Results 1 to 14 of 14
    Dec 25 2017
    Sweden
    Question Transverse engine block identical to Longitudinal?
    Hi,
    So I have a Audi S3 BHZ engine in the garage. It was built April 2007.
    My own car has the Audi A4 BUL engine. Built late 2006.
    Both are Quattro.
    Thus far I have compared the cylinder heads (waiting for a new BUL gasket to overlay on the BHZ gasket to compare cooling and oil holes etc.) and they appear identical.
    But what about the block? Should I assume all accessories and parts will transfer, including flywheel/clutch and engine mounts? Any evidence to support this? Or how can I verify it, without pulling my engine?
    Basically if the two engines are compatible I will just restore/build the S3 engine and then swap.
    Thanks
    Audi A4 Avant Quattro 400 CHP build thread.
    Apr 17 2018
    Hampshire UK
    https://r.tapatalk.com/shareLink?url...6&share_type=t
    Have a read of this thread, he did the same, loads of detail.
    Sent from my SM-G975F using Tapatalk
    Dec 25 2017
    Sweden
    Quote Originally Posted by Metalsmurf View Post
    You know this person?
    I browsed through it (NICE car!) and looks like at some point he put a CDL engine in. Not sure I understand what was different on the crank from his notes.
    Wasn't the DTM Front Wheel Drive also?
    Apr 17 2018
    Hampshire UK
    No I dont know him, bit there is loads of info on there. The DTM is quattro too.
    Veteran Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    The blocks are identical and all accessories swap over. My race car has an engine out of a GTI which is FWD, and it installed into my Quattro. I know first hand because I did the swap myself.
    The crank issue is completely separate. There are difference between tiptronic and manual cranks. That will cause issues.
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
    Jun 17 2013
    jersey city nj
    Need to the oil pan & pick up screen
    Dec 25 2017
    Sweden
    Quote Originally Posted by james12lucy View Post
    What you are saying is I need to find out if my S3 engine was in a tiptronic equipped car? How would I do that.
    Haven't found the VIN on that block yet...
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by AudiB720TS View Post
    for a pilot bearing on the end of the crank if it was a manual
    Dec 25 2017
    Sweden
    Quote Originally Posted by vce1232000 View Post
    That's all? I did not see one (didn't look much).
    Clutch looked like this: https://imgur.com/4mXUtp4
    Will go back to garage and take a pic of the crank boss and flywheel if that helps.
    Nov 03 2011
    All Over!
    I don’t think the manual / auto crank difference applies to transverse engines. I believe they’re the same.
    1986 Type 85 Audi 90 quattro
    Active Member Four Rings EvolutionArmory's Avatar
    May 20 2017
    New Hampshire
    When you swap this motor use the block and head but use all of your original accessories just to make sure you don’t have hardware/software conflicts with sensors or other electrical parts unless you verify that they are the same beforehand.
    The rail pressure sensor and intake flap runner motor are VIN specific for example. If they have different part numbers from the old motor to the new motor, there could be conflicts. Keep that in mind when you decide which parts to use from each motor. Also keep in mind what part numbers your specific tune might be looking for. If you map out all of this info ahead of time, you’ll have less of a chance of bolting this all up and running into a very avoidable issue.
    I’d also make sure if the pilot bearing is different or the same.
    2016 S4 premium plus, Glacier White Metallic, black optics, carbon trim, magma interior. APR dual pulley Ultracharger and TCU, APR intake, Merc HX, CWA100, APR A01 wheels, ECS rotors, Michelin PS4S, 034 trans mount, AEM 400cc’s meth
    APR tune [email protected]
    Jackal tune 10.68@129
    stock blower, stock cats, stock suspension.
    Dec 25 2017
    Sweden
    Quote Originally Posted by EvolutionArmory View Post
    Throwing almost everything away from the spare engine. Keeping only bare head and (complete) block.
    The needed parts will be either transferred or bought new.
    Thanks
    Mar 24 2013
    Oakdale, CT
    Bare blocks are identical between transverse and longitudinal. The only oddball crank is the tiptronic version in the A4. All other cranks are the same.
    -Adam
    Dec 25 2017
    Sweden
    So then I'm good with the S3 block. Thanks.
