Originally Posted by
Hayk
Hello!
I just bought a 2017 SQ5 with stock 20 inch wheels and am not a fan of the wheels on the car. I'm pretty new to mods (even wheels) and was hoping to clarify a few questions.
How do 21/22 inch wheels affect the ride quality, handling, price of tires etc. I'm not interested in lowering the suspension at all but am a bit interested in a larger wheel look, but not if it compromises ride quality or results in super expensive tires.
Does anyone have experience buying aftermarket OEM wheels off eBay? The pair I'm looking at is linked below.
Thank you in advance!!
https://rover.ebay.com/rover/0/0/0?m...2F202751239082
Sent from my SM-G973U1 using Tapatalk
For some reason my iPad will not open your link. But, I came here to suggest that you stay with 20 rims.
I have the 20 summer tire package on my 17 S-Line, probably the same rims as yours. While I like them, if I did not, Id still stick with 20s with replacement rims.
21s have fewer choices for tires, they are more expensive, and with the lower aspect ratio, the sidewalls will be less, stiffer, and ride quality worse. 22s even more so. And a 21 rim will be heavier than the same rim in a 20. Metal is heavier than rubber, too so your unsprung weight, important to handling, will be worse with a 21 compared to the same rim and tire combo in a 20.
Its your car, get what you like, but you are right when you have concerns about larger rims.
