So I have a 2013 A4 with an oil consumption issue. It's burning a quart of oil every 600 miles (110k on dash). This issue didn't start until I had the dealer do my oil change in March 2019. Also took the car to a shop that specializes in Audi and VWs. The mechanic stated that there are no leaks. Besides the high oil consumption, the car drives/run great. I had someone say that maybe I should replace the PCV first to see if that helps. Any suggestions😫
I'm going to get a oil change and try the motul oil to see if that helps as well.
Side note also I had the Timing chain and tensioner replaced at 75k.
