Results 1 to 9 of 9
Thread: Exhaust J-Pipes
    Junior Member Two Rings Merlintwist's Avatar
    Feb 27 2019
    Scotland
    Question Exhaust J-Pipes
    I know drone plays a huge factor on the 3.0T with an exhaust, so I've been wondering has anyone tried J-Pipes (or 1/4 wave resonators as they're also known) to cancel out those resonant frequencies?
    If so, what was the outcome?
    I know Polo Performance used adjustable J-pipes on their system to help cancel out some drone and it seemed to get decent results if set up correctly.
    For those curious on the subject of J-Pipes and need the formula for calculating the length, here you go:
    1100 feet/second (roughly the speed of sound) divided by the target frequency you're trying to eliminate (in cycles/second) gives a full wavelength in feet per cycle. Divide this number by 4 to get a quarter wavelength (a much more convenient length to work with). Finally, multiply this wavelength by 12 to get the chamber length in inches.
    Example 110hz:
    ( 1100 / 110hz ) / 4 ) x 12 = 30 inches
    EDIT: After more digging i finally found JACKAL's thread on expermienting with exhausts which includes 1/4 wave resonators on the downpipes.
    https://www.audizine.com/forum/showt...tors-a-j-pipes
    2014 B8.5 S4 Black Edition - Phantom Black Metallic | Alcantara
    IE Stage 2 | 187mm CTS Crank Pulley | Porsche Macan Calipers | Merc Racing HX | Eibach Pro | 034 RARB | VBT G-Hook Discs | DS2500 Pads | CR-15 Strut Brace | 034 Billet Underbrace | Billet Trans Mount Insert | Carbon Mirrors | ECS Carbon Inlet | Leyo PD Paddles | 5% Rear Tints | 50% Front Tints | Michelin PS4S
    Veteran Member Four Rings theweebabyseamus's Avatar
    May 12 2008
    No disrespect, but search a bit. I know its been done a bit, iirc JACKAL has done something similar.
    Veteran Member Four Rings JACKAL's Avatar
    Mar 28 2017
    Infiniti QX70S, Indian Scout Bobber
    Southeastern Wisconsin
    Quote Originally Posted by theweebabyseamus View Post
    You recall correctly sir. I do have branch resonators on my setup. Mine were approximately 32 inches long, calculated using the same formula noted above but slightly longer because I used a slightly higher speed of sound due to increased air temperature. There were more effective when I still had cats. After going catless, I gave up and had to go back to my stock mufflers to completely eliminate drone.
    B8 Sprint Blue S4 | 6MT | 034 Motorsport Stage 2+ E40 (3.40 PR) | Tampa Autosports Ported Blower | AEM Water/Meth 1000cc | Test Pipes | CTS Turbo Downpipes | MF 11385 | AWE Touring | Injen Intake | 75mm Ported TB | Merc Racing HX | Stoptech 6 Piston BBK | Stainless Brake & Clutch Lines | SB Stage 3 End. Clutch | Eurocode Short Shifter | D-Steering Wheel | Autotech HPFP | 034 Motor Mounts | Low Kick Spoiler | RS Bumper | Verde V99 19x9.5 Wheels
    Feb 27 2019
    Scotland
    Quote Originally Posted by JACKAL View Post
    Cats will be staying on my car for a while yet.
    Interesting placement for the pipes too! Did they successfully combat the drone you were chasing down when you still had cats in place?
    Mar 28 2017
    Quote Originally Posted by Merlintwist View Post
    They helped a bit. They weren't 100% effective but they cut it by perhaps 50%.
    Mar 31 2008
    eS-4
    CAL*SO
    If you want j pipes,buy a polo exhaust. Seriously everyone's chasing this "idea" yet no one had been able to replicate what polo can do. Save the grief
    Save the time
    Save the bs thinking you know what your doing lol.
    It's financially cheaper just buy the damn system and be done with it. No one has ever complained that polo doesnt work.
    No one has ever said "drone" or "rasp" when referring to polo.
    Oct 30 2012
    Oxford, MS
    Quote Originally Posted by Fresh.S4 View Post
    Save the time
    I'm quite happy with my setup (though I would never recommend replicating all that I did). I still need to get some updated videos now that the system has had time settle.
    https://www.audizine.com/forum/showt...-exhaust-setup
    The Polo likely does a great job if you don't mind a restrictive turbo style muffler in the system. But I'm glad I didn't go that route.
    Mar 31 2008
    eS-4
    CAL*SO
    how do you figure turbo restrictive muffler?
    its literally a x pipe muffler (just like the magnaflow everyone swears by) and a traditional x pipe (that ecs runs on theirs/ as well as AWE). the difference being right after all of this, which is literally a straight pipe/ j pipe out?
    Junior Member One Ring
    Oct 19 2020
    So why pay 2 grand for it then lol?? So many people do this for 500$. I don’t think anyone’s going to buy a used polo with the metal quality , but it does sound great
