A big thanks to Old Guy for coming up with this idea in the first place. You can find his thread here:
https://www.audizine.com/forum/showt...weighted+shift
Instead of lead, I decided to use small Tungsten beads to add weight to my OEM shift knob and the results were great. Tungsten is almost twice as dense as lead (1.74 times more), so you get quite a lot of weight to fill in the small voids inside the shift knob. Like Old Guy, I also used a bit of Elmer's Glue to keep the beads from rattling around inside the knob. I was able to add 4.3 oz (122 grams) of Tungsten to the inside of my shift knob and that made a noticeable different in the shift feel. It definitely feels more solid and has a more positive engagement when shifting from gear to gear. The difference is subtle, but definitely noticeable. It's a great cheap mod that takes just a few minutes. My biggest challenge was getting the top off the shift knob, mostly because my fingernails are too short. I even tried a plastic trim removal too, but I couldn't get that in there either, so I ended up using a pocket knife to slide in there and pop it off. I wish I would have done this mod sooner!
