Results 1 to 8 of 8
    Junior Member Two Rings
    Feb 15 2018
    Orlando, florida
    A6 2.0t quattro downpipes?
    I know, I know, I know, I should have got a 3.0 instead. Well, I didn't. So anyone have any info on a possible downpipes for a 2.0 quattro engine? I have looked around quite a bit and don't see anything. I know there are tunes available for the car, a downpipe to go with it would be better though.
    Apr 10 2015
    Morristown, NJ
    The APR DP for the B8 a4 is supposedly a direct bolt on fit, link here: https://www.goapr.com/products/apr_e...dp_20t_b8.html
    Here is the thread for tuning the 2.0T engine: https://www.audizine.com/forum/showt...oon-C7-A6-2-0T
    All of this is for the 2.0T engines for 2013-2015, no one has tested anything on the 2016+ engines.
    Feb 15 2018
    Orlando, florida
    Thank you!!
    Mar 11 2007
    Colorado Springs
    Quote Originally Posted by wade99 View Post
    Actually it's downpipe, as in one ;-)
    You need the APR downpipe for stage II, add a TMD, and it's a difference maker.
    There are a couple AZ members that have 2.0T motors and went stage II. Do a search "mbauer" I think that's it.
    2022 Q8 S line Prestige Stock
    2012 A7Plus APR Stage II+ UC
    2012 A8L 4.2
    Still own them all...
    Apr 10 2015
    Morristown, NJ
    Quote Originally Posted by A6sport View Post
    What's a TMD?
    Don't entice me, I've been itching to go stage 2 (I've been quoted $1200, unless I install the DP myself), already at stage 1 and it made a big difference....
    Junior Member Two Rings Cybercub's Avatar
    Mar 22 2018
    2014 Enclave
    Bradenton/Florida
    When I had my 2.0t 2014 A6 I went straight to stage II. It definitely brought the car to very acceptable performance. When I went to 3.0t A7 it felt pretty damn close to how my A6 was in power. However since I have applied stage 1 to the 3.0t it’s definitely snappier than what I had thus far.
    You will love the 2.0t with stage II. You might have to get HI-Flo cats unless your able to get it straight piped somehow.
    Oil change more frequently at every 5k, change sparks every 25k.
    Your first “launch” will put a great smile on your face and pin you to the seat! Look up how to do launch after tuning.
    2014 A7 3.0T Prestige Quattro | MODS EVENTUALLY....
    2014 A6 2.0T P+ Quattro | APR 93 STG II | APR Downpipe - SOLD
    Mar 11 2007
    Colorado Springs
    Quote Originally Posted by acamposac1 View Post
    What's a TMD?
    Turbo Muffler delete, it only works for stage II, when I went stage III on my A5 the Tech said it will not fit the K04 turbo.
    https://www.goapr.com/products/turbo...88_g3_ihi.html
    2012 A8L 4.2
    May 10 2015
    Pittsburgh PA
    Turbo Muffler Delete should help reduce lag a little bit, but it won't be night and day. Not saying it's a bad mod, just not a necessity. Your money is probably better spent upgrading to an OEM A6 TDI intercooler to help combat heatsoak.
    If you are running stock intercooler piping though, deleting you soundbox will offer a very similar effect for around $5. I removed mine and capped the pipe with a rubber chair leg stopper secured with a hose clamp.
