I doubt Audi patented the tool. There is nothing financially to be gained (for Audi) by protecting that tool...they are not in the tool selling business, and it is such a super-niche application.
The "magic" of the Audi tool is the right-angle spray tip, and the measurement scale so that it can be inserted the correct depth to spray into each of the 3 individual SAI ports that run to the exhaust ports.
Concerning the AC system, the AC condensor can be swung out of the way, with the flexible rubber hoses still connected, so that the Freon does not need to be released and recharged.
Since I intend to keep my S4 for a very long time, and I expect my SAI ports to eventually clog, I will then spend some time to develop a circuit that taps into the SAI pressure sensor signal, to fool the ECU that the SAI system is not clogged. Unfortunatly I have no motivation to do this until I run into this problem...too many projects on my plate.
If anyone else wants to do this, have at it. Basically, at engine start, the ECU checks the SAI air pressure (as measured by the pressure sensor) at 4 or so different operating conditions of the SAI pump and the two combi valves. If the measured SAI "backpressure" falls within a certain range (unique to each of the 4 operating conditions), then the diagnostic test passes and there is no DTC set. If a port is clogged, or a combi valve does not open/close, or the SAI pump doesn't work, then one or more of the measured backpressure values will not be within the acceptable range (for that operating condition), and the SAI DTC is set. Using a Rasberry Pi micro, one could easily output an analog voltage that replaces the real SAI pressure sensor output signal (0 to 5VDC), that tells the ECU that the SAI backpressure is within the normal range. The Rasberry needs to sense the 12V drive signals to the pump, and the two Combi valve solenoids, to determine which of the 4 diagnostic operating modes the system is in, to then generate the appropriate simulated sensor DC output voltage to the ECU. The first step to developing this is to measure the SAI Pressure sensor signal output level during each of the 4 diagnostic operating modes, on a car that does not have an SAI clog.
See pages 38 thru 41 of the "Audi 3.0 V6 TFSI engine with Roots blower Self-Study Program 925803" for the technical details of the SAI system and the diagnostic self-test.
