Results 1 to 25 of 25
    Jun 19 2018
    21 Jeep Gladiator / 05 Tahoe Z71
    NH
    2016 A6 MASSIVE Oil Leak after oil change
    The one time I don't do my own oil change! (not saying it wouldn't have happened this time if I did it)
    Inspection was due, so decided to have my local Indy shop also change my oil. A couple days later, I get the dreaded "low oil, add a quart" message - I have never had an issue with oil consumption, for the 69k miles on the clock. I knew this wasn't good... took it back to the shop immediately and they took a look. The amount of oil that was on the belly pan, leaking on the ground, and actually in places towards the front of my engine, was not a small amount. Accidents happen, so I wasn't too worried about it and knew the shop would take care of me. They diagnosed it as a faulty drain plug crush washer, which can certainly happen. So they replaced it. Car was driven 3 miles and sat overnight. Drove it the next morning and noticed a lot of oil under the car after I pulled away - I initially thought it was residual, still cleaning itself up (they did clean the engine bay and belly pan as good as possible) - then I took a look under the hood! It was insane to see how much oil was in the engine bay! Started the car up again and got the "Oil at the min. level, add immediately"... Rut Ro... we are talking probably close to 5-7 quarts of oil GONE in less than 10miles driving
    It's back at the shop, and they are diagnosing the problem. Now unsure if a bad crush washer or maybe a cross-threaded drain plug, would be leaking this much oil???? Quite a bit worried at this point, but they will get to the bottom of it.
    My question is - has anyone experienced a leak from a bad crush washer and/or cross-threaded drain plug? If so, how much oil tends to leak? Is it possible to leak so much (maybe under pressure somehow?) that is gets on the belly pan AND the front of the engine bay?
    Anyone else experience a massive oil leak before with this engine?? I have never heard of or seen anything like this with these engines!
    Veteran Member Three Rings Vinng86's Avatar
    Jul 20 2018
    Toronto, ON
    How bad is the engine bay? The oil drain plug is underneath the car, there shouldn't much oil all over the engine bay!
    Do you have any pics of the engine bay?
    2014 Audi A6 3.0T Technik(Prestige) S-line w/ Black Optics
    Sep 01 2016
    Sacramento, Ca
    Sorry to hear this, must be frustrating. Only thing I can help with- my brother in law had a similar experience with his Jetta years ago. He actually overfilled it, apparently the dealer told him vw designed his motor for some seal to blow to save the motor if it gets over filled. Sounds like you may have a different situation but just throwing it out there in case.
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    Wow. Sorry to hear. Any pics?
    FWIW even if a crush washer was split or drain plug cross-threaded it should still not leak that much.
    Missing the O-ring on the filter or cross-threading the filter cap maybe...
    Not good news, but back in the day my friend had an indy do his oil change on an old C5 3.0 (NA) and they did not tighten the filter on properly causing catastrophic engine failure when all the oil leaked out. Unfortunately it made my friend very averse to Audi as a brand since the mechanic was his friend and blamed Audi for the issue.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Jun 19 2018
    NH
    Quote Originally Posted by Vinng86 View Post
    I wish I took pics! I was a little heated and didn't think about it at the time. It did seem very odd that the drain plug (being underneath) would cause it... the majority of the oil is on the belly pan, and lower on the engine though. Oil is also getting onto the belts and the cooling fan, which I think is causing it to get over other areas of the engine bay - which is also why I thought with the amount of oil leaking, and the belts/fans being able to spread the oil around, it still may be the drain plug.
    The top of the engine is clean, same with around the sides where the valve covers are, so I dont think its the oil filter.
    Jun 19 2018
    NH
    Quote Originally Posted by jrp916 View Post
    Did his also have a massive leak? When being overfilled, it made all the oil come out?
    Established Member Two Rings Qwery718's Avatar
    Jun 01 2019
    Miami
    Why didn’t they suck out and fill the oil from the top? Isn’t that the way to do it for these cars?
