Results 1 to 16 of 16
    Junior Member Two Rings
    May 07 2019
    Dallas, TX
    B8 S4 Clutch Replacement Cost
    Hello! I've got a stage 2 dual pulley APR 2012 B8 S4... I noticed the clutch pedal will vibrate fairly significantly at cost to 5k - 6k RPMs so I figured the throwout bearing was done for. Right now the cars clutch is 100% stock... 64k miles on the car.
    I took it to a shop to get replaced and they were recommending I additionally upgrade to a stage 2 clutch (southbend), add a new flywheel, and a new crankshaft seal.
    Total out the door cost for all parts and labor I was quoted at $4,800 - is this reasonable? The shop I'm at seems very reputable and I've worked with them before... But I figured for a $4k+ repair I should get some more opinions.
    Thanks for any input!
    Veteran Member Four Rings KRp220's Avatar
    Aug 23 2011
    NH
    I paid about that for my south bend stage 3 clutch and install. Don’t remember the exact cost but it was in the ballpark of what your were quoted
    2013 S4 // ESTORIL BLUE // 6MT// RS BUMPER // GIAC STG 2 // FORGE CC // AWE+SCORPION // ECS INTAKE // BILSTEIN+H&R // VOSSEN VFS5 // PSS 265/30/20 // AK // 034 MOUNTS // SB STAGE 3 CLUTCH // CR 15
    + ECS Diffuser, BFI shift knob, tints, sports diff, j-codes, Akebono pads, SS clutch line, Ceramic Pro...
    GONE 2010 S4 // QUARTZ GREY // 6MT // GIAC STG2 // AWE TRACK // ROC EURO // 034 TRANS MOUNT // H&R OE's // AG M610 FF 19x8.5 // + random stuff
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    That seems high to me. I was quoted about $2,700 for parts+labor for the Sachs Xtend clutch and Luk flywheel. So, unless the rear main seal costs $2,000 or their labor rate is $250/hr I suggest you get another quote just for sanity purposes.
    Established Member Two Rings Glad22's Avatar
    Aug 12 2017
    Middletown NY
    Quote Originally Posted by jsh139 View Post
    Just had Same set up installed: $2800 all in
    2014 b8.5 Audi S4 6MT| Phantom Black | Unitronic Stage 3 | Merc HX | Roc Euro intake | AWE Touring exhaulst | H&R OE Springs | H&R Front and Rear Sway bars | Zito 19x10 et 45 Satin Black | Michelin Pilot Sport 4S 255/35 |
    Veteran Member Four Rings Audi 4 Life's Avatar
    Jan 16 2011
    06 D3 A8 Black/peanut with alcantara
    Earth
    Just got the JHM R series I have driven several clutches southbend, jhm b7 rs4, clutchmasters (stay away from CM)... and few more cant think or atm and in all my experience the JHM kits are the best way to go if your modded otherwise might well stick to OE. You get what you pay for.
    Sent from my SM-G960U using Tapatalk
    RIP - JHM B6 3.0 6MTQ USP Denim Blue/Black w/ Nappa Silver
    Current- B8 A4 2.0t S-Line Stasis Challenge Extreme Edition, Alcantara Headliner, ALA/ACC and 3g+ swap
    D3 A8 4.2 Black/Peanut (Daily)
    Apr 17 2018
    Rochester
    Same for me, Sachs Xtend clutch and Luk flywheel @ 49k miles.
    $1400 labor (I did diff, sport diff and tranny fluid too), $1200 in parts.
    Note: I spent $200 in bolts, I ordered and replaced every single bolt removed. OCD...
    Here's a list of parts:
    https://www.audizine.com/forum/showt...port-diff-info
    2015 Audi S5 6MT Porsche Sport Classic Grey
    APR Stage 2. Milltek Valvesonic. ECS CF Intake. KW HAS. B9 RS5 Akebono BBK SQ5 380mm. CR15 Brace. 20" RS5 wheels (satin black & silver lip). 19" Speedline 3430 (winter). 19" TE37 Ultra MSpec.
    Sep 22 2010
    Quote Originally Posted by peterpark0 View Post
    Same for me. $1400 labor (I did diff, sport diff and tranny fluid too), $1200 in parts.
    Same here.
    Veteran Member Three Rings Snowmonkey's Avatar
    Apr 27 2018
    Kansas
    Agree with the others, thats a bit steep. I did ECS lightweight flywheel and sachs Xtend clutch for 2950
    2013 Phantom Black S4, 6MT, APR Stage 1, Carbon Intake, Canyon Run CR-15, aFe Pro 5R, Sport Diff, B&O, Nav
    Aug 23 2011
    NH
    Just checked my records. $1200 for labor. $3300 for the stage 3 clutch
    Veteran Member Four Rings ModItNow's Avatar
    Mar 05 2015
    Exway x1 pro
    Bay Area
    JHM charged me around $1,200 in labor to install their 3R clutch, flywheel and clutch line. At the time the 3R/flywheel was $2,750
    Sent from my SM-G965U using Audizine mobile app
    May 07 2019
    Dallas, TX
    Ok thanks for the input guys... Yea it's about $3k in parts and the rest to labor.
    Oct 11 2014
    '14 RS5, '20 BMW X5, '21 Wrangler, '21RipleyV4
    Connecticut
    I just got quoted $5,800 to replace the clutch and flywheel on my 2010 S5, that seems $2k out of line.
    Can anyone recommend a good shop in Connecticut / Rhode Island where you’ve had quality work done?
    Senior Member Two Rings Z06Corey's Avatar
    May 24 2019
    Quote Originally Posted by cts5 View Post
    Curious for responses. I bought a Sachs Xtend clutch I haven't had put in just yet.
    2019 S5 SB. Prestige, black optics, B&O, sport diff. 034 stage 2/2 ECU/TCU, 034 downpipe, APR intercooler, 034 transmission insert, 034 turbo inlet, CTS intake
    2017 R8 V10+
    Veteran Member Four Rings Silver Streakin's Avatar
    Mar 05 2004
    B8 S4, 17 Expedition EL, 2009 328ix coupe
    NoVA
    several factors...
    Parts you pick
    Parts markup $ if you can't bring your own parts
    Labor rate
    How long it takes a mechanic to do it versus book time
    I'm not surprised by any of these quotes.
    2011 S4, 6M, BB/panda, Sport diff, ADS, B&O | UniTronic stage 3 Dual Pulley | MercRacing HX | RocEuro intake | AWE Track & DPs resonated | H&R c/o w/Bilstein B8 rears| 19" VMR 710 & 19" Peelers | 034 trans insert | AK brace | CR15 bar | DEVAL CF Diffuser
    SOLD 2007 S4 DTM, Phantom Black Pearl, manual | JHM | FI | H&R | VMR | 034
    RIP 2001.5 A4 1.8TQMS, Silver/Ebony | APR stage 3 | STaSIS Tracksports | StopTechs
    SOLD 1995 90
    Veteran Member Four Rings Ford Prefect's Avatar
    Jan 20 2017
    RS7
    New Hampshire
    Might be worth a trip to N.H., Sam’s Euro in Bow quoted me $900 in labor and $1950 for SB stage 2 w/ECS lightweight flywheel.
    Sep 28 2017
    Attleboro
    I used Banchwerks in Providence. I paid $1500 for labor and $2300 for JHM 3R cluth and LWFW.
    Sent from my SM-N975U using Audizine mobile app
