Results 1 to 20 of 20
    Feb 15 2016
    Cambridge,Ontario
    pin extraction tool for ignition coil connectors
    As these cars become older and with the heat on top of the engines i an finding these connectors are starting to break and crumble. ECS sells replacement connectors bu getting the pins out can be a challenge. I also dont want to cut into the wiring harness and crimp.
    In my research i cam across this from another site.
    https://www.mouser.ca/ProductDetail/...61kfbFCVPh1A==
    not eve sure its for our particular cars. its just all i could find and it is fairly pricey.
    I was thinking of making something with some bits lying around but thought i would ask in case anyone else has been through this.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Veteran Member Four Rings MugelloB7RS4's Avatar
    Feb 06 2015
    ECS sells a kit from Schwaben that is a multi tool that might help.
    https://www.ecstuning.com/b-schwaben...xoCGIYQAvD_BwE
    Jan 01 2012
    2004 A4 Avant
    CO
    Quote Originally Posted by MugelloB7RS4 View Post
    Definitely get one like this with multiple tools for different size connectors! While it may seem like a lot of money, it’s worth it for something like this if you do a lot of electrical work on these cars
    | 2004 A4 Avant | Gloss Dark Grey |
    | 2.7t K04 swap | 034 RSB | Apikol snub | 17z BBK |Vogtland GT1 Coilovers | Moog adj. UCA's | Peeler reps |
    | 2011 A4 Avant | Brilliant Black | 6MT swap | APR S2 | APR Downpipe | Vogtland Coilovers | RSE's | 034 Sway/tranny mount | Q5 brakes |
    Feb 15 2016
    Cambridge,Ontario
    that looks like it might do the trick . A little more than i need .. over 100 bucks CAD plus shipping to push a pin out seems like a lot but for what it does likely worth it. I wonder if anyone found some kind of standalone knock off tool.
    i dont do a lot of cars .. i just want to fix a couple of connectors on mine.. still might spring for it though ... i said this would be my last German car about 4 german cars ago so i will likely use it multiple times. Has anyone used this on our B8(.5) and can confirm one of the tools will work on our ignition coil harness ?
    thanks for the info , that's a good start.
    1976 Yamaha XS 360
    Jan 01 2012
    2004 A4 Avant
    CO
    I have a single tool that I bought off of amazon for like $15. While it gets the job done, I had to modify the prong ends a bit with a deemed and while I can get it to work on some connectors, some are too big or small for it and I end up using small electronics flathead screwdrivers
    Feb 15 2016
    Cambridge,Ontario
    yeah and sometimes you need 4 hands .. one small flat head on either side of the connector, one hand to hold the connector and one to pull the wire ..
    1976 Yamaha XS 360
    Jan 01 2012
    2004 A4 Avant
    CO
    this is the one I currently have
    Feb 15 2016
    Cambridge,Ontario
    that one looks like it might work .. but yeah i see what you mean .. you kind of need the bend part way down inwards. gives me an idea to make a tool though.
    1976 Yamaha XS 360
    Apr 20 2019
    Coloarado
    Ebay has some sets for 20 or so. No idea of quality, but for hobby use they will probably be gtg.
    Veteran Member Three Rings BrewDude's Avatar
    Mar 13 2009
    04 R32 FT450
    KLAS
    The Schwaben kit from ECS is garbage. Every extraction tool had the tips fall out.
    Feb 15 2016
    Cambridge,Ontario
    Anyone have a link to an ebay kit they know works? I'd throw 20 bucks or so at the project as it will.likely be a one time use thing.
    Sent from my SM-G973W using Audizine mobile app
    1976 Yamaha XS 360
    Jul 16 2018
    Atlanta
    I unwound a thinner paper clip and it looks like it should accomplish the task all the same.
    The third pic in this eBay listing gives a good view of the tabs trying to be pushed back.
    http://www.ebay.com/itm/Ignition-Coi...-/362375617604
    Of course, ShopDAP video on the subject, including links to the tools used.
    www.youtube.com/watch?v=lrs8-KtJGus
    Jul 16 2018
    Atlanta
    And if you can't find one that works in all this, https://www.amazon.com/dp/B07T6972Z4, ....
    Feb 15 2016
    Cambridge,Ontario
    i did try the paperclip method and although i did get one pin to move out of 4, it was not ideal..
    1976 Yamaha XS 360
    Veteran Member Four Rings Spawne32's Avatar
    Nov 20 2016
    I litterally just broke up the connector around the pins and then took all the debris away and put the pins in the new connector. lol
    Feb 15 2016
    Cambridge,Ontario
    found one that fits my budget...
    it should get here in about 6 months so I will be sure to update you guys on how it went.
    https://www.ebay.com/itm/18Pcs-Car-W...-/253939223610
    1976 Yamaha XS 360
    Nov 20 2016
    lmao 2020 is gonna be a big year for you
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by Spawne32 View Post
    lol
    ok truth is my car is a 14 and is fine... my buddies car who I just fixed every single one is broken.. one in fact the whole casing is broken because he tried to remove it without undoing the harness screw.... yeah this is what I have to deal with.
    so I told him get it fixed..... so having said that im expecting the "misfire" call mid October and want to be ready.
    1976 Yamaha XS 360
    Jul 16 2018
    Atlanta
    I hope you opted for the squaretrade 2yr protection plan; it was only $2.
    Veteran Member Three Rings Ray1031's Avatar
    Nov 01 2015
    San Antonio, TX
    I use a hair Bobby pin and it gets the job done