    2013 A6 Prestige
    May 22 2017
    Wilmington, MA
    Quote Originally Posted by MattyMarkey View Post
    Oil on belts & fan *could* be a drain plug but it seems unlikely.
    One thing about the drain plug, it will leak when the engine is not running. That's not the case with many other leakage points.
    You say "valve covers" so I assume it's the 6-cylinder engine? The potential leakage spots are different between that and the 4-cylinder.
    Be alert! America needs more lerts.
    Eric Law
    '14 A6Q 3.0t prestige self-tuned
    '12 A4Q also self-tuned
    Jun 09 2017
    Signature
    GTA
    Right after an oil change and swapping out the drain plug gasket didn't do the trick, it's gotta be an incorrectly installed oil filter or a crack in the oil filter housing from over-tightening... That's my guess..
    Current Line-Up:
    2008 911 Turbo Cabriolet Manual
    2012 VW Golf R - APR in-house build Stage 4
    2002 Audi TT 225 Quattro Roadster - Big Turbo
    1995 Camaro Z28 6 Speed - Just Bolt-Ons
    Gone: 2015 Audi S6 - Stage 3 / 2015 Audi S4 - Stage 2 / 2012 Subaru Sti Hatch
    Apr 05 2005
    Casa Stg 3 S4
    evergreen state
    Quote Originally Posted by 15 Phantom S6 View Post
    I agree with this. Should be pretty easy for them to figure out. When I bought my used A6 the dealer did an oil change on it. They didn't install the filter properly and oil got everywhere. Added a new OEM filter and everything was good minus the mess the lost oil made.
    Past (in order): Hibiscus Red B5 A4 ,2003 Audi RS6, B6 s4, UrQuattro, Urs4, Nogaro sport B5 S4 avant, Silver stg 3 B5 s4, 2010 A6 Avant prestige
    Present: Casablance White stg 3 B5 S4 avant, 2002 Audi S6
    Mar 30 2018
    long island
    also agree to cracked filter housing or bad o ring seal.
    oil shouldn't be visible near the top of the engine with a drain plug seal issue. not to mention, its too fast of a leak.
    2017 RS7 | Daytona gray pearl | DS1 | Mike's downpipes (catted) | Milltek non-res exhaust | SRM intake | AK racing lowering module | VS forged VS16 wheels | JHM turbo filter relocation | Blackout badges | Color matched side reflectors | Cquartz ceramic coating | 20% tint |
    Sep 01 2016
    Sacramento, Ca
    He had a massive leak yes. Some seal around the heads blew out I think. Cost $2k at the dealer to fix the oil seal on a vw 5cyl.
    This does seem like it could be something with the oil filter housing, there is an upper (cap oring) and lower seal. They could have just forgot the cap o-ring :fingerscrossed:
    Jun 19 2018
    NH
    Quote Originally Posted by Eurotuned_A4 View Post
    When you say "oil was everywhere", was it in similar areas as I mention (Belly Pan, lower engine, fan shroud, belts)? With the filter being on the top of the engine, I would think oil would be all over the valve covers, coilpacks, and maybe even underside of the hood, which those are clean for me.
    Appreciate all the support and ideas, folks!!
    Jun 19 2018
    NH
    Oof
    Jun 19 2018
    NH
    Extremely curious and anxious to see what they find! Waiting for the call...
    May 22 2017
    Wilmington, MA
    If oil was spraying out, yes. If it was seeping, it could easily run straight downward and bypass those things. Oil is very clever, and will actively try to prevent you from finding out where it is leaking.
    Again, knowing which engine would help. If the 4-cylinder is the same as in my A4, the oil filter is in the front and oil leaking from it could easily end up on the belts etc. on the front of the engine. That would be much less likely with the 6-cylinder engine which has the oil filter in the rear.
    Eric Law
    Aug 21 2015
    2018 SQ5, 2010 Q5 3.2
    Naperville, IL
    I would check the oil filter housing and related gaskets/o-rings. It's possible it cracked from overtightenting, missing/improperly installed o-rings, or cross threaded.
