Hello Everyone,
I had OEM Discs and Pads that were replaced with Zimmerman Discs and Hawk HPS Pads 3 years ago and it's time to replace them.
OEM Discs and Pads were AMAZING but lots of dust and it felt like the initial bite was much more abrupt than higher speed braking.
Zimmerman Discs and Hawk HPS pads are down right DANGEROUS when the temperature is below -30C/-22C as there is ZERO braking till they warm up and if you are on a long drive on the highway you would need to touch the brakes once in a while to heat the pads up. Other than that the Zimmerman Discs would rust very quickly when I don't drive the car.
So I'm looking for coated discs? and something closer to the OEM Pads. I've been told Textar is the OEM Brand, if so I'm going to get this set https://www.ecstuning.com/b-textar-p...8k0698151ekt1/
In terms of Rotors/Discs I'm looking at 3 options.
Brembo https://www.ecstuning.com/b-brembo-p...0615301a~brkt/
ECS V4 https://www.ecstuning.com/b-ecs-part...5997ecs0616kt/
Zimmerman https://www.ecstuning.com/b-zimmerma...8k0998301akt3/
