Results 1 to 14 of 14
    Established Member Two Rings Audi TTRS's Avatar
    Jan 17 2019
    Why no rolling anti lag?
    Is it possible to get anti lag/rolling launch using these steps? What's the downside?
    1. Establish desired mph
    2. Pull and hold cruise control stalk to maintain speed
    3. Press gas pedal to the floor
    4. Release cruise control stalk at designated boost level.
    Is it very difficult to program this without using syvecs?
    2018 TTRS stock
    Established Member Two Rings Ricky Ricer's Avatar
    Apr 16 2015
    Lakewood
    I agree, I loved that feature in my GTR. Launch @ 60 with 1G of acceleration. It was brutal
    -Rick
    Audi Denver/MAG
    Veteran Member Three Rings MichiganRS3's Avatar
    Apr 30 2015
    Michigan
    Should be similarly achievable by getting a tune that enables left foot braking?
    Accelerate to desired speed
    Right foot gas to floor left foot brake to maintain speed
    Let off brake
    Should work?
    `18 Mystic Blue Pearl Effect RS3
    10.6 @ 129mph / 2.82s - 0-60 - Stage 2 e85
    Aug 04 2018
    2017 Audi Q7, 2022 Silverado 2500HD
    Sacramento, CA
    Unitronic tunes allow for it!
    2018 Nardo Blk Optic RS-3, DA, RS Design, Dynamic Package
    UNI Stg 1+ (E85) ECU, Stg 2 TCU, UNI 3"Turbo Inlet, IE Intake, 034 St.Stl Intake HTshld, Eurocode FMIC, IROZ Eng Oil Catchcan, 3D Prntd DSG Vent, OEM Euro Catless MidPI, CTE Exhst Valve Cont., 034 Upr/Lwr DgBne Insrts/Billet Arm, MSS Springs Fnt Track/Rear Sport, Eurocode SWB E.Links/Rear Strut Brc, 034 Rear SbFrm Mnt Insrts, ECS Rear Diff Mnt Insrts, Signature SV303S/Gloss Blk Barrels/Flat Blk Spokes/Slvr Hdwr, F 19x9.5+41, R 19x9.0+43
    Jan 17 2019
    Quote Originally Posted by MichiganRS3 View Post
    Let off brake
    Should work?
    No, it does not deliver the same results. Using left foot braking is really inconsistent, at least for me it is. Also, incredibly difficult to hold the correct mph without creeping forward.
    2018 TTRS, APR intake/inlet, IE catted DP, APR intercooler. E85
    Jan 17 2019
    Quote Originally Posted by NelsDMAX View Post
    Really? Are you referring to left foot braking or the cruise control stalk launch?
    Active Member Three Rings SlowSedans's Avatar
    Oct 27 2018
    R8, RS4, RS3, S4 x 5
    Tahoe
    Left foot braking is allowed even in stock form, here is the deal, you cant be on gas and then push brakes. It will cut.
    You must be on gas, get to just over desired range, lift gas entirely, engage brakes slightly and then depress accelerator again. You can brake boost the f*>k out of these cars, even stock. On stock turbo I rarely bother, it's very responsive as we all know.
    Rolling anti lag is 100% programmable by most tuners. It's also very hard on turbine wheels so I think most wont or dont offer it. I have it, its set to 14 psi, -23 degrees, 20/30/40/60mph holds and basically never use it.
    On a side note, some tunes and even versions of the stock programming had a bug, it's actually been discussed even here at length, it was almost like an unpredictable rolling anti lag lol. I accidentally found it myself at one point.
    The stock ecu is extremely flexible if you are okay with changing code and not just calibrating maps, even with just mapping, the ecu can do a lot. The stock launch control for instance is fully adjustable in regards to afr, timing, boost PID, etc. Same with engine aggressiveness during shifts and boost hold.
    Nov 18 2017
    Melbourne/Victoria/Australia
    Quote Originally Posted by Audi TTRS View Post
    What is cruise control stalk launch?
    Jan 17 2019
    Quote Originally Posted by cavebob View Post
    Just using the cruise control lever to maintain speed while the gas is fully depressed. I dont think it exist for this platform but that's what I would really like to see developed.
    Jan 17 2019
    Quote Originally Posted by SlowSedans View Post
    I figured it out a while ago too, I just wanted something a bit more consistent. I cant really get a clean run using this method. Sometimes lots of boost, sometimes not so much.
    Veteran Member Three Rings old_spool's Avatar
    Aug 01 2005
    Irvine, CA
    Just picked up my Syvecs setup and the anti-lag is ridiculous. As my B5 S4 buddy put it..."worth the price of admission".
    2002 S4 Nogaro Blue Avant 6MT Stage 3 K04 E85 GIAC X-Treme.
    2019 RS3 Ara Blue - IMS850s, Built Motor, Syvecs, IE Intake, Malaka Inlet/Hoses
    Junior Member Two Rings EyeCon's Avatar
    Feb 10 2012
    2021 SQ8 / 2018 RS3
    Washington State
    Totally agree, it is indeed :)
    2018 RS3 Built IMS 850 / Syvecs / Essex AP Racing / JRI Coilovers
    2012 Special Edition S5 | APR Stage III | AWE Touring Exhaust
    Jan 17 2019
    Quote Originally Posted by old_spool View Post
    I'm switching over to a hybrid very soon, what's the cost of the syvecs system? Do you know of any shops in So Cal that can do it? I'm seriously interested in antilag.
    Aug 01 2005
    Irvine, CA
    The Syvecs unit by itself is around $5200 and the installation/programming is $2,500 (2 years of support) through Iroz in Las Vegas.
    If you haven't seen the video they made with my car yet, there's some good info on it. They talk about the flex fuel element more than the anti-lag but still good info.
    https://youtu.be/mrcXwZJGt-c
    If you want to come down to Tustin I can give you an anti-lag experience. We are meeting in Tustin this Thursday pm me for details.
