Results 1 to 18 of 18
    Veteran Member Three Rings AudiC7Owners's Avatar
    Jan 14 2016
    Wilmington, NC
    Someone explain AMAX to me please
    I've been seeing people talk about it, and I think I have a vague Idea, but I'd like to hear from someone who explicitly knows what it is, and how to do it on a 3.0T ZF car.
    Kwikstix DIY Video Thread
    //2013 A6 Prestige 3.0T |IE Stage 2 Single Pulley | Berk TCU Tune | Injen Intake | Cende Valvetronic Full Exhaust | Gutted OEM Catalytic Converters | Merc Racing HX | H&R Sport Springs | 034 Motorsports Control Arms & Engine Mounts | Eurocode Drivetrain Mount Inserts | Eurocode Front & Rear Sway Bars + End Links | P3 Multi Gauge | StoneCarbon2009 RS Style Grille //
    Oct 02 2005
    The Moon
    Quote Originally Posted by KwikStix View Post
    AMAX or acceleration maximum is a function of "launching" the car.
    Foot on brake, traction control off, foot on gas till revs stabilize and release brake. In this situation the vehicle will not reduce torque output during shifts, causing more abrupt shifting and the fastest possible acceleration.
    Jan 14 2016
    Wilmington, NC
    Quote Originally Posted by p3u View Post
    Thank you.
    So it doesn't have to be in sport mode? This can be done in manual or sport?
    Does the car have to be in Dynamic?
    Oct 02 2005
    The Moon
    Thanks you.
    Welcome.
    In any mode it can be activated as long as the steps mentioned above are followed.
    Jan 14 2016
    Wilmington, NC
    Welcome.
    Fantastic. Appreciate the fast replies.
    Aug 08 2018
    New Hampshire
    You have to push and hold the traction control button until it says "Braking guard off!", about 15s, just pressing the button to disable ESC isn't enough.
    Jan 14 2016
    Wilmington, NC
    Quote Originally Posted by kebabman View Post
    thanks for the clarification
    Veteran Member Four Rings Shane Horning's Avatar
    Nov 16 2018
    2012 A6 Prestige IE dual pulley. custom trans tune. mercracing hx. autotech hpfp.
    Upstate. New York.
    Must be not all are the same cause I don't have to hold it just press to disable tc
    Veteran Member Three Rings krwalkman's Avatar
    Jan 01 2018
    Thornton, CO
    Quote Originally Posted by Shane Horning View Post
    I also just have to press it. Also, for A model cars, such as my A6 there is no AMAX from the factory. I had it added via the TCU tune. Also Also, holding the traction control button does nothing in my car, regardless of the amount of time, just acts like a single press. I think that is S-model specific.
    Moonlight 2012 A6 Prestige FBO - SOLD
    Monsoon 2014 SQ5 Prestige
    4.0T Swap in Progress by @SPAutowerks
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by krwalkman View Post
    I've seen this mentioned before too. I don't know why some people seem to have to hold the button. Even in my S6 it is just a single press...holding does nothing.
    There is about a 5 second delay between the display saying ESC: Sport & Braking Guard: off but you do not have to hold it at all.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Senior Member Three Rings RSLRS71's Avatar
    Mar 03 2017
    18' SQ5 and WK2 SRT8 Jeep
    Castle Rock, CO
    i had thought it was the fore mentioned steps but the car needed to be in Dynamic to take full credit.
    2017 RSL RS7 (1 of 3 stateside)
    Mods:
    Current: APR Stage II w/ HF DPs and KW H.A.S kit , Rotiform 3 piece SPF 21x10.5 wheels, Tag Motorsports Side marker delete and Badge blackout, ...
    Next: looking to be the quickest RS7! ;)
    Nov 16 2018
    Upstate. New York.
    They have amax mode from factory but they have a 100 limit
    Veteran Member Three Rings WatchMeSpend's Avatar
    Mar 19 2019
    2016 A6 3.0T Technik S-Line
    Toronto/Ontario
    My C6 A6 was press and hold. C7 A6, holding doesn't seem to do anything.
    Oct 02 2005
    The Moon
    Quote Originally Posted by RSLRS71 View Post
    It does not. It could be in comfort and still engage AMAX.
    Jan 14 2016
    Wilmington, NC
    So I just tried it and I did what P3U said and it worked like a charm.
    Just for reference I have a 2013 A6 3.0T, prestige.
    Also, holding down the traction control button did disable breaking guard after about 5 seconds.
    Amax is definitely interesting. According to my P3 gauge, it knocked off a half second on my 0-60 time, in 95 degree humid weather. I did 0-60 in 5.43, whereas without AMAX I did 5.85 in 75 degree weather.
    Jan 14 2016
    Wilmington, NC
    Can you see how many have been used/are left via vcds?
    Nov 16 2018
    Upstate. New York.
    I don't know. Curious myself
    Veteran Member Four Rings A U D I's Avatar
    Nov 13 2012
    Chicago
    Correct, however it should be only 5 seconds on certain years and others do not need the long hold. It should be in sport mode to fully engage. Also, if you hold it for too long it will not engage and drop power.
