Results 1 to 40 of 48
    Dec 01 2018
    2015 370z Nismo
    Saskatchewan, Canada
    Turbo sounds like supercharger
    Hi all. Over the past few days I’ve noticed a really strange sound coming from the turbo while in the boost... it almost sounds like a supercharger to be honest. Can’t be good so I’m definitely going to get it looked at as soon as I can (closet dealer is 100+ miles away from me). Still produces boost fine. Only mod is an ECS intake. What do you guys think?
    Veteran Member Four Rings HyperM3's Avatar
    Mar 20 2004
    Lawrenceville, NJ
    Quote Originally Posted by Audski View Post
    How many miles are on your car?
    Yesterday was the first time since I got my car(3 weeks ago) that I was able to take it on a highway commute(70 miles each way). On the turnpike I was having a raucously good time going from 65-90+ in multiple spurts. When I was at these speeds at WOT, the noise coming from my car also sounded like a supercharger whine. To note, I have a JB4 on my car and unplugged the exhaust. I loved the sound but I need more noise! I think the supercharger sound is normal.
    21 S5 Coupe - RacingLine strut brace/034RearSwayBar/CTSTransMount/034 tune/VPS Res Delete/CTSIntake
    10 S4 (gone),13 S6 (gone),14 S6 (gone),14 S6 (gone),16 S6 (gone),17 A4 (gone),19 S4 (gone)
    20 BMW R1250RS
    ACNA Lifetime Member - 26690
    Respond to a post with an answer, they will keep asking questions. Teach them how to RTFM, they will learn to help others.
    Feb 27 2018
    2019 S4 PP - Quantum/Magma 2016 Audi S3 - SOLD 2005.5 S4 Avant MT
    Boston, MA
    I have a '19 S4 as well. Same sound when under strong boost
    Dec 01 2018
    2015 370z Nismo
    Only 19,000 miles. Just weird hearing that sound coming from a turbo is all
    Veteran Member Four Rings richib86's Avatar
    Nov 05 2006
    Fair Lawn
    Assuming it sounds like this, I have it too. But it only happens when ambient temps are in the 60-70 degree range. I haven’t noticed it with the heat. https://youtu.be/0U3lGniiogw
    2019 S4, Quantum Grey, Magma red, Presitge, Black ops, Sport package, Driver assist, Dynamic steering, Carbon mirrors and spoiler, Xpel XR ceramic 35%, Alcantara flat bottom wheel w/ RS paddles, Alcantara shifter, TAG reflectors, APR Stage 1, CTS testpipe, Resonated Miltek, P3 gauge, KW H.A.S., ECS Intake scoop, ECS Carbon intake, ECS Intercooler with charge pipes, ECS Carbon engine cover overlay, ECS Carbon ECU cover, O34 trans insert, O34 rear sway bar, HRE P101 20x9.5 ET35 w/ 265/30/20 PS4s
    Apr 11 2012
    i just hear turbo spool and blow off, nothing remotely like SC whine at all. turbo bearing going? "When the boost is running, a failing turbo could make a loud whining noise."
    Mar 20 2004
    Lawrenceville, NJ
    Quote Originally Posted by will13k7 View Post
    I only have 400 miles on my car, I doubt my turbo bearing is failing already.
    20 BMW R1250RS
    Jan 26 2019
    Check your intake for a vac leak. I once had a similar issue on my ‘04 STi. Ended up having a loose coupling that created a similar sound.
    Apr 11 2012
    Quote Originally Posted by HyperM3 View Post
    likely not, but it could be DOA, always a chance.
    Senior Member Three Rings mobE's Avatar
    Nov 26 2018
    '18 GMC Sierra Denali ultimate
    IL
    True, I've been told if they are going to fail it's most like right off the bat. I'm not sure how true that is though.
    '18 s4, under construction!
    Mar 20 2004
    Lawrenceville, NJ
    Car doesnt feel slow yet, so I dont think its DOA.
