Page 2 of 2 FirstFirst 12
Results 41 to 59 of 59
  1. #41
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    Quote Originally Posted by RoofRails View Post
    LOL ! All of the settled SQ vs Q science is being challenged in this post. What in the world is going on. Here is my input since I spent many a hour looking into this. These are the facts and I don't have to rip apart either of these two below items to tell you that.
    1. Engine = same
    2. Trans gearing = same
    Sent from my SHT-W09 using Audizine mobile app
    Yes. Confirmed multiple times. Repeatedly. Only difference engine wise is the small supplemental HX on the SQ in addition to the one both models have. Once you upgrade cooling that difference goes away. It has been long since resolved that final drive ratios are identical.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
  2. #42
    Veteran Member Four Rings VroomVroom's Avatar
    Jan 03 2007
    SF Bay Area, CA
    ^ This.
    --Jerry || 2020 SQ7 Pr, GW/Black/BO (His); 2018 S5 Cab Pr, Daytona/Red (Hers)
    Suspension || H&R Springs - 29001-3; Bilstein B8 Dampers - 24-145985 (F) & 24-145992 (R)
    Wheels & Tires || BBS CI-R - CIR 0501 BPO, 20x10 ET25 Satin Black; Continental DWS06 275/40
    ...Formerly: '16 SQ5 '13 Q53.0T '12 Q5 3.2 '08&'06 A4 Avant 3.2.
  3. #43
    Jul 31 2017
    Brooklyn NY
    Final drive ratios the same? We know the engine/trans are identical but are the differentials identical (same part number)? And how do you check the front differential in a Quattro? You guys say this is resolved please post a link to where you resolved it and verified the differentials. It would only be 60 vs 62.5 or 2000 vs 2083 rpm so we're not talking about a huge change and I'm not sure you would see that driving the cars back to back, especially with different tires.
    We should be able to get actual identical differential part numbers for the two builds through Audi somewhere.
  4. #44
    Veteran Member Four Rings elijahallen's Avatar
    Nov 12 2006
    Michigan
    I have owned both and also the TDI version and the extra money is well spent on the SQ5. The Q5 is just dull in every way compared to the SQ5, sure you can make it as fast as the SQ5 but there is so much more that it would need to be comparable.
    2014 Porsche 911 turbo S, 2022 RS3 Uni DP, mid pipes, Racingline Piggyback(SOLD), 2018 RS3 Uni Stage 3 Iroz built motor(SOLD), 2017 Q7 APR stage 2 DP, 2016 Audi Q5 TDI Malone stage 2, 2013 Q5 3.0t DP stage 2(sold), 2016 SQ5 DP stage2 (SOLD) ,2014 Q5 tdi Stage 2(SOLD),2008 Porsche Cayenne S stock(SOLD),2011 B8 S4 DP stage 2+(SOLD),2001 B5 RS4 clone Built motor 600hp(SOLD),3 B5 S4 Avants Stage 3+(SOLD),95 S6 Avant RS2+(SOLD),94 S4 K27 built motor(SOLD),91 Coupe AAN RS2 Conv. Built motor.
  5. #45
    Veteran Member Four Rings Novarider's Avatar
    Jul 02 2017
    Knoxville TN
    Quote Originally Posted by elijahallen View Post
    Such as?
    2011 A4 Avant Prestige S-Line
  6. #46
    Nov 12 2006
    Michigan
    Quote Originally Posted by Novarider View Post
    Such as?
    What ever they did in the SQ5 to make it feel more like a car and not a truck. The SQ5 felt light and nimble compared to the Q5.
  7. #47
    Veteran Member Four Rings choppstixxx's Avatar
    Apr 24 2017
    2016 Audi Q5 3.0T Premium+/2003 Honda S2000
    Hilton, NY
    I mean the suspension is slightly different Q5 vs. SQ5, but not drastically different. Maybe the combination of the the extra power from the SQ5 made it seem "sportier"?
    That being said when you strip down the Q5 and SQ5, they share the same bones. We can all go back and forth about which one we prefer forever, but we all are part of this forum because we share the same platform and love driving/modding them.
    2020 Manganese Gray Metallic VW Arteon SEL Premium R-Line
    2003 Berlina Black Honda S2000
    2004 Crownline 202 LPX
    2016 Glacier White Metallic Q5 3.0T Premium+ S-Line 1 of 589 *RIP*
    2013 Moonlight Blue Metallic A4 Quattro Premium Flex Fuel 1 of 519 *RIP*
  8. #48
    Jul 02 2017
    Knoxville TN
    Are you comparing the tdi Q5 to the SQ5? We're taking about the 3.0t Q5.
  9. #49
    Apr 24 2017
    Hilton, NY
    He's owned the trifecta, TDI/3.0T/SQ5
  10. #50
    Jul 02 2017
    Knoxville TN
    Quote Originally Posted by choppstixxx View Post
    Wow.
  11. #51
    Feb 14 2017
    Gulfport, MS
    Quote Originally Posted by Silver_Bullet View Post
    We’ve done this over and over and posted results. We’ve posted speedo and gps reading at various rpm in 6th gear (direct 1:1 drive) and the rpm is the same for a given mph. I was a doubter initially. I thought the S-Line Q5 had a bit shorter gearing that the SQ5. I was wrong.
    If you want to dig out part numbers, have at it. Knock yourself out.
    Road and Track independently tested a 2015 SQ5. They reported a 3.08:1 final drive and published the gearing ratio in all eight gears, here:
    Apologies for poor cell cam photo, but the numbers should be readable.
