So this is my first moded car. Finally out of warranty, and have time to mess with my car. Here are the mods/upgrades I wish I would have know about before. Lest expense, most increase in performance:
Suspension:
034motorsports Transmission Insert - firm shifts... little to no additional vibration (easily reversible without a jack)
034motorsports Rear Sway Bar (RSB) - keeps the car flat while in the "soft setting" without major daily driver loss at all. Improved "turn in" (no dealership will worry about this)
Moog rear end links - to maximize the effect of your RSB. Take the poly out (which will wear out with a non-OEM stiffer RSB). Silent and solid
Moog front end links - not sure how much it helps, but tightens things up a bit. Cheap.
HP and responsiveness:
Airbox mod - cut a hole in the place a hole should be. More air... no downside.
034motorsports Silicone Throttle Body Intake - allows the engine to take in more air... quicker throttle response. Zero downside.
EPL TCU and EPL Stage I -- both are self installed and self reversible even if you are under warranty. Amazing upgrade... smooth shifts.. aggressive... MUCH MUCH more power without changing anything but software.
Steering:
Turn off