    20 BMW R1250RS
    Nov 05 2006
    Fair Lawn
    For me it started happening after installing an intercooler and charge pipes
    Veteran Member Four Rings HurrayFive's Avatar
    Jul 21 2013
    Remote
    Quote Originally Posted by richib86 View Post
    It's normal to hear the sound of air rushing through the heads when under heavy load, it's a light, high pitched whine that increases with revs and throttle, once you hear it on one engine, you can pick it out on just about any other engine if the conditions are right, my B9 SQ included. (Obviously harder if exhaust is loud or it's actually supercharged, which drowns it out)
    That said, your video is much louder and a different tone than that, it sounds like it could be a pinhole compressor side leak from a clamp on the pressurized side of the intake, probably intercooler piping. That or the PCV system may be leaking (through the intake connection) or is stuck (on the manifold side), but it could also be your intake making the sound of the PCV louder, you just don't normally hear that system unless something is wrong with it.
    EDIT: You added a post since I opened this, definitely could be a leak coming from one of the clamps on your IC pipes not being tightened all the way or the piping isn't fully seated.
    '25 M8 Comp GC Frozen Tanzanite on Ivory/Night Blue - 11.0 @ 126 bone stock
    Dec 01 2018
    2015 370z Nismo
    https://youtu.be/kfpwHc6mHr4
    Here’s a vid but doesn’t do it justice.
    Nov 26 2018
    IL
    Yeahhh buddy, you got something going on! Check all connections that have been touched or changed. That's where I'd start...
    Mar 20 2004
    Lawrenceville, NJ
    Ok yeah, mine doesnt sound like that. Then again, I havent put my windows down yet...
    20 BMW R1250RS
    Jul 21 2013
    Remote
    THAT sounds like a compressor that's about to eat itself, definitely get it to a dealer ASAP. Turbos can last quite a bit longer with a failing bearing or shaft that's causing fins to slowly eat themselves than people think and still make normal feeling power, problem is that if it grenades and gets sucked into your engine it goes from just a turbo problem to a much larger one. Even if it's not the turbo, it's not normal, definitely have a dealer look at it as soon as you can.
    Dec 01 2018
    2015 370z Nismo
    Just talked to the service manager at Audi. Wasn’t much help tbh. He said to put the stock air box back on and see if that makes any difference. He also said that if something is wrong with the turbo or whatever that it may be the intake that’s causing it and I could be liable and have to pay out of my own pocket if something does need replacing. Can’t see an intake hurting the turbo or anything. Sounds like a bunch of bullshit to me. I checked everything that may be lose that has to do with the intake and everything seemed fine.... I’m not liking the way this is shaping up.
    Established Member Two Rings Omychron's Avatar
    Dec 18 2018
    Belgium
    Remove intake, go to a different dealer?
    Normally when you really push the car you can hear the whine quite clearly, but this isn't even under heavy load and is not normal.
    Up!
    Current: 2017 Audi S5 (B9)
    Previous: 2015 Audi TT (8S)
    Established Member Two Rings Wikkidtt's Avatar
    Jul 25 2015
    1991 R32 GT-R, 2001 D2 A8L, 2001 Audi TTQ BT,2019 Dodge Durango SRT
    Usa
    Yeah this is not normal. Owned lots of turbo cars and BT Cars and that is a bad noise.
    Jun 01 2017
    I noticed a similar sound recently as well... Any updates? Planning to take my car into the dealership this week or next to have it looked at.
    Aug 12 2019
    Oakland
    My car had a similar sound on Sunday that I only noticed once I had the car in “S” in dynamic mode. Happened once under full throttle...went away and I haven’t really heard it since. My guess is it’s a belt or pulley or something of the sort...not sure what the sound the OPs car was making since he took the video down. But I really hope what we’re hearing is nothing to worry about
    Veteran Member Four Rings oc cc's Avatar
    Oct 14 2011
    OC
    My car also makes a SC whine type noise (still only have 600 miles on it). I am hoping it is nothing to be concerned about...
    Current: 2019 S5 Sportback Quantum Gray
    Previous: 2012 A4 Avant Glacier White
    Dec 01 2018
    2015 370z Nismo
    Hey guys. After much research I have narrowed down the problem to what I believe is most likely a boost leak. I suspect the culprit to be the dump valve, so I’m going to be ordering the Forge Motorsport atmospheric dump valve to see if this remedies the problem. Will let you know how I make out. Cheers.
    Aug 12 2019
    Oakland
    Please let us know!
