Results 1 to 4 of 4
    Established Member Two Rings tonycasas's Avatar
    Feb 05 2018
    El Paso
    Fault 01543 - Parking Aid Warning Chime (h15)
    I recently started to get the following fault while scanning the card using Carista in my 2017 A3 Premium Plus Quattro:
    01543 - Parking Aid Warning Chime (H15)
    My parking system seems to be working fine from what I can tell, so I am wondering if this is a false positive? Anyone else getting this?
    I was also getting this fault since I had my car (again, using Carista):
    00022 - Actuator warm flap center console in the back of the right of (V201)
    and had the dealership scan it and they found nothing.
    Thanks in advance!
    Dec 25 2004
    Earth
    Ive heard its Carista...
    VCDS wont give false indications...
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Veteran Member Three Rings bakedcorn's Avatar
    Jul 27 2015
    Ontario
    I’m beginning to believe the above response. Each time I scan the car for codes with Carista the same usual suspects pop up, a total of 7 if I recall however each time the car went in for maintenance the dealer reports the opposite, no errors found. Grain of salt maybe is in order?
    Feb 05 2018
    El Paso
    Yeah I think that’s the case. Nothing seems to be working improperly so I’ll just chalk it up to Carista false positives. I tried scanning with ODB Fusion and it came up with no errors. So I think we’re good to go.
