Results 1 to 20 of 20
    Veteran Member Four Rings 01northernS4's Avatar
    Oct 18 2006
    Audiville
    Going to add water wetter/purple ice... a few quick questions>>>
    1. Can I just drain the stock combined audi antifreeze reservoir (blue cap) in the engine and top up with a bottle of water wetter/purple ice, will it mix properly eventually, if not what is recommended?
    2. What is better, water wetter or purple ice, does it matter?
    3. How many bottles should I add, is draining the reservoir and filling with water wetter/purple ice enough?
    4. Can I actually notice a reduction of up to approx. 14C/22F in fluid temps they advertise? I'm guessing nothing near that but what have you all seen generally, 5c/10F? It all helps in the end...
    BTW, I have stock audi mix 50/50 antifreeze/distilled water.
    2015 Audi S5 Technik
    Mythos Black Optics | DSG | Sport Diff | H&R OE Springs & 10F/15R Spacers | CR-15 | 20"x9" Black Matte Rotors | Akebono Brake Pads
    Unitronic DP 3.2 Ratio | Merc Racing Hx | Milltek Resonated Cat Back Exhaust W/Black Cerakote GT100's | Modded Airbox w\AWE Intake Tube & AFE Dry Cone Filter
    Veteran Member Four Rings Audi 4 Life's Avatar
    Jan 16 2011
    06 D3 A8 Black/peanut with alcantara
    Earth
    My tech uses Redline water water, not the purple your talking about it does help I doubt as much as advertised.
    I suggest just adding a bottle of the regular pink water wetter since our coolant is pink imo works well with Audi coolant system.
    Sent from my SM-G960U using Tapatalk
    RIP - JHM B6 3.0 6MTQ USP Denim Blue/Black w/ Nappa Silver
    Current- B8 A4 2.0t S-Line Stasis Challenge Extreme Edition, Alcantara Headliner, ALA/ACC and 3g+ swap
    D3 A8 4.2 Black/Peanut (Daily)
    Oct 18 2006
    Audiville
    Also just read royal purple may mix better with our antifreeze... but apparently most of the benefits come from just mixing with water...
    Will I see any benefit from mixing with our stock 50/50 antifreeze/water?
    Thanks again
    Veteran Member Four Rings theweebabyseamus's Avatar
    May 12 2008
    There were some issues with Water Wetter gunking when mixed with AF on some older platforms so I went with Purple Ice as its a newer product (straight water/Purple Ice for my s/c loop). However, plenty use Water Wetter when running lower AF ratios and it seems to be ok.
    I don't know whether I'd add it to a 50/50 mix as I doubt it'll make much of a difference but to each their own.
    Oct 18 2006
    Audiville
    Got it... so if I were to add it, I could do so by emptying the reservoir and topping up with a bottle of the preferred royal purple ice and it should mix itself with the rest of the coolant/water in the system
    Has anybody else added it to a 50/50 stock coolant mix? At 10 bucks not a big waste if it doesn't work...
    Thanks everyone!
    Quote Originally Posted by theweebabyseamus View Post
    May 12 2008
    No it’s a lot less than a full bottle, but yeah you would just pull some coolant and add the appropriate amount of Purple Ice and it will mix.
    Oct 18 2006
    Audiville
    thank you sir!
    So has anybody else added purple ice/water wetter to a 50/50 stock af coolant water mix and seen any measurable benefits?
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    This. Just siphon off some coolant mix from the reservoir and add the Water Wetter or Purple Ice. There were some problems with earlier versions of Water Wetter and some Audi coolants. That's all in the rear view mirror, now. Both products are compatible with current coolants. I run Purple Ice, but the two products are basically interchangeable.
    One thing: Run as much water as you can. Water is far better than coolant in heat transfer. And the more water the better the water wetter product works (either brand). If you can go 70/30 in favor of water and add the water wetter, then that would be better. 70/30 will protect you to 0 degrees F. 80/20 gets you to +20 F. Unless it gets colder where you are, use as much water as possible.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    May 12 2008
    Quote Originally Posted by MSq5 View Post
    I don't think hes divorced lol
    Oct 18 2006
    Audiville
    Wow, that's great info MSq5... thank you... I'm in southern Ontario and we can see -20 to -30C in the winter but I do park in a heated garage... where did you find the references on mix ratio and temps? I may do 60/40... will have to figure it out but hopefully emptying the reservoir and filling it with distilled and half a bottle of royal purple ice are the right ratios... just need to figure out the capacity of the cooling system and the reservoir.
    Not divorced but I think a 60/40 will work across the board for me better than stock ratios... I should still see improvements despite not being divorced on a 60/40 mix with royal purple ice?
