Results 1 to 33 of 33
    Veteran Member Four Rings arjun90's Avatar
    Dec 27 2014
    2013 Audi Q5 3.0T
    What are the common Suspension Issues to look out for at 55,000 Miles on 3.0T Q5?
    I'm sure if any of you drive through major metropolitan areas its quite annoying how rapidly the suspension wears and tears. It didn't take long to realize shortly after purchasing, that my front driver side suspension was a bit out of whack. A complete front suspension overhaul isn't as a cheap as my Avant. The strut itself costs as much as a complete control arm set for my A6 Avant.
    Recently I jacked up the front, I tested 9 and 3 positions and 12 and 6 positions and found no play whatsoever.
    I'm issue starts when going over manholes, storm drains, and little potholes. I can feel a double-tap (pronounced sound) coming specifically from the front driver side. The front driver side is usually the most susceptible because of driving on the far most left lane. In countries where right-hand driving occurs, the front ride side would be more susceptible.
    I notice a lot of upper control arm complaints on the Q5 as well other Audi models (rather most models because of the multi-link position). I don't hear any metal to metal contact.
    What are some other common issues based on the variables mentioned above?
    Current:
    | Audi Q5 (B8) 2013 (3.0T, Quattro) |
    70,xxx Miles
    | Audi A6 (C6) Avant, 2010 (3.0T, Quattro) |
    182,xxx Miles
    Gone But Not Forgotten:
    | Audi A6 (C5) Avant, 2004 (3.0L, Quattro) |
    221,386 Miles [April 2014 - March 2022]
    New genuine Audi/VW parts for cheap within the US - audiusaoemparts.com
    New genuine Audi/VW parts for cheap if you can afford the wait - oemVWshop
    Senior Member Three Rings KillerQuattro's Avatar
    Dec 15 2016
    Englewood CO
    Im currently at 105k miles. No suspension issues so far. I went on the KW Street comfort coilovers 25k miles ago. So ~80k on stock and another 25k on modded suspension. I live and drive quite a lot in a city filled with nasty pot holes.
    Maybe you should try looking for a used strut off of a crashed Q5 with low miles? Or, would an aftermarket suspension solution would be close to the cost of and OEM strut? You could get some H&R coilovers for fairly cheap and address any control arm stuff at that time, while you are in there. 2 birds, 1 expensive stone.
    Current: 1995 urS6 Avant. RS2 manifold, Stage 1 chip, Apikol FMIC, custom exhaust.
    Sold: 2013 Q5 3.0t- EPL Stage 2, 183mm CP, KW Coils, Eurocode Alu Kreuz, 034 inlet/AWE filter, EBC Brakes w/ SS lines, Hartmann HRS6 20x9, MF #11385 (center res) and Vibrant Ultra-quiet resonators out back.
    Sold: 2007 Ibis Avant- 2.0t 6mt, JHM HFC, TT DP, JHM HPFP, GFB+, B5 perch mod, 19x9 RS6, Hawk slotted rotors and performance pads.
    Sold: 1992 urS4- Garret 3071R, 034 tuning, RS2 goodies, 993TT BBK
    Jul 31 2016
    PA
    Short answer really should be none.
    I'll post up maybe today or tomorrow my suspension swap I just did if you are looking for alternatives to stock or want to do the job yourself. Our roads are awful, and my car has about 40k miles and everything still looked basically brand new, no issues with any of the rubber bushings, etc. Including the front control arms. I honestly would not suspect a suspension component at 55k miles barring some premature failure, which can happen on the bushings, shocks, etc.
    What mods (if any) are done to the car? How many cars out there have needed a full suspension rebuild at 55k even of one side? There's nothing exotic about this vehicles suspension, and they use the same bushings as probably a lot of cars, many of which are likely bigger it heavier.
    Just be sure you actually have an issue before just throwing parts and money at it. You would be surprised how many things you hear/see that have been there forever but you just never paid attention to before until you are concerned there could be something wrong, myself included.
