Results 1 to 8 of 8
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    2012 Audi A7 fault codes with VCDS scan info
    So i have been having the check engine light coming on this week. I read the codes out earlier in the week and cleared them just to make certain it was not a fluke because despite the codes the car is still running very strong and still gets 28 - 30 MPG on the highway. Recently I ran some fuel with Tech Ron (or however it is spelled) through the engine and just filled with 93 octane as well.
    I cleared the codes and then started up the car this last time and the check engine light was out but after scanning again the speed sensor faults were back but not tripping the light.
    BUT . . . the codes persist. Here is a stripped down version of the log ( I removed all the no fault)
    I am really only worried about the engine codes. The others are seem to be just nuisance codes.
    ANY AND ALL HELP WOULD BE MUCH APPRECIATED.
    Saturday,10,August,2019,18:38:11:40639
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
    Data version: 20190529 DS308.0
    www.Ross-Tech.com
    VIN:
    Mileage: 289787km-180065mi Repair Order:
    Chassis Type: FC-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3B 42 44 46 47 52 53
    55 56 5F 62 6C 6D 72 8F 90
    VIN: Mileage: 289787km-180065miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    28-HVAC, Rear -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    3B-Sensor Elect. -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    6C-Back-up Cam. -- Status: OK 0000
    6D-Trunk Elect. -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    8F-Pretens. Frt Left -- Status: OK 0000
    90-Pretens. Frt Right -- Status: OK 0000
    Address 01: Engine (J623-CGXB) Labels:. 06E-907-551-CGW.clb
    Part No SW: 4G0 907 551 A HW: 4G0 907 551 A
    Component: 3.0l V6 TFSI H07 0006
    Revision: --H07---
    Coding: 1A2A0034052600060000
    Shop #: WSC 02391 785 00200
    ASAM Dataset: EV_ECM30TFS0214G0907551A 002007
    ROD: EV_ECM30TFS0214G0907551A_002.rod
    VCID: 270BF86CDF64FFCFAB3-8072
    3 Faults Found:
    6237 - Fuel Rail/System Pressure
    P0087 00 [104] - Too Low
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 3
    Mileage: 289444 km
    Date: 2019.08.08
    Time: 15:48:30
    Engine speed: 1626.00 /min
    Normed load value: 80.8 %
    Vehicle speed: 84 km/h
    Coolant temperature: 96 °C
    Intake air temperature: 38 °C
    Ambient air pressure: 980 mbar
    Voltage terminal 30: 13.812 V
    Unlearning counter according OBD: 40
    Engine speed: actual: 1920 /min
    MAF_ENVD: 610.07057 mg/stroke
    Coolant temperature (unfiltered): 88.50 °C
    FUEL_MASS_REQ_I_CTL_ENVD: 36.117188
    FUP_ENVD: 74718.4735 hPa
    FUP_EFP_ENVD: 4773.4 hPa
    10964 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
    P0016 00 [237] - Incorrect Correlation
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 10
    Mileage: 289338 km
    Date: 2019.08.07
    Time: 20:10:33
    Engine speed: 894.00 /min
    Normed load value: 7.8 %
    Vehicle speed: 0 km/h
    Coolant temperature: 72 °C
    Intake air temperature: 73 °C
    Voltage terminal 30: 11.577 V
    Engine speed: actual: 1184 /min
    MAF_ENVD: 92.60000 mg/stroke
    Coolant temperature (unfiltered): 90.00 °C
    Engine: operating status: IS
    ENVD_CAM_IN_1: 16
    Vehicle speed: actual: 0 km/h
    10965 - Bank 2: CMP Sens 2 (G163) / Engine Speed Sensor (G28)
    P0018 00 [237] - Incorrect Correlation
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 10
    Mileage: 289338 km
    Date: 2019.08.07
    Time: 20:10:34
    Engine speed: 1014.00 /min
    Normed load value: 4.7 %
    Coolant temperature: 44 °C
    Intake air temperature: 44 °C
    Voltage terminal 30: 11.780 V
    Engine speed: actual: 1152 /min
    MAF_ENVD: 87.15294 mg/stroke
    ENVD_CAM_IN_2: 16
    Readiness: 1000 1000
    Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
    Part No SW: 4H0 907 063 BP HW: 4H0 907 063
    Component: BCM1 2.0 H12 0111
    Revision: 11012002 Serial number: 00000001372385
    Coding: 0D072091073E9FE081000884A0003820CF9CD208A209012580 0308453B00
    VCID: 77ABE82C4FC4AF4FFB3-8022
    Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
    Component: WWS57X 111222 H35 0051
    Serial number: 120109192801
    Coding: 0045F7
    Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
    Component: RLS H04 0003
    Serial number: 20034691
    Coding: 02562B
    Subsystem 3 - Part No SW: 4G0 941 531 E HW: 4G0 941 531 E
    Component: E1 - LDS H07 0044
    Serial number: 19 01 2012 00000367
