Results 1 to 25 of 25
    Senior Member Two Rings Serpex13's Avatar
    Jul 18 2019
    2011 GS Corvette
    Illinois
    What engine oil do yo u guys prefer and why?
    About to get an oil change done and was wondering what some of the oils that you guys use are.
    Aug 08 2018
    New Hampshire
    Quote Originally Posted by Serpex13 View Post
    I used Mobil 1 0W-40 for my last oil change, got some LiquiMoly to try for the next one. One advantage of 5k oil changes I guess.
    Mar 26 2010
    US
    I typically use Mobil 1 European formula 0W-40 (VW 502), works well & easy to find. The 5 gallon container is around $28 at Walmart.
    I am tempeted to try the Mobil1 ESP 5W-30 (VW 504), since it allegedly produces less sludge, but it does cost more.
    My underhood labels says to use VW 502 or VW 504 motor oil.
    The local Audi dealer uses Pennzoil Platinum Euro because it is cheaper.
    BMW M3 Competition X-drive
    Jul 18 2019
    2011 GS Corvette
    Illinois
    What oil filter do you guys use?
    2016 Audi RS7 - | DS1 with custom SRT ECU Tune | Carbon Optics Package | Alcantara Headliner | TawCustoms Carbon Fiber/Alcantara Steering Wheel | Miltek Non-Res Exhaust + 3 inch Catless DPs | 20’ HRE P44SC Bronze Chrome Matte | 285/30/20 Michelin PS4 | Neidfaktor Carbon Fiber Mirror Caps
    IG: glacier_rs7
    2011 Corvette GS H/C/I
    Feb 25 2015
    Phoenix
    I’ve been using Motul or LiquiMoly but good grief it’s a pain in the butt to find locally of you need a quart to top off between oil changes. Always used Mobile1 with my AMGs with zero issues on a lot of hard miles. I’m seriously considering going back to Mobile1, not just because it’s easy to find, but I feel like the 0 weight may give me a small layer of comfort with the oil screen issues.
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    Motul Specific 5w-40 for changes.
    and/or Amsoil European Car Formula 5W-40 Improved ESP aka AFL for top offs.
    Optional for top offs because locally avaialble...Pentosin Pento High Performance II
    OE filter
    FWIW top off oil usually lasts a while never had to do more than 250ml in a 5k mile change interval.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Mar 14 2016
    Cleveland, OH
    Quote Originally Posted by Chiromikey View Post
    I ran 0w-40 M1 with OEM filters. Turbos both failed at 46k miles. 0w-40 will not help. It's the oil screen micron is wrong and it clogs from sludge build up or simply the oil starts to break down and creates enough large particles to clog the oil screen. 5k OCI buys time. Doubt it's a actual fix.
    Veteran Member Four Rings Dasquade's Avatar
    Sep 07 2010
    Belgium
    Quote Originally Posted by Clipse3GT View Post
    That is why some take it one maintenance step further and do oil flush restorations (BG, Bardahl, etc...) and additional oil adds. Sadely we can't proof if it helps or not...
    S6 C7 avant '13 estoril | ceramics | DS1 OTS stage 2 | Lightvan | Milltek non-res X pipe | TS1 | 034 trans-diff mount | CETE ASC-EVC | FL tails & dynamic signals | Thermo ZO catless DP | SRM a2a | BC Forged 20" HCA162S | custom spoiler sideskirts | Maxton front lip & diffuser | Armor heatshield mani-turbo-dp | B&O led tweets (repli) | Forge boost hoses | FIS mmi gauges | R8GT steeringwheel | alcantara interior | SRM inlets | R8 exclusive seats | JXD driveshaft | Tial WG
    Veteran Member Four Rings OlyS6's Avatar
    Nov 22 2016
    Olympia, WA
    Motul 5w-40 Excess:
    https://www.amazon.com/Motul-007250-...gateway&sr=8-3
    Oil change interval of 5k miles. I've been using a can of BG EPR engine cleaner at the start of each oil change:
    https://www.amazon.com/cans-EPR-Engi...NsaWNrPXRydWU=
    At 25k, when I changed the turbo oil screen out to the new version, my old screen was pristine.