    Sent from my Pixel 3 using Tapatalk
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
    Dec 27 2014
    2013 Audi Q5 3.0T
    The noise only comes when going over bumps and manholes, something tells it could be something as cheap as the strut mount, buts it’s all speculative at this point. The handling suffers every time this car goes over manholes and storm drains and I’m typically driving on the left-most lane on the highway. I’ll have to remove the wheel and update here with my findings
    I hope it’s not the shock/strut, the price is astronomical, lol
    Current:
    70,xxx Miles
    182,xxx Miles
    Jul 31 2016
    PA
    A new strut is like 250ish, unless you have EDC and then close to twice that. It's probably less than 2 hours to do just one. A shop asking for more than 5 or 600 is charging too much (again more based on EDC parts). Strut mount is 30 bucks but is basically the same job.
    Dec 27 2014
    2013 Audi Q5 3.0T
    I was able to feel something in the wheel well as I drove earlier today, closer to my left foot on the footrest, could be lower control arm / wishbone, I’ll be checking this first thing in the morning
    Current:
    70,xxx Miles
    182,xxx Miles
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    I am at only 48,000 miles. No suspension problems. However, I’ve done my own maintenance on multiple cars for many decades.
    The description you supplied is more consistent with the front sway bar end links. That usually goes first before struts on most cars and has on my others. The end links are readily user replaceable without disassembling the suspension. I would check that first.
    I looked up the price. OEM Audi is over $100 each. Ouch. Aftermarket ones are a fraction of that, but I defer to others here on quality.
    Were it me, I would do both sides while at it. It’s usually best to replace them in pairs, even when only one side is noisy.
    One way to test is to undo one end of link on the noisy side, zip tie or wire I it out of the way and drive the car over some bumps. If the noise stops, you know it is the end link.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Jul 31 2016
    PA
    Moog end links, which have a metal construction and still use the bonded rubber bushings, are like 25 or 39 bucks a piece if you need a replacement. They can be done with the car on the ground in probably 30 minutes for both sides.
    Dec 27 2014
    2013 Audi Q5 3.0T
    I did visual inspection of the front driver side sway bar link and surrounding suspension earlier today. I should probably affix a camera and see what's rattling while going over bumps. I sure hope its something as cheap as the end link, costs $13 Lemforder, not sure if they are the OE supplier for this part though
    Current:
    70,xxx Miles
    182,xxx Miles
    Feb 14 2017
    Gulfport, MS
    Camera may not show anything. A noisy endlink may not make any movement. Probably won’t. Just undo one end to take the load off of the entire bar. Tie it out of the way temporarily and take a drive. If the noise goes away, you’ve found the problem. If it persists, look elsewhere.
    Don’t go super cheap on endlinks. They will soon fail. I’ve used Moog with good success and their stuff is reasonably priced.
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    Quote Originally Posted by arjun90 View Post
    HA! You should check out the mag-ride on the R8's. Makes these seem like something from a Cracker Jack box (free).
    I haven't seen any pot whoes around here, just crack whoes, but I only run over them in GTA.
    Feb 27 2011
    Winnipeg
    At 55k miles I had to do both lower ball joints on mine, everything else is tight.
    Apr 18 2018
    Montevideo, Uruguay
    Last year, at 50K miles I put a set of Bilstein B12 Pro Kit (Bilstein B8 + Eibach springs), this is 2009 Q5 which was driven very little but over poorly paved roads, shocks where pretty much busted but suspension parts looked good after 9 years. I was amazed about the lack of rust on the underbody. Bushings, specially rubbers have some life still, no cracks spotted when job was done. I’m the second owner and drive it like she deserves it, so let’s see how things look like in a couple of months when I take it for an alignment but I don’t expect any major repairs down there.
    Jul 31 2016
    PA
    Quote Originally Posted by seanf86 View Post
    What was the issue you were having?
    Feb 27 2011
    Winnipeg
    Clunking and squeaking over bumps, jacking it up it was very obvious that the ball joint was loose
    Sent from my LM-G710 using Tapatalk
    May 06 2007
    Michigan
    Earlier this summer I noticed a squeaking noise coming from the rear whenever I went over dips in the road forcing the suspension to compress. It sounded like something needed to be greased/oiled, like maybe a dry rubber component. Indy shop said my control arm bushings were probably wearing out.