    Subsystem 4 - Part No SW: 8K0 959 772 E HW: 8K0 959 772
    Component: SLR-B8 H06 0007
    Serial number: 0020375367
    Coding: 853000
    Subsystem 5 - Part No SW: 4G0 907 472 HW: 4G0 907 472
    Component: A31 LED Mod1L H02 0001
    Serial number: 00000000001112163604
    Subsystem 6 - Part No SW: 4G0 907 472 HW: 4G0 907 472
    Component: A27 LED Mod1R H02 0001
    Serial number: 00000000001112163455
    Subsystem 7 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
    Component: EVLS-SG H08 0300
    Serial number: WA103663000000864100
    Coding: 020300
    Subsystem 8 - Part No SW: 4H0 907 658 HW: 4H0 907 658
    Component: AQ_Hum_Sensor H02 0002
    Serial number: 9328C906000000000001
    Subsystem 9 - Part No SW: 4G0 907 472 A HW: 4G0 907 472 A
    Component: A32 LED Mod2L H02 0001
    Serial number: 00000000001112170044
    Subsystem 10 - Part No SW: 4G0 907 472 A HW: 4G0 907 472 A
    Component: A28 LED Mod2R H02 0001
    Serial number: 00000000001112122170
    1 Fault Found:
    02258 - Door Opener Transmitter
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 234
    Mileage: 289338 km
    Time Indication: 0
    Date: 2019.08.08
    Time: 05:56:00
    Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
    Part No SW: 4H0 907 064 BR HW: 4H0 907 064 BR
    Component: BCM2 2.0 H31 0333
    Revision: 00002001 Serial number: 0168294233
    Coding: 0126023A20FAF40580B00A8002010000000000000000000000 0000000000
    VCID: 7AADF1187CD6B22784D-802E
    Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
    Component: GTO BF H01 0080
    Serial number: 00000000000000066697
    Subsystem 2 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H05 1501
    Subsystem 3 - Part No SW: 4G8 959 591 HW: 7P0 959 591 C
    Component: J245 PS40.039 H01 0008
    Serial number: WOO14525742
    Coding: 101F00
    Subsystem 4 - Part No SW: 4G0 947 135 G HW: 4G0 947 135
    Component: Dachelektroni H10 0100
    Serial number: 0000000AP00000765836
    Coding: 010000
    Subsystem 5 - Part No SW: 4G8 959 252 HW: 4G8 959 252
    Component: HSP-SG H09 0028
    Serial number: WA102657000000823337
    1 Fault Found:
    03637 - Roof Electronics Control Module; Function Limitation due to Overtemp
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 18
    Mileage: 289437 km
    Time Indication: 0
    Date: 2019.08.08
    Time: 15:34:37
    Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
    Part No SW: 4G0 035 746 C HW: 4G0 035 746
    Component: H-BNT-NA H48 0423
    Revision: -------- Serial number: 031AT0C7526268
    Coding: 090200040003E1EF45128B1E00000003100001000000000000
    Shop #: WSC 25807 444 183057
    VCID: 270BF86CDFE4FFCFAB3-8072
    Subsystem 1 - Part No: 8R0 060 884 AD
    Component: NAR 2011 0505
    Subsystem 2 - Part No SW: 4G0 919 605 B HW: 4G0 919 605 B
    Component: DU8 C7 SV H42 0021
    Serial number: AUZ8ZDB9400HB1C
    Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 610 C
    Component: E380 BDT C7 H11 0204
    Serial number: 90349LAI00017
    Subsystem 4 - Part No: 8R0 060 961 B
    Component: CD-Database 3371
    1 Fault Found:
    03157 - Functionality limited due to Communications Disruption
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 19
    Mileage: 289771 km
    Time Indication: 0
    Date: 2019.08.09
    Time: 19:57:35
    Freeze Frame:
    Bin. Bits: 00000000 00000000
    Bin. Bits: 00000000 00010000
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    P0087 Fuel Rail/System Pressure- Too Low
    Fuel Rail Control Valve functional check: Stuck open
    -rail pressure <0.80 [MPa] {In your case appears to be .47734 MPa}
    *Check fuel pressure
    *Check the Fuel Metering Valve - N290
    The Engine Control Module (ECM) - J623- regulates Fuel Metering Valve - N290- directly at the High Pressure Fuel Pump to control the low pressure flow inside the High Pressure Fuel Pump.
    ---To check---
    • Fuses OK.
    • Battery voltage OK
    • Switch OFF All and electronic accessories
    • Vehicles with Auto. Transmission, ensure Selector Lever position is in “P”.
    • Vehicles with Manual Transmission, ensure Shifter Lever position is in “N” with Parking Brake applied.
    • Coolant Temperature: ≥ 20 °C.
    Check#1
    IGNITION: OFF
    • DISCONNECT: Fuel Metering Valve - N290- connector
    • CHECK: Fuel Metering Valve - N290- component connector terminals 1 to 2 for resistance.
    • SPECIFIED VALUE: 1.5 to 11 Ω (± / 0.5 Ω @ approx. 20° C)
    ---If no good REPLACE: Fuel Metering Valve - N290-
    Check#2
    IGNITION: ON
    • CHECK: Fuel Metering Valve - N290- connector terminal 1 to ground.
