Results 1 to 13 of 13
    Aug 26 2019
    Botswana
    Instrument Cluster (Gear Display) Showing Gear Wheel Symbol
    Hello Guys,
    My b8 1.8T 2008 gear display does not show currently engaged gear but instead it shows a gear wheel symbol as shown below.
    What are the possible causes and solution to this.
    Jan 03 2013
    Baltimore
    Looks like a transmission fault. Have you scanned it to see what the fault may be?
    Sent from my Pixel 3 using Tapatalk
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Feb 15 2016
    Cambridge,Ontario
    Jesus these cars are getting smart .. i just wait for the burning smell and listen for the noise..
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Jan 03 2013
    Baltimore
    Is that referring to the clutches in a DSG trans or THE clutch on a manual trans? I've got a 6M and had no idea the car was capable of this type of fault. What sensor or system would monitor that? I thought the clutch on the manuals is completely mechanical without any electronic monitoring.
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by elscotto80 View Post
    I believe it is a manual clutch warning. The ECM knows what gear you are in and most likely has an algorithm to compare gear selection/engine rpm/road speed. If the rpm's are consistently higher than the expected value it assumes clutch slippage.
    Aug 26 2019
    Botswana
    Hello,
    I will have it scanned to check the fault...i think its the tiptronic manual not work because when engaging the tip mode it does not do any gear shift but drives well in auto mode.
    Cool
    Aug 26 2019
    Botswana
    Mine its a white symbol...
    Aug 26 2019
    Botswana
    So what will need to be done to fix the tiptronic manual mode. ?
    Aug 26 2019
    Botswana
    how about if its the white one....which refers to tiptronic malfuction.
    Dec 28 2006
    Western Maryland
    And upon further review I believe the red and yellow also refer to the automatic transmission and not a manual clutch. Clicky clickŪ
    Established Member Two Rings JUNBUG361's Avatar
    Jan 08 2019
    1965 MUSTANG GT COUPE
    Antioch, Ca West Coast
    Transmission is possibly losing communication with other modules maybe
    Aug 26 2019
    Botswana
    What might be worst damage this might cause....it is a matter of just fixing the tip mode or the tranny might be gone bad ?
