Results 1 to 18 of 18
    Junior Member Two Rings dbetter's Avatar
    Jul 16 2019
    2002 A4 Big Turbski, 2005 Audi S4, MK4 VR6 Wagon (sold), MK4 TDI (sold)
    Grand Rapids Michigan
    Question Fuel level gauge not working even though level sensor is fine
    I've taken these senders out three times now, with not much luck at repairing the issue. My fuel level 2 sensor on the driver side of my B6 A4 Quattro 1.8t, which is responsible for the instrument cluster gauge reading, is showing 55 ohms, which I am told is in range. Not sure why it's not going to full even with a full tank, tried using vcds to calibrate the tank, highest I can get it to go is 3/4 tank. Any help is appreciated, I've tried the fuse trick as well to try an reset it, no luck. I'll post my scan and a picture of my meter.
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
    Part No: 8E0 920 950 HX
    Component: KOMBI+WEGFAHRS. RB8 D29
    Coding: 03200
    Shop #: WSC 03354
    VCID: 064092DB20CF657FA3-5184
    WAULC58E02A135667 AUZ6Z0A0266150
    7 Faults Found:
    01039 - Coolant Temperature Sensor (G2)
    30-10 - Open or Short to Plus - Intermittent
    00771 - Fuel Level Sensor (G)
    30-00 - Open or Short to Plus
    00438 - Fuel Supply Sensor 2 (G169)
    00668 - Supply Voltage Terminal 30
    53-10 - Supply Voltage Too Low - Intermittent
    01331 - Door Control Module; Driver Side (J386)
    49-10 - No Communications - Intermittent
    01320 - Control Module for Climatronic (J255)
    01304 - Radio
    49-00 - No Communications
    -Built B6 A4 Quattro 1.8T, GT35R, 6 Speed Swapped 02X-GVE
    Jan 24 2010
    Paramus,NJ USA
    What is the vin for the car where the cluster is installed. As according to your scan your showing a rb8 cluster in a 2002 vin. Not possible as rb8 was only installed in later a4/s4 2004 or 2005 model year only and some cabriolets.
    Also both sensors report a ohms reading then the average is calculated not just 1 sender.
    Ziddy Autowerks
    Jul 16 2019
    Car vin is WAULC58E02A135667, I tested my passenger sender too, it was in range, I think 49 ohms, so do u think someone swapped my cluster??
    Jul 16 2019
    Recoded the soft coding in the module, it got rid of all my fault codes except for fuel level sensor (G), and my fuel gauge is reading 3/4 when I have a full tank
    Jan 24 2010
    Paramus,NJ USA
    have you tried doing the gauge sweep in vcds??
    Ziddy Autowerks
    Jul 16 2019
    Your not able to on the B6's, but I have done a full calibration which resets the cluster
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    While the senders test ok, are they operating properly when installed? There's a thread around here on replacing the sender/fuel pump. Newer units have a small hose that needs to be put into the correct spot on installation or it causes fuel level issues. Could that be what's causing your issue, at least in part?
    Also, have you checked the wiring that connects to the sender? There could be a break in the insulation somewhere causing your fault given the code you have.
    Sent from my Pixel 3 XL
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Nov 03 2011
    All Over!
    Quote Originally Posted by dbetter View Post
    Has this always been an issue since you had the car? Or did it occur in your ownership?
    1986 Type 85 Audi 90 quattro
    Jul 16 2019
    Hmmm, I didnt check the placement of my vent line when installing the pump, that could very well be my issue, I'll have to try it in a few days when my fuel level goes down far enough so I can pull the top off it. Also @Nollywood, I've had this issue since I bought the car, on July 15th of this year, so I haven't had it long.
    Nov 03 2010
    2019 Audi A5 Sportback, 1986 MB 560SL
    Fallbrook, CA
    Quote Originally Posted by imnuts View Post
    That's what tripped me up, the small overflow tube which should be fitting through a funnel-shaped opening in the tank's plastic support bracket. If left loose, the tube interferes with the float. My car would do the same thing with the fuel gauge; once I was aware of this issue, it was fixed in 10 minutes. Run your fuel down enough in the tank so the access cover can be removed without flooding the back seat area with gas, and check that little tube.
    Jan 24 2010
    Paramus,NJ USA
    Could be your issue if the float is getting hung up. This is why good repair information is important and knowing how its supposed to be routed.
    - - - Updated - - -
    B6's will go the gauge sweep all clusters will. Not at start up but rather output test of steppers to make sure they are operating correctly.
    Ziddy Autowerks
    Jun 12 2014
    2002 Audi A4Q (B6) 3.0 6MT; 1999 Mustang Cobra; 2003 G35 Coupe 5AT
    Tampa FL
    Quote Originally Posted by EuroxS4 View Post
    - - - Updated - - -
    I think that I had the same problem and you helped me.
    It was the tank type/volume setting being wrong somehow...probably done accidentally when I was setting some other feature in VCDS.
    2002 Audi a4 B6 Q 3.0 6MT
    Jul 16 2019
    Just fixed my vent tube, didnt't fix it, so I did the output tests, as well as full calibration in the Adaptation, and tried setting fuel level sensors to 160 in Adaptation as well, highest it will go at 160 is 3/4 full... Any other ideas?
    Control Module Part Number: 8E0 920 950 HX
    Component and/or Version: KOMBI+WEGFAHRS. RB8 D29
    Software Coding: 01231
    Work Shop Code: WSC 03354
    Additional Info: WAULC58E02A135667 AUZ6Z0A0266150
    2 Faults Found:
    01304 - Radio
    Jan 24 2010
    Paramus,NJ USA
    Pull fuses 15 and 28. Try to start the car. It may start and stall. Turn igniton off then put fuses back in and see what the gauge reads. Also have you tried going into MVB 4 in the cluster to see what each sender is sending to the cluster??
    Ziddy Autowerks
    Jul 16 2019
    Fuel level sensor 1 readin 510 ohms..... sensor two is fine at 106 ohms, gonna check cluster wiring now.
    Jan 24 2010
    Paramus,NJ USA
    According to that picture sensor one is no good. Resistance is too high.With a empty tank should be maxed out at 305ohms not 510. When full should be between 56 to 68ohms. I would say sender 1 is no good.fuel sensor.png
    Ziddy Autowerks
    Jul 16 2019
    The sensor is fine, I've tested both of them already, pulled my cluster out about 30 min ago, tested pins 32 and 3 of the blue connector, got no reading. Switched to pin 32 and 11, and got 112 ohms from my driver side sensor. So then I unplugged passenger side sensor and tested for continuity, one of the wires are fine, but one I got no continuity through. Gonna have to do some rewiring and I think I've found my issue