    My S-Line has the same 3.08 diffs. I suspect any data reported by Audi to the contrary is simply a mistake. Believe me, I’d love the 3.2:1 gearing claimed by some, but I don’t.
    Edit: the R&T article shows fourth gear upshift as 108 mph at 6,400 for the SQ5. Most of us see that as 6,300 for the shift, but close enough for these purposes.
    Today, I had neither time nor space to get to 108 mph in 4th, but I took it half way to 54 mph. Guess what the rpm was? If you divide 6400 by 2 you get 3200.
  12. #52
    Mar 26 2007
    Colorado
    Welp,
    Not to get of tangent.... But I did the air box mod, throttle body hose, flapper delete, and now X pipe install is scheduled on Thursday..... (Might reconnect flappers after X pipe, not sure) .... Then finally will be tuning the car.
    Still loving the car. I gave it a full rubbing compound, polish compound and wax this weekend. Brought the exterior back to life.... Really love this car. Feels although suspension may be in the future next spring. (Only part of the car I can't find a service history on, so assume I am still on stock 66,000 miles now)
    *ALSO, has anyone had good luck blacking out their own front end grill? I can't stomach a $900-$1000 OEM black optics grill for something that is cosmetic
    CURRENT:
    2021 Atlas
  13. #53
    Jul 25 2009
    Bellevue, WA
    Not to belabor this, sorry, but I have a few more questions about the transmissions between the two.
    I remember reading the early tests when they were talking about the SQ5 development. And, I distinctly remember them talking about transmission programming. Now, I know we can tune the transmissions, but I have a couple simple questions:
    1) Are the transmissions between the 3.0T and the SQ5 the same actual part number? IIRC the Diesel has a different PN? Not sure about the SQ
    2) Would there be any way to verify that the programming for the transmissions is different?
    One of the things I love about the SQ, that is better than any recent automatic I've driven (Including Cayenne, Macan, Allroad, S4, etc) is how aggressively it downshifts and what a great job it does *not* automatically shifting to the highest gear possible. They appeared to not give a damn about gas mileage when they tuned this transmission and I love it.
    I have a hard time believing that the 3.0T is tuned the same way simply because it's a higher volume car and CAFE goes on overall average.
    Again, both are great, yadda yadda. But, it's more than just gear ratios.
    '16 SQ5 ROW/BilsteinB8 CH-R 9s; 997.2 spasm 6spd; '18 Macan S. Many, many audis in the past...
  14. #54
    Feb 14 2017
    Gulfport, MS
    Quote Originally Posted by scottst View Post
    I don’t know if the stock ZF8 TCU tunes are identical between the two in every detail on every one of the many different shift patterns. But they seem to be. Those of us playing with tuning them with HP Tuners software are not seeing any differences in the line pressures, clutch fill settings, shift points at various rpms in drive, sport or manual modes or in AMAX activation or stall speeds. There may be some, but I kinda doubt it based on the files we are exchanging.
    There are differences between model years, but those differences seem to be more in the way the file is displayed when we open it in the HP Tuners software. The later year versions do seem to have more variables for us to play with. One example is that earlier ZF8s have a different processor chip speed. AMAX launches have a max launch of 256 (but we can over ride it), while later ones can be set to an impossibly high of over 65,000 because of the faster chip.
    But, since I am only messing with upshift patterns and rpm shift point at very high throttle positions, only 70% and higher, and with AMAX operation, I’m only scratching the surface.
    I agree that the sport mode downshift patterns are more aggressive even in the S-Line Q5 than any other auto transmission I’ve ever seen. It’s so good on the downshift side, there is nothing I would want to modify. FWIW, having seen the TCU file for the ZF8 in an RS7, the downshift patterns seem very similar. That may explain why they are so aggressive in sport mode for us.
  15. #55
    Deactivated Four Rings
    Jun 23 2011
    The Q5 and SQ5 have different TCU box codes and files. We offer ZF TCU tunes for all of them.
  16. #56
    Jul 31 2017
    Brooklyn NY
    Oh MSq5 I like the work you do here and I was ready to believe you guys proved this out and then you posted this photo to compare to 108 MPH at 6,400. I couldn't help myself - so I pulled out a scale, blew up the photo, and estimated the numbers in your picture as 3250 RPM at 52.8 MPH. MPH at 6400: X = (6400/3250)*52.8 = 104 MPH. Ratio = 108/104 = 1.038 (3.8%). The gear ratio difference = 3.204/3.076 = 1.042 (4.2%).
    I'm not saying you are not right - maybe they are the same - but your photo is not making your case and would point to the opposite conclusion.
    Maybe actual data logs with speed/RPM through 6400 RPM for a Q5 and SQ5 would be pretty convincing (with tire info to correct discrepancies).
    Quote Originally Posted by MSq5 View Post
  17. #57
    Jul 25 2009
    Bellevue, WA
    Quote Originally Posted by Chris@EPL View Post
    Thanks Chris. Very useful insight!
  18. #58
    Feb 14 2017
    Gulfport, MS
    Data logs will be better. My speedo reads 1-2 mph slower than my gps, but tach seems spot on with logs, so hard log data would be better. Yes. Small differences in tire brands for a given stated size and variations in iinflation pressures can skew the calculation, as well.
    I may have a 4th gear log, but most were done in third.
  19. #59
    Dec 29 2018
    San Diego, CA
    The Q5 3.0T and SQ5 have the same final drive ratio (3.204:1).
    Reference: Audi Q5/SQ5 Quick Reference Specification Book, September 2013, Page 112: https://static.nhtsa.gov/odi/tsbs/20...21465-9999.pdf (Page 124 of the PDF)
