Results 1 to 16 of 16
    Veteran Member Three Rings DarrenOman's Avatar
    Nov 03 2014
    2009 Gray A3
    California
    AC Compressor shaft removal
    Since returning from my vacation, I had the best week driving my S4. Everything was perfect and life was grand . Not to let me off to lightly, my AC compressor seized up yesterday leaving me with no AC in the 100+ heat.
    The car is in the service position and I was able to remove the compressor, but the cone shaped piece is still attached to the drive shaft and will not budge.
    My manual says to hold the shaft still and rotate the cone piece anti clockwise, but nothing.
    A; Am I trying to rotate the cone is the correct direction.
    B; What else should I try.
    Thanks
    Sent from my SM-G960F using Tapatalk
    Veteran Member Three Rings Velox's Avatar
    Mar 30 2016
    S4
    Oranjestd
    ant-clockwise when looking from the front of the car yes.
    ive had this problem too, I stuck a wrench on the shaft and locked it against the frame. and used a breaker bar to get the part of. But it might be safer to just remove the shaft and work on it outside the car, because you don't want to accidentally turn the shaft
    Senior Member Two Rings 522sixth's Avatar
    Sep 16 2018
    Las Vegas, NV
    Quote Originally Posted by Velox View Post
    Penetrating oil and a torch to heat up the connection. I had to to hold heat on it for at least 3-4 minutes to break it loose.
    Sent from my SM-G955U using Audizine mobile app
    Nov 03 2014
    2009 Gray A3
    California
    Velox,
    Do you know how it is removed by chance. That would be much easier.
    Mar 30 2016
    S4
    Oranjestd
    Yes if you remove the rubber boot/cover it should simply slide out
    Veteran Member Three Rings luvsspeed's Avatar
    May 13 2007
    04 S4
    North Carolina
    The shaft should just pull out from the block at this point. There isn't anything holding it in.
    Nov 03 2010
    2019 Audi A5 Sportback, 1986 MB 560SL
    Fallbrook, CA
    I just recently had the compressor changed on my 3.0, and the drive plate hub was broken just like that. The shaft, which should turn easily, would clunk and jam against something internally. On the other hand, I see that your inner bearing race is stuck on the snout of the compressor. Did the bearing shatter and cause the pulley to twist and break the drive plate? If so, then perhaps you just need a new pulley/bearing/drive plate assembly, and to get the broken hub off. An impact wrench with a rigged-up socket that grabs the remainder of that hub should work, then tap or pull that bearing race off. Too bad you are so far, I bought a brand new pulley assembly and the Sankyo installation tool before finding out what the issue really was, and they need a home.
    Mar 30 2016
    S4
    Oranjestd
    Quote Originally Posted by Turbo510 View Post
    Wouldn't have worked anyway the 4.2 don't work with pulley, they are directly driven by a shaft of the timing/accessory gears
    Nov 03 2014
    2009 Gray A3
    California
    I have been soaking the part for two days and the f*^ker still won't break loose. I'll give it some heat today, as I have my new compressor waiting to be installed.
    Sep 16 2018
    Las Vegas, NV
    Yeah, i had to place mine in a vise and heated it up for a while. Put a breaker on it and it came off.
    Quote Originally Posted by DarrenOman View Post
    Mar 30 2016
    S4
    Oranjestd
    There's a shaft only on ebay for 29usd, might safe a lot of time/frustration
    Edit forgot you're on the other side of the world though
    Veteran Member Four Rings Jdsb6s4's Avatar
    Aug 27 2016
    GL450, GLA250
    I am considering removing the AC system if I decide to go water meth option when I boost the car. Does removing the compressor throw anything off on the engine or will everything be the same? Kinda a dumb question to ask but I don’t know anyone that has completely removed system.
    Nov 03 2014
    2009 Gray A3
    California
    Something things just dont go to plan
    Got the shaft off of the clutch wheel in the end, ready for the compressor install tonight.
    While assembling my engine I used loctite on the engine mount bracket bolts, what a great idea I thought. Until I needed to remove the bracket to install the compressor, where the top right bolt head strips.
    I tried for several hours, but could not get the compressor in place with the bracket installed.
    So now I have decided to cut the bolt head off with my dremel and of course ran out of carbide disks . The Joy's of motoring would tell me.
    The good news of course, is that I have a plan of action and a direction to take.
    Sometimes that's all you need.
    Sep 16 2018
    Las Vegas, NV
    We should start a broken hearts b6s4 club, lol!
    Nov 03 2014
    2009 Gray A3
    California
    I'm in
    Aug 27 2016
    GL450, GLA250
    Yeah I wouldn’t use loctite on bolts that big TBH