    Senior Member Three Rings KLX's Avatar
    Jan 28 2018
    Shaw AFB SC
    Quote Originally Posted by 01northernS4 View Post
    Thanks again
    +1
    2021 S5 Premmie SB 034 intake & springs/034 Stage 1
    2018 S5 Prestige SB Sold
    2015 S4 B8.5 APR Stg2 DP Sold
    @businessklazz on Instagram
    Feb 14 2017
    Gulfport, MS
    I’m not either.
    - - - Updated - - -
    Yes.
    Oct 18 2006
    Audiville
    Good morning everyone!
    So a few points:
    1. Tested my antifreeze/coolant mix and it's registering off the meter at a freezing point over -45F/-43C and boiling point over 269F/131C... this tells me my mix should be over 50/50 water to coolant... maybe 40/60?
    2. As I read the instructions on the royal purple ice bottle it says 1 to 2 oz per quart of coolant/antifreeze mix... our system should hold 12 liters/quarts... it seems I need the whole bottle?
    3. Royal Purple Ice bottle says to change every year/30k miles... seems excessive no?
    So my plan is to drain the reservoir and top up with a full bottle of royal purple ice and distilled water... drive around a few days to give the fluids time to mix and retest hoping to get to 50/50 or 60/40 water to coolant ratio. This should yield somewhat better cooling.
    For those that have done this are you using a full bottle of royal purple ice on our coolant systems (approx. 12 quarts/liter capacity) for the right ratio?
    One last question - by draining the reservoir, topping up with distilled and royal purple ice and driving around a few days will my coolant system mix completely so I can retest? I really don't want to flush it all if I don't need to until I get my new heat exchanger.
    Oct 18 2006
    Audiville
    Anyone?
    For those of you who have used royal purple ice/water wetter does 1 full bottle to the entire cooling system sound about right?
    I just want to get the ratios right.
    Thanks again.
    May 12 2008
    Yeah if our system really is 12 quarts I would do the whole bottle. 2 oz to quarts is for straight water.
    Feb 14 2017
    Gulfport, MS
    Just a few thoughts. No expert by any means. Here is what I concluded based on other threads here, the manufacturer's recommendations, and my admittedly recent use of Purple Ice:
    1. For the surfactant (Water Wetter or Purple Ice), your water to air ration must be at least 50% water. If your water is only 40%, you need to drain some coolant and replace with distilled water or tap water if your tap water is soft, then add the Purple Ice.
    2. I run Purple Ice in a 70/30 water to coolant mix and I just add it to the reservoir.
    3. It does wear out over time. The active wetting agent and the anti-corrosion agent have a life of about 30,000 miles. Just repeat the process by draining enough coolant to add another 12 ounce bottle. It does not hurt anything to add more, but adding more does not improve cooling unless the existing Purple Ice is over 30,000 miles.
    4. Yes, one 12 ounce bottle should be sufficient for our cooling system volume, even with a larger heat exchanger.. More does not hurt, but offers no increased benefit. The Kenne Bell supercharger folks have a lot to say on the subject and found that with their their blowers on GM V8s, the Lucas version of water wetter dropped IATs by 6 degrees and raised power by 7 whp during dyno pulls.
    Oct 18 2006
    Audiville
    Just confirmed with Royal Purple help line our system is 12 quarts/liters so 1 full bottle for a 50/50 mix and 2 full bottles for straight water. He said even at 50/50 ratio should see 5 to 10F approx. reduction in temps... won't hurt to try.
    He also said the royal purple ice looses it's efficacy so it must be added yearly or every 30k miles.
    Thanks weebabyseamus
    Oct 18 2006
    Audiville
    4. Yes, one 12 ounce bottle should be sufficient. More does not hurt, but offers no increased benefit. The Kenne Bell supercharger folks have a lot to say on the subject and found that with their their blowers on GM V8s, Purple Ice dropped IATs by 8 degrees and raised power by 8 whp during dyno pulls.
    lol we replied at about the same time... Excellent info right here and big thanks MSq5 for your response... you're right on the money!
    Feb 14 2017
    Gulfport, MS
    Yes. I did revise the post after looking at the Kenne Bell video again. IATs went down 6 degrees and hp went up 7. That was with two bottles of the Lucas version, but they all work the same way. I don't know the coolant capacity on the GM V8 they tested, though.
    Mar 05 2016
    Did anybody tested the IAT before and after using Purple Ice or Water Wetter?
    Also I live is Canada, winter can be -40 degree celsius, will that be a problem using Water Wetter or Purple Ice with 50/50 mix?
    Audi 2013 S-Tronic | REVO Stage 1+| REVO TCU tune| MercRacing Heat Exchanger | AFe intake | ECS cross drilled slotted rotors | Hawks HPS 5.0| Vibrant 90mm double wall Stainless steel tips | Resonated Xpipe
