Results 1 to 3 of 3
    Aug 09 2012
    Alberta
    1.8T MAP Sensor in place of 2.7T
    Recently picked up a 2001 from an older gentlemen.
    Going through the receipts I see a note from a shop that the MAP sensor had failed and they put in a 'used one from a 1.8T'.
    My question is, should this sensor cause me any issues?
    I pulled the cover to check the part numbers of the installed sensor.
    Bosch # - 0 281 002 177
    VAG # - 038 906 051 (No indicated revision letter)
    What I assume is Build date - 2 29/01
    I don't know what model 1.8T this came out of unfortunately.
    Apr 07 2011
    Home of the mighty beaver
    same sensor.
    Aug 09 2012
    Alberta
    Thank you.
