Results 1 to 14 of 14
    Apr 12 2015
    408 CA
    2012 c7 a6 3.0T water pump + thermostat DIY tips
    Got the water pump and Thermostat replaced today, the vehicle was not required to be put into service position, nor was the front bumper removed.
    We took off the plastic cover above the radiator ( plastic guard ) , and took off the radiator fasteners, and wedged the radiator backward, away from it's mount; away from the engine, giving us enough clearance to remove tension on belt, removed all sensors on and around supercharger, removed supercharger, removed thermostat pipe(PITA, lots of bolts) , thermostat + water pump; replaced both parts and reinstalled in reverse order.
    Did not have to remove front bumper, or radiator support, only removed corner screws to give more leeway for movement for radiator support.IMG_20190830_184123.jpegIMG_20190830_200445.jpeg
    Sent from my Pixel 3 using Audizine mobile app
    Veteran Member Three Rings 3g_bishi's Avatar
    Mar 03 2016
    07 a6. 13 A7, 13A6, 08 A8LW12, 16A3, 15RS7
    DFW
    Nice!
    Why are you using prestone coolant?
    Apr 12 2015
    408 CA
    empty bottles from different vehicles to empty out the coolant from reservoir.
    i put G12+ purple into it.
    will be flushing it out soon along with liqui moly for the oil.
    Sep 01 2016
    Sacramento, Ca
    Quote Originally Posted by violentaudi42 View Post
    Nice! I have two questions- what parts do you need besides the thermostat and water pump? ( gaskets, coolant, etc...) and how long did it take you? Thanks!
    Apr 12 2015
    408 CA
    4 hours and we replaced the supercharger gaskets while we were there.
    Sent from my Pixel 3 using Tapatalk
    Veteran Member Four Rings Ford Prefect's Avatar
    Jan 20 2017
    RS7
    New Hampshire
    Did you clean the valves?
    Apr 12 2015
    408 CA
    Did not , wasn't that deep in. I want to get them done professionally. Like a walnut blast
    Jun 16 2018
    nh
    Perfect! I need t do this before the winter (mild leak in my water pump, non oem bs)
    Did you have to use a flat breaker bar, or were you able to use a standard one?
    Apr 12 2015
    408 CA
    Had to be flat!
    Barely enough clearance.
    Radiator had to be pulled Way from engine, 2 man job.
    Sep 01 2016
    Sacramento, Ca
    So a complete list of supplies-
    Water pump
    Thermostat
    Supercharger gasket
    G12 coolant (how much?)
    Anything else?
    Apr 12 2015
    408 CA
    3 -4 jugs does it for the coolant , and just regular tools, you need torx bits too. Make sure you have a full set.
    Sep 01 2016
    Sacramento, Ca
    Did you bother with the coolant vacuum fill tool? On some of the installs they use it to fill the system I believe.
    Apr 12 2015
    408 CA
    No , I was planning on doing a coolant flush soon anyway , didn't bother with the coolant too much.
    Sep 01 2016
    Sacramento, Ca
    Thanks. Did you have a leaking pump or just do it as preventative maintenance? How many miles does the car have? I’m thinking about doing it at all as maintenance when I get to 80k.
