I am hoping a couple of readers can help me out!
My 3.0TFSI (Supercharged) engine has a high level of vacuum in the crankcase. This is noticeable when you remove the oil cap as it is difficult to remove whilst the engine is running. It requires a force of about 2 to 4 lbs to open it.
I also had a PCV fault code and I understand that this combined with the excessive vacuum are signs of a faulty PCV system.
I had the PCV valve and PCV pressure control solenoid replaced by the dealer. The fault code has gone but I still experience the high vacuum pressure in the crankcase. According to my dealer this high crankcase vacuum is normal.
Does anyone else have some info on if this is how it is supposed to be? It will be a huge help if some readers can
As I understand it there is only supposed to be a very slight vacuum just to scavenge any possible blowby air at idle.
Any help will be appreciated! Thanks.