    Mar 18 2019
    UK
    I have the wine when I’ve been on it hard for a long period of time. I’m confident I don’t have a boost leak I already have the Forge atmospheric DV which is awesome And I can still get that wine. I still don’t know what it is but to be honest I’m going to keep going until something goes bang and then the guys at Audi can sort it under warranty. I have been trying to blow it up since I brought it. I always warm it up cool it down and oil change every 6k. Currently on 22k miles and still hasn’t put a foot wrong.
    Nov 26 2018
    IL
    Whelp, today I joined the "my turbo identifies at a supercharger" club 😒. I'm thinking it's just the waste gate...
    Jan 26 2019
    Check your intake for vac leaks, fellas
    Aug 12 2019
    Oakland
    I’d be curious to know if the very few guys running upgraded turbos have the same sound. Just to ease my worst fears of it being our turbos 😬
    Nov 26 2018
    IL
    Quote Originally Posted by kr3wski View Post
    I'm pretty confident my turbo is hurt. I'll be going over it today doing some checks before dropping it off at Audi. Even though I have a brand new turbo sitting in a box in my garage. Shittttt if it's still under warranty I'll gladly them fix it instead. I doubt the after market one's are having an issue. I think the factory wastegate is failing us.
    Veteran Member Three Rings Zed 2.0's Avatar
    Feb 12 2010
    San Diego
    Can somebody post a sound clip of this? The OP took the video down.
    Only odd sound I've ever noticed is a high-pitched whine at part throttle low speeds. But it sounds like normal high pressure injector or HPFP operation.
    Aug 12 2019
    Oakland
    Quote Originally Posted by Zed 2.0 View Post
    It sounds exactly like a supercharger whine
    Nov 26 2018
    IL
    https://youtu.be/rmjrWf9O4wU
    Dec 01 2017
    Dallas
    Quote Originally Posted by mobE View Post
    WOW! I first listened to the original video that is now taken down, and I didn't hear any of that. This video clearly shows the sound. Is this your car?
    Aug 12 2019
    Oakland
    Woahhhh ok yeah mine doesn’t sound like that
    Nov 26 2018
    IL
    Quote Originally Posted by -LoneStar- View Post
    Yeahhh, it's really clear for me. I have two videos posted that sound clearly different. She's mine...
    Yupp...
    ~ break ~
    About three months ago I was chasing my tail because I thought I had a boost leak. The car wasn't hitting target boost. After many hours checking and reseating/tightening everything it was fine so I figured it was a leak.
    Then a few week's ago I was going down the highway and the car went limp, fault code was a fault with the waste gate actuator. It cleared and went back to normal so I didn't think much of it.
    Yesterday I was on my third session at a track day event and while under boost it went from sounding normal to that nasty whine. I knew something was wrong so I pulled off immediately and cooled the car down. Then putted my way home trying to not spool the turbo as much as possible.
    In hindsight all of the thing's that have been happening could be explained by a faulty actuator or internal failure... I have a second brand new turbo just sitting in a box. I was about three or four week's away from ordering a hybrid 🤷*♂️. I just took off a few of of my part's and it'll be going Into audi with the rest still on.
    I'm going to do an oil change as well... and send a sample off for analysis.
    Dec 01 2017
    Dallas
    Yupp...
    ~ break ~
    Would be nice if Audi warrantied it and took care of it. Which parts are you leaving on? I would almost be inclined to remove everything unless you have a really relaxed dealer. Any time I would bring my car in for warranty work the first thing out of their mouth was "is it modified".
    What's the build date of your car?
    I think an oil analysis would be very smart. What alloys would you be looking for from the turbo (iron, lead, tin, aluminum etc)?
    Nov 26 2018
    IL
    AWE dp & touring exhaust, ECS intake, APR fmic w/ piping, all the 034 suspension bits, KW H.A.S., catch can. They said it will be cool, I was at a track event they put on 🤣.
    Feb 12 2010
    San Diego
    Dealer time for sure, but the fact that it's doing that in neutral is really odd. You should not be making much--if any--boost there.
    Nov 26 2018
    IL
    Yeah for sure... 🤷*♂️
    Like I said I'm pulling an oil sample and then letting them deal with it.