    My guess is the crush washer was not replaced either, just reused.
    Keep us posted.
    Sent from my SM-N950U using Tapatalk
    Mar 26 2010
    US
    Quote Originally Posted by robd88 View Post
    I would check the oil filter housing and related gaskets/o-rings. It's possible it cracked from overtightenting, missing/improperly installed o-rings, or cross threaded....
    +1,
    I carefully use a torque wrench on the oil filter sealing cap.
    Torque value is 25 NM (18.6 Ft-Lbs) for 4.0 TFSI, 3.0 TFSI & 2.0T TDI.
    Torque value is 22 NM for 2.0 TFSI.
    Oddly, Torque value is 35 NM for 3.0 TDI
    BMW M3 Competition X-drive
    Jun 19 2018
    NH
    Quote Originally Posted by ELaw View Post
    My bad. With the oil filter being on the top, rear of the engine, it is in fact the 3.0T. The majority of the oil is in the belly pan and lower part of the engine - to me, it looked like the oil on the front of the engine, belts, fan shroud was due to it "spraying" or being carried to those points somehow.
    May 22 2017
    Wilmington, MA
    Well that's weird... on the 3.0 you'd think the oil would just run down the back of the engine if there were a leak at the filter.
    If I can toss out one more data point, re the drain plug washer... when I change the oil on my cars, 90% of the time I reuse the washer. I've had a few leaks from doing that, but the worst amounted to maybe a drop a week... hardly an Exxon Valdez-level loss. If your engine is leaking at the plug, I'd say more likely the washer was omitted, or the plug was cross-threaded so it didn't seat squarely.
    I think the 3.0t also has an oil cooler at the front of the engine (low down on the driver's side), it's possible you've got a leak there.
    Edit: I found a photo of the cooler, it's the light-colored thing at the top center of this photo:
    In the car, it's just forward of the oil drain plug.
    Eric Law
    Jun 06 2016
    Florida
    The shop may not admit it, but I’d put my money on a crush washer / oil filter/ oil filter gasket issue.
    I’ve seen cases where the rubber gasket on the old oil filter comes off and gets stuck to the engine block. It’s not something you typically look for and easy to install the new oil filter on top of.
    2018 Daytona Gray S6 | S Sport | Black Optic | Carbon Atlas |
    2011 Phantom Black S4 | S-Tronic | P+ | Nav | Sports Differential | Titanium Package | Silk Nappa | SOLD
    Jun 19 2018
    NH
    For those of you who called an oil filter housing/gasket issue; well done!
    Spoke to the shop late yesterday - they found that the filter housing gasket, that is replaced with each filter change, had a tare/failure. The oil was traveling down the valley pan (under the SC), which was the culprit of oil on the belts/front of the engine. The shop is taking full responsibility and handling the situation by treating me (and my car) well. Because of the "min oil level - fill immediately" warning message, they did measure the amount of remaining oil in the engine - turned out 5qts came out. Does seem odd, knowing the warning message, and the amount of oil on the ground, belly pan and in the engine bay... but my perception of amounts of liquid could be off. The car never overheated, and with the amount of oil left in the engine, hopefully no damage was done (fingers crossed)
    The shop is being extra diligent this time. Still amazed a tare/failure in the o-ring could cause that size of an oil leak!! Though it is under pressure at the filter housing...
    May 22 2017
    Wilmington, MA
    Glad to hear they figured it out!
    Eric Law
    Aug 21 2015
    Naperville, IL
    Gotta lube those o-rings prior to installing the filter cap or they might roll or tear.
    Glad it was nothing major.
    Dec 08 2021
    Houston Texas
    Took my 2015 Audi A3 to the Dealership where I always go in September for an oil change.. I noticed last Friday on Dec 3rd a bunch of oil in the garage.. I took my car back up the the Audi Dealership and of course they're not responsible.. They said I need a Oil Pan Replacement and a Timing Chain Cover.. Thats where the leaks are coming from..
    I'm sitting on only 58000 miles and this is NOT a daily driver..
    Pissed
