The GFB (Go Fast Bits) DV+ has been around for quite a while and is popular on the VW Golf scene. The basics are that it replaces the guts of your stock solenoid powered DV with a machined adapter plate, pilot actuator, brass piston with silicone gasket and a couple springs. If you want more detail on how exactly it works head over to their website https://gfb.com.au/products/blow-off...alves/dv-plus/ they offer excellent explanations and videos. (P.S. they also have excellent support.) (BTW I have no affiliation with GFB.)
I have never seen anyone attempt to install them on a 4.0T before...
...and for good reason.
There is literally no room to install the adapter as it extends the length of the DV by 11mm. Which on the drivers side pushes it all the way into the engine cover standoff and a piece of valve cover casting that is in the way. There is no way to rotate the valve either as the electrical connector will only fit in the one spot and you'd have to extend the wires in any other position anyway.
Regardless, based on Phantom's experiences and literally dozens of other positive reviews I decide to move forward and grind out a spot for them to fit.
Here is before grinding. (The end of the stock setup has the OE valve sitting about 3mm from that casting part of the valve cover.)
Here is after grinding.
I took off more than was necessary to allow a little breathing room, plus I am not that adept at grinding of this nature and was only using a dremel tool. So please excuse the messy look. Anyway I managed to make enough room for it to fit. The passenger's side is further away from a similar spot and required less grinding.
On too the impressions...
My uncalibrated butt dyno and the lap timer boost gauge makes me think there is a difference. It does seem like it holds boost better to redline now. In particular in 3rd gear it just seems like it keeps pulling right to redline where before it felt like it ran out of breathe earlier. It actually surprised me a little because it was pulling like a freight train and seemed like it wasn't going to shift at first but it did...right at redline and full boost on the bar.
I did not notice any downsides. No extra unusual noises (the coming off part throttle low speed release is still audible like with stock valves and RS7 airbox), no fluttering or other weird noises at all. Driving normal it feels as normal as you'd expect.
I'd like to give it some more seat time and maybe get it over to the strip to see what difference it makes there, but overall it seems like it does as advertised.
Is it for everyone...probably not...there is quite a bit of grinding involved. It also doesn't magically create more boost than you had before. I feel it does holds available boost better (as intended). I'd be curious how it is on Stage 3 cars since holding boost better would seem paramount at their increased boost levels. It is quite pricey, but less than some full vacuum operated ones and (grinding aside) less complicated to install.
As always let me know if you have any questions and I'll do my best to answer them.
Passenger's side after grinding
Driver's side reassembled
Passenger's side reassembled
Overall reassembled.
