Installation was a breeze. Just make you sure have a T30 Torx bit or driver. Other than that, piece of cake. One tip I can give you, is that you should mount the solenoid on the given bracket, prior to installing. It would be tedious to do it while on the car. I also pre-rigged the vac lines so it would make life easier with zip ties. And don't forget to wait until the car is totally cooled down or you'll be working in a very hot area.
Fit and finish is great. No issues or defective looking parts. Tight tolerances. Something you'd expect from Forge.
Now the good stuff.
The sound is the same on spool up, but much "tighter" and direct. More fluid. That stronger piston is making sure nothing is escaping until you let off or shift. And the "woosh" is much more precise and mechanical. Not as flabby or loose as the stock valve. Mind you, my AWE Intake has the lid option, so it's not as loud and obvious as the open style intakes. It sounds serious. The plastic piston on the stock valve takes less pressure to activate. Its on the loose side. And the Forge is stronger and has absolutely no wiggle room in it's moving parts. The tolerances are perfect and precise. I like that because it's functioning the way it should. And I like me some functioning parts.
The Forge Recirc valves performs well. There's precision with the boost. It gets back on boost quickly and gives the feeling of better throttle response. Quicker response. It's not making more power, but it's performing and utilizing the excess boost more efficiently. And faster. And adds a nice touch to the driver experience.
Now that it's all good from Forge and there aren't any hiccups with false readings, I definitely recommend this to those who care for the details I've mentioned above. I'm a function over form guy. If something is just going to sound "cool" with no other benefit, I'm not doing it. This has both. And form follows function with this Recirc valve. It was just a matter of preference choosing this over the Atmospheric Dump Valve. They perform the same, but sound different.
Anyway! Great mod, lots of fun and functionality. Big Thank you to Mops at Nemesis for the assist! He managed to get me, what we believe, was the first one in the US for the B9 S4. Of course he did! lol. He's the man. Hit him up if you want one! No regrets on this purchase.
Some pics and vids