    2016 S6, mythos black, RS7 turbos, MRC inlets |Akrapovic exhaust| AMS downpipes and intercooler |Eventuri intake| Loba HPFPs |Tial wastegates| Eurocode sways, end-links, and AK | Audi CCB| HRE P103, 20x10 | RS6 grille| Neidfaktor CF mirrors, diffuser, and steering wheel| Blackvue dashcams| Escort Max CI 360 | RS6 LED headlights, OEM Euro tails |Sound: Navtv Zen-v preamp, Helix DSP Ultra, JL HD900/5 driving JL10W3 sub and Hybrid Audio speakers.
    Feb 25 2015
    Phoenix
    Quote Originally Posted by OlyS6 View Post
    Motul 5w-40 Excess:
    Was thinking about starting this regimen. Do you simply add oil afterwards with no worries about any leftover solvent?
    Nov 22 2016
    Olympia, WA
    Yep, just add it to the old oil, and run the engine at temp for 15 minutes. Then drain the old oil. Change the filter, add new oil, done. I fully drain it, and don't use a mityvac with this process- I'd be concerned about leaving some solvent in if I only used a vacuum and didn't completely drain the oil.
    Established Member Two Rings warp_ix's Avatar
    Aug 18 2014
    2016 Audi RS7. 2018 BMW M3. 2010 Audi A4.
    One can or two?
    Sent from my SM-G950U using Tapatalk
    Nov 22 2016
    Olympia, WA
    I've only been using one can, but the directions say that for our volume of oil we should be using 2 cans of the BG EPR.
    Veteran Member Three Rings Patrick Matte's Avatar
    Jun 12 2018
    old car's: Porsche 911 86 3.6 varioram plus G50, elephant racing track suspension, 996 turbo brakes
    Beloeil , Canada
    Liqui Molly
    Mar 26 2010
    US
    BG EPR Engine Performance Restoration information PDF
    "For 7-9 quart (6.6–8.5 liter) capacity crankcase: Add two 11 oz. (325 mL) cans BG EPR® to crankcase. Start engine, bring to full operating temperature and run engine for 20 minutes at 1,200 RPM. Shut off engine, drain oil and remove old oil filter. Install new filter, replace drain plug, and fill with new oil. Do not use on badly sludged engines!"
    Jan 28 2018
    Audi B7 A4 Sline
    Columbia, SC
    Liquid Molly. If it’s not available Motul. I have to go to Napa. Advanced Auto and such don’t carry German motor oil.
    Veteran Member Three Rings LawDawg's Avatar
    Feb 20 2008
    Naperville, IL
    2 questions:
    Is it a problem to add 22oz. (2 cans of BG EPR) to the engine oil? That seems like quite a bit to have "overfilled" your oil levels.
    Do you actually sit there and rev the car in neutral to 1200 RPM after it warms up, or do you just go for a short, easy drive keeping the RPMs low?
    Will def. do this at my next change.
    Current:
    '13 S6 Prestige [Oolong Grey Metallic, B&O, Innovation (HUD, Night, ACC, Active Lane/Side Assist., Top-view), Cold Weather, LEDs, 20"]
    Former:
    '11 S4 Prestige
    '05 A4 1.8T USP 6MT
    '01 A4 1.8T QMS
    '95 Dinan M3
    Mar 26 2010
    US
    Quote Originally Posted by LawDawg View Post
    2 questions:
    For running at high idle, the extra 22oz should not be a problem, most likely the oil is not completely full, since last oil change.
    Use a tool to keep the throttle at high idle 1200rpm: Lisle 48700 Throttle Pedal Depressor, $19.34 FREE Shipping
    " Engage the nylon hook under the steering wheel
    Tool is 40" in overall length
    Use the adjustment screw to fine-tune the RPM level
    Then extend the depressor rod to the accelerator pedal "
    Aug 06 2014
    NJ->CO
    2 questions:
    Good question.
    I'd be uncomfortable if I did not at least remove half a quart prior or maybe ok if the oil level already reads half quart(liter) low at oil change time.
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Veteran Member Three Rings DoItAllGarage's Avatar
    Oct 29 2013
    WA to ID
    I spoke with a Liqui Moly rep and this is what he recommended. I change my oil every year bec I only put about 5-6k/yr. What I use on my S7, Liqui Moly (top tech 4200, anti-friction oil, and engine flush every other oil change) and use Liqui Moly 2332 Leichtlauf High Tech on my A4 B8. Screenshot_20190818-185708_Amazon%20Shopping.jpeg
    Sent from my SM-N960U using Audizine mobile app
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by DoItAllGarage View Post
    Weird that Liquimoly would recommend the lighter 5w-30(4200) for the S7, when their 5w-40(4100) is recommended on their website as well as it's on Audi's approved list.