    • SPECIFIED VALUE: Battery voltage
    • IGNITION: OFF
    If no good CHECK/Repair: wiring for open, high resistance, short or connector for damage, corrosion, loose or broken terminals
    The Fuel Metering Valve - N290 is on the high pressure fuel pump, so be careful and follow de-pressurizing procedures if you plan to replace it yourself.
    If the sensor is ok then one of the pumps might be going.
    The other two codes are related to Crankshaft/Camshaft position sensors.
    P0016 Crankshaft Position-Camshaft Position Correlation Bank 1 Sensor A (G40)
    P0018 Crankshaft Position-Camshaft Position Correlation Bank 2 Sensor A (G163)
    Using the signal from the Camshaft Position Sensor - G40- , the precise position of the camshaft relative to the crankshaft is determined very quickly when the engine is started. Used in combination with the signal from the Engine Speed Sensor - G28- , the signal from the Camshaft Position Sensor - G40- allow to detect which cylinder is at TDC. The fuel can be injected into the corresponding cylinder and ignited.
    ---To check---
    • Fuses OK.
    • Coolant Temperature: ≥ 80 °
    Check G40 or G163 sensor
    • DISCONNECT: Camshaft Position Sensor - G40 or G163- connector
    • IGNITION: ON
    • CHECK: Camshaft Position Sensor - G40 or G163- connector terminals 1 to 3 for voltage
    • SPECIFIED VALUE: About 5.0 V
    • IGNITION: OFF.
    I've deliberately left out the check where they mention to remove the ECM as I doubt anyone will do that...
    Both sensors appear to be in the left side of the engine as you face it one on the cam end the other on the connection out to the cam near the fuel metering valve N290.
    So I'm thinking something is wrong with the wiring in that area...
    Hopefully that helps you track do the issue.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Nov 27 2018
    Valparaiso, IN
    Thank you. Could a battery going bad cause any of this? I have read other posts that others pointed to the battery throwing random codes. I am second owner of the car and it very well might be the original battery.
    Aug 06 2014
    NJ->CO
    Anything could be possible...Why not take a look at it and see if there is any date code on it. If it's original replace it and go from there.
    Just strange those three items are in close proximity to each other...was any other work done in that area?
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Nov 27 2018
    Valparaiso, IN
    No work at all. I last changed oil at 173,000 miles. I bought the car with 142,000 on it and the only work I have done on it is oil changes and front brakes
    Nov 27 2018
    Valparaiso, IN
    I have looked all over the battery short of removing it from the car and I can find no date code at all on it. Makes me wonder if its original and now has 7+ years on it and 180,000 miles.
    The only thing I can find on it is
    4G0 915 105 E
    12V 520A 110Ah DIN
    Nov 27 2018
    Valparaiso, IN
    Update on the car.
    I found a few sensors around the engine bay that were not completely clipped. They were pushed on but the keeper was not clicked down. I reseated the fuel rail sensor and I found 1 of the CMPs that was not clipped in as well. The cam sensor at the front of the engine on the driver side. I removed the sensor to see its condition and all seemed okay so I cleaned it off and re-installed it.
    So for now the only Module 01 code returning is:
    I called the dealer to see if the previous owner had ever replaced the battery and discovered that it has not been replaced. Somehow my original battery is 7+ years old with 180,000 miles on the car. Before I replace it I am gonna read up on how to test the battery with VCDS. Dealer quoted me $263 for the OEM battery and another $250 in labor to install and code.
    Now from my reading it seems that there are more than 1 CMP Sensors on the car but my old eyes can't find any sensors other than the 1 at the front driver side so far.
    Would someone please educate my stupid arse on where the bank 1 sensor is. Since it cleared I am assuming that the front driver side is bank 2 sensor.
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by Valpo A7 View Post
    Update on the car.
    Hmmm. the clips shouldn't just sporadically come undone like that. It sounds as if the original owner may have had some work done.
    At 7 years and 180k miles I wouldn't even bother testing the battery. Just replace it...it will die and at the worst possible time for you according to Murphy.
    Since I was just researching some battery stuff I know it is possible to get OE batteries down to about $200 so it can't hurt to ask for a discount.
    In your case they are actually asking over MSRP of $223 (new p/n is 000915105DL) online sources have it for $190 but no shipping, and then of course their obscene labor charge to code it. (Seeing as you have VCDS...you can code it yourself.) Or you can look for a Pep Boys sale and buy a Bosch that fits and save even more. (Be sure to fully charge the new battery before installing...and as usual be careful yada yada yada.)
    The nice top tier Bosch Platinum AGM is on sale right now for $146 assume you currently have an AGM battery in the car.
    As for the sensor G40 it should be on the passenger's side sticking out of the round camshaft adjuster just at the front of the head/valve cover.
    Ignore the yellow marker in this picture (borrowed) the G40 should be right there on the lower left of the picture. Just left of the supercharger pulley you can see the three wires coming out of the connector.
    Perf, Leather, Exec
    2015 S6 Quartz Gray
