Originally Posted by
A4x
I'm getting some clunking from the front passenger side. Not sure what it is, but these lower curved control arm bushings are shot and nothing else is obvious.
@90k miles, deciding if I should refresh all control arms for significant cost, or just tackle the trouble bushings.
Yeah I’m getting all sorts of weird sounds right now. About to hit 120k and the car isn’t riding as smooth as it did at 108k.
I also suspect my struts and coil springs and strut mounts weren’t in the best of shape as well.
I was already planning on lowering it but the ride harshness is definitely making it a priority.
Was able to snag solowerks coil overs at waterfest for $400 flat, was able to get the heavy duty Meyle kit for $605 marked down from $655 and was also able to snag st sway bars for the front and rear almost 100$ off as well on sale. Also picked up new Meyle rear end links and I still want the coil over install kit(strut mounts front & rear) and rear control arm bushings and all should feel solid and tighter then before.
Decided to go Meyle with the lack of reviews on this platform because all the posts I found of guys with the 034/eurocode kits that have spherical bearings and not bushings are made to be serviced and NEED to be regularly or will experience weird noises as well.
Once mine come in and I have them installed I can post initial impressions if anyone is interested. As our cars start to age this makes a nice cost effective solution to keep them riding smooth.
EDIT: forgot to mention that I also picked up the heavy duty Meyle outer tie rods and new lemforder inners for the left and right. Maybe over kill but I’d rather do it once and do it right and have some peace of mind. This with the new end links and sways should end my steering wheel shake.
I can also go one step further and bless you guys with an awesome contact. Met a guy who has a business with his friend selling aftermarket and oem parts. They have an ecs wholesale account but 9/10 times they charge less then ecs and do not charge sales tax which is a big savings in itself. That’s who got me 50$ off the Meyle kit. I’ve used him several times always a good experience. If anyone wants to save a few bucks on ecs’s catalogue contact @s4_dad on Instagram and tell him wastegate_warriors sent you!
FYI: he can give the best deals on everything that does not have the VAG stamp on it
