I have done all of the testing and found that both of my radiator fans are dead. I went to a you-pull-it parts yard to practice and see if I could do the labor myself. I removed everything from the bumper to the radiator with not much trouble. But the radiator was a nightmare. The refrigerant lines were rusted and broke off when i tried to remove them. The transmission fluid lines were also not fun. But I was able to get the radiator out and get the fan assembly out.
My question is if there is a better way to do this without removing the radiator? While I'm that far into it, I want to do a timing belt and water pump. I appreciate any help. Thanks.