    I swapped out the the rear right upper & rear left upper control arms with OEM (Meyle) arms. Squeaking noise gone.
    Time on coilovers: 1.5 years
    Mileage on coilovers: 20k miles
    FTG: 29.5"
    Total mileage: 62k miles
    2013 Daytona Grey RS5
    Prev
    2014 Ice Silver SQ5
    2012 Monsoon Grey S4
    2010 Brilliant Black A5
    2003 Denim Blue A4
    Established Member Two Rings Ashs4b8's Avatar
    Nov 21 2017
    I've had the same issue since owning the car 7k ago. The noise started to get louder with harsher clunks. Come to find out the upper control arm nuts was loose. I would go round and check everything is tight.
    2014 Audi SQ5 Prestige Phantom Black
    Dec 27 2014
    2013 Audi Q5 3.0T
    "I think," I found the source of the clunking. It could be my upper control arm bushings.
    I used a pry bar, rubber mallet, and my hands earlier this morning to check for play.
    I even tried checking the suspension when under load (placed a hydraulic jack under the brake rotor).
    The creases and what appears to be cracked upper control arm bushings stood out to me.
    As per the attached pictures, would you agree similarly?
    I don't hear any metal to metal contact, therefore should probably rule out ball joint issues.
    The clunk feels more soft and coincides / follows a split-second after hearing the thump on my tires whenever going over manholes, storm drains, small bumps, etc.
    I can feel the clunk faintly around the footrest area inside the car. If the feel of the clunk was more pronounced there it could have very well been lower control-arm related, but in this case is not.
    However, coming back to the upper control arms, I wedged the pry bar between the upper control arm and the metal housing plate, the control arm moves side to side rather easily; it should be stiff.
    Surprisingly, the "Plastic" sway bar links still look and feel intact.
    What do you all think? Please let me know, thanks again
    Also, is there supposed to be this much of gap between the sway bar and sway bar bushing? (see attached)
    Current:
    70,xxx Miles
    182,xxx Miles
    Dec 27 2014
    2013 Audi Q5 3.0T
    How is the price of $167.36 of four upper control arms possible when genuine Audi upper control arms (4x quantity) cost $900 altogether?
    Current:
    70,xxx Miles
    182,xxx Miles
    Dec 27 2014
    2013 Audi Q5 3.0T
    Also, has anyone here tried the Meyle End Links? They seem to be made of all-metal as well, similar to the MOOG-brand
    Current:
    70,xxx Miles
    182,xxx Miles
    Jul 31 2016
    PA
    The creases are molded into the rubber, and the circumferential cracks aren't really a major concern. If the bushing rotates independent of the control arm, that is generally when it's time to replace. Or if the cracking is really deep. They don't look that bad though.
    Meyle makes a lot of OE stuff so I think you'd be fine with them
    167 for all four arms seems reasonable. Shop around a few places and see what you come up with.
    For the end link, make sure it's actually going to be metal, they are typically in the 100+ range (maybe I'm remembering wrong). The Moogs are like 30 bucks a piece or something.
    Dec 27 2014
    2013 Audi Q5 3.0T
    I've used Meyle HD on my A6 wagon, which was a reasonable aftermarket upgrade and was cheaper as a kit
    The bushing flexes a lot when I wedge a pry in there, not 100% sure if it is contributing to the soft clunk though. The sway bar bushing (driver side) though looks like there is a minor a gap between the sway bar and bushing itself.
    I would definitely upgrade the end links after the clunk is eliminated.
    Also, the bump stop is still in place. I haven't checked the strut mount yet as that would involve complete removal of the strut assembly
    Quote Originally Posted by djn876 View Post
    Current:
    70,xxx Miles
    182,xxx Miles
    Dec 27 2014
    2013 Audi Q5 3.0T
    Turns out there wasn't really a clunk; apparently that's just how the suspension behaves. Although, the mechanic did point out that eventually my upper control arm bushings will need to be replaced. These bushings are common to crease within 10,000 miles of buying new off the lot. I probably should just change the driving style and avoid the roads and lanes with numerous manholes and storm drains.