    While I'm sure both are fine and all Liquimoly is probably pretty good, since we are splitting hairs here the 5w-30 just seems like an odd choice, but for your low usage it probably doesn't matter. Also the "synthesis-technology" is market speak for "not really fully synthetic" GroupIII (thanks Castrol) again probably no difference to most anybody, but I believe their Group IV stuff goes by different naming (if it exists at all any more...maybe Synthoil Energy.)
    From Liquimoly:
    "Note :According to the National Advertising Division® all Group III and Group IV based oils are designated as “Fully Synthetic” oils. "
    Again from Liquimoly:
    Group III:
    "Hydrocracked base oil combines the positive properties of mineral and fully synthetic base oils with one another. This base oil type offers a very good thermal stability and resistance to aging with simultaneously absolute material compatibility. The basis for hydrocracked base oils are formed by the paraffin taken from the mineral oil extraction. The paraffin is made up of long-chained molecule compounds (> C35). These are split open in the presence of a catalytic converter under a pressure of 70 - 200 bar and temperatures of up to 500 °C and shortened to a useful length of C20 – C35 (catalytic hydrocracking). The liquid in the vacuum is subsequently distilled, in order to avoid the cracking of the molecule chains. In the last step, any paraffin deposits are removed"
    Group IV:
    "Fully synthetic base oil is mainly characterized by its very good thermal stability and cleaning performance. As high performance as it is, so laborious its manufacture also is. So-called naphtha (petrol without additives) serves as the base product. Naphta in cracked in the first step, which means that the molecule chains (C5 – C12) split open and are broken down to a length of C2 – C3. The former liquid is now gaseous. In the consequent synthesis process the short molecule chains (C2 – C3) are added to long molecule chains (C20 – C35) and sealed by adding hydrogen (hydrogenation)."
    So there is a defined difference between Group III & Group IV yet oil manufacturers are not required to differentiate between the two Groups in advertising...jeez....
    Again it all likely makes no difference whatsoever and I know a lot of this information is old news...just being pedantic. Sorry.
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Oct 29 2013
    WA to ID
    Really good info! I haven't been on LM's site in almost 2 yrs, looks like they added more options. I totally agree not much of a difference between 30w vs 40w, colder vs warmer regions. The 4100 is cheaper, may change to save a few bucks.
    Jan 13 2018
    This Technical Service Bulletin is pretty helpful if you don't already have a favorite brand. For the S6 we want VW 502 00 compatible. I got a warning last night that my oil is low, so I've been researching what to top it off with. My dealer who did my last oil change under AudiCare said they use Castrol 5w30, but weren't specific as to which Castrol so I may go by and ask in person just out of curiosity.
    https://www.audiusa.com/content/dam/...e-Bulletin.pdf
    2014 S6 | Phantom Black Pearl | Alcantara Headliner | B&O | Black Optic | Driver Assistance & Innovation Packages
    Mods: APR Downpipes | APR Stage 2 | Black Powder Coated Wheels
    Mar 26 2010
    US
    Quote Originally Posted by Dre325 View Post
    ........For the S6 we want VW 502 00 compatible.......
    My S6 underhood label says to use VW 502 or VW 504 motor oil, so I could also use the VW 504 5w-30 oils listed near the end of the bulletin.
    Established Member Two Rings Joe'sS6's Avatar
    Jan 24 2018
    San Diego, CA
    Mobil 1 5W50 works like a charm in warmer climates, at iddle the engine runs smooth. You can forget about those valves clicking noises at iddle when using Castrol Edge and the original VW 504 00 oil.
    2016 S6 Tornado Grey / Black Alcantara, SR7 Turbos, SRM Inlets + SR7 Intake, DS1 Stage 3 Tuned, APR CPS, Eurocode F&R Anti Sway Bars, Steel Braided Brake Lines, Slotted OME Front Rotors, EBC Red Stuff Brake pads, Full Audio Upgrade, CarPlay & A.A. enabled, 50% Ceramic Tint, Xpel P.P.
