Results 1 to 9 of 9
    Established Member Two Rings pjekar's Avatar
    Jul 17 2017
    2018 S7 Prestige
    Staten Island, NY
    Color Matching - Daytona Grey
    So...
    Somebody clipped my 2 months old SQ5 Daytona Grey Pearl Effect - I was thinking that since the car had minimal weather exposure, paint match will be nearly perfect. Hell... I couldn’t be further from the truth. LZ7S is completly different shade of color and now I am going through anxiety about getting it done, since I don’t know how to get the doors back to perfection... anyone had experience with matching this color and achieved near perfect effects? I already know spot painting won’t do the truck, but I want to make sure shop gets all the info they need so I don’t have to listen to “this is a touch up work, you got to understand that it won’t be perfect”...
    Veteran Member Four Rings choppstixxx's Avatar
    Apr 24 2017
    2016 Audi Q5 3.0T Premium+/2003 Honda S2000
    Hilton, NY
    IDK if it's just me or because the picture is not large enough, but where is the damage? If it is very minimal I would just see if PDR and a good paint correction would be better/less invasive than a whole re-spray.
    2020 Manganese Gray Metallic VW Arteon SEL Premium R-Line
    2003 Berlina Black Honda S2000
    2004 Crownline 202 LPX
    2016 Glacier White Metallic Q5 3.0T Premium+ S-Line 1 of 589 *RIP*
    2013 Moonlight Blue Metallic A4 Quattro Premium Flex Fuel 1 of 519 *RIP*
    Jul 17 2017
    2018 S7 Prestige
    Staten Island, NY
    Zoom on on this section to see color difference between passenger and driver’s side. IMG_1831.jpg
    Mar 12 2017
    N.C. USA
    Are you using the factory paint code on the drivers door to match your color? I have a local source that can always match factory colors. They are a specialty co. that does only touch up work or small panels. Have used them for many yrs. Always dead on.
    2020 Q5 prem plus Matador red/Beige
    Veteran Member Four Rings EvoToSQ5's Avatar
    Aug 09 2018
    2017 Audi SQ5
    Leominster, MA
    Any pearl will be extremely hard to color match 100% although it’ll be very hard to spot to the untrained eye. Had my Evo resprayed after some vandalism which was also pearl. I couldn’t tell the difference but my friends dad who did paint work could see a minor difference in one area. Had to be in the right lighting and you had to be right in front of the panels.
    Veteran Member Three Rings windyctyaudi's Avatar
    Jul 30 2007
    '12 S4 prestige DSG
    Chicago
    I had a similar issue when trying to match Mythos Black Metallic on my SQ5. I tried multiple colors and had no luck. I was being stubborn and wanted the rock chips to be fixed immediately. I finally gave up and ordered genuine Audi touch up paint though ebay. I ordered the kind that came in a small bottle rather than the pen style. It will come with the paint in one bottle and the clear coat in another. I then applied, wet sanded and polished, its as close to factory as its ever going to get without getting the hood resprayed.
    Veteran Member Four Rings VroomVroom's Avatar
    Jan 03 2007
    SF Bay Area, CA
    It's worth asking the paint shops you're considering about their process. Armed with the paint code and VIN, they'll be able to not only match the color but also the batch code(s) from the original paint. The challenge then becomes one of expertise, and if it's done right you'll be the only one to ever know...and even then you'll need a magnifying lens to confirm. Honestly, the real difference will be in the clear coat, and even that will only be noticeable during any paint correction efforts.
    Bottom line: with the right shop, you have no worries. Might be worth focusing on shops that specialize on German vehicles. FWIW, Mercedes and BMW both have colors that make matching Daytona seem like a walk in the park by comparison.
    --Jerry || 2020 SQ7 Pr, GW/Black/BO (His); 2018 S5 Cab Pr, Daytona/Red (Hers)
    Suspension || H&R Springs - 29001-3; Bilstein B8 Dampers - 24-145985 (F) & 24-145992 (R)
    Wheels & Tires || BBS CI-R - CIR 0501 BPO, 20x10 ET25 Satin Black; Continental DWS06 275/40
    ...Formerly: '16 SQ5 '13 Q53.0T '12 Q5 3.2 '08&'06 A4 Avant 3.2.
    Aug 09 2018
    2017 Audi SQ5
    Leominster, MA
    Not sure where in NY you are but J&B body works might be one of the best options.
    Sep 28 2018
    St Petersburg
    Very easy to match, you will have to blend into the front door and use “base coat blender” before painting to lay metallics on wet and it will blend in nicely