    Current:
    70,xxx Miles
    182,xxx Miles
    Junior Member Two Rings
    Jun 09 2018
    Fort Smith
    I think your upper control arm bushings look similar to mine. Recently my car started clunking occasionally when backing out of my driveway. So, I checked the bushings and only those seemed to have cracks in them.
    Check the cracks with the vehicle stationary and the steering wheel turned all the way to the left and then right. When I checked mine that way, the splits looked much deeper than otherwise, because as you turn the control arms twist. Interestingly, that’s when it clunks when backing out of my driveway - steering wheel is turned quite a bit.
    I’m considering just pressing the old bushings out and installing new ones. There’s no reason to replace the control arms at this point, especially with aftermarket ones of questionable quality. My ball joints and boots look like new.
    Jul 31 2016
    PA
    You probably will see a reason to replace the arm after trying to press those bushings in and out. If you are really going to replace them, just do the whole arm and save yourself the aggravation. Plus then you have a new ball joint as well.
    Apr 26 2014
    DFW
    That's sound advice.
    Dec 27 2014
    2013 Audi Q5 3.0T
    Prior to taking the vehicle to a family mechanic, I was quoted $40 (from a nearby mechanic) for each upper control arm bushing as far as price for the part goes.
    Otherwise, each arm was to cost $300; labor $80 for each side.
    These are things I'd be able to do myself, however, I still reflect 'till this day about my experience with seized pinch bolts on my A6 wagon
    Ultimately, I'd like to replace upper control arms, sway bar links (from plastic to all metal--from either MOOG or Meyle), and sway bar bushings.
    The bumps I drive over sound more harsh compared to my wagon, but I'm sure this is to do with 20" wheels and heavier vehicle, overall---I'm still getting used to this feeling. However, a visual inspection of the strut mount wouldn't hurt. Some drivers prefer firmer rides other prefer the opposite; I'm more or less in-between, not to keen in cabin vibration. I made the mistake of installing 034 strut mounts on my wagon
    Quote Originally Posted by SQive View Post
    Current:
    70,xxx Miles
    182,xxx Miles
    Dec 27 2014
    2013 Audi Q5 3.0T
    Today I decided to stay on the middle lane on the highway. I also changed the Drive Select from Auto to strictly Comfort and that made a night and day difference. In comfort, bumps don't feel as harsh. Other than that, I'm prepared for what's down the pipeline. Eventually, they'll be the time to replace bushings, etc. Will continue to keep an eye on it. For the meantime, I plan to replace the radiator on an A6 avant.
    Current:
    70,xxx Miles
    182,xxx Miles
    Jul 31 2016
    PA
    Buy a non-Audi branded one from an OE supplier for like 40 bucks a piece for the arms as a whole or the bushings are like 9 bucks a piece for an OE supplier that doesn't say Audi on it. I understand not wanting to fight with those pinch bolts and ball joints, 40 bucks an arm isnt bad, you could bring them the parts and do it for close to what he was going to charge you for one arm.
    Dec 27 2014
    2013 Audi Q5 3.0T
    Yep, I hear TRW is the way as far as upper control arms go. I don't see any rust on the pinch bolt; which seems to be prevalent on Audi's that are closer to the ground; I won't let the appearance deceive me When its time to replace, will put penetrating spray (i.e. Kroil) days in advance
    Current:
    70,xxx Miles
    182,xxx Miles
    Apr 26 2014
    DFW
    Ermagerd! Getin anything repaired on the R8 is an arm and a leg, so bitchyour quitchen.
    Jul 31 2016
    PA
    How terrible you have to struggle with r8 ownership. Could always give it to me if you'd like! I'm not complaining, just saying you can find parts for way less than that guy wanted to sell them for.
    Apr 26 2014
    DFW
    #first-worldproblems
