AC working great and cold then nothing. No electric fan operation.
Jumped power to the fan and it runs but getting noisey.
Pulled under dash cover and fuses appear intact.
Not sure which of the many relays under there control the fan speed.
Ran HVAC codes and I get a 00792 a/c pressure switch error (F129).
Unplugged and reconnected switch and no change.
- Indicates a short circuit to ground
- Open circuit in wiring between a/c pressure switch and a/c control head
- activation of coolant fan V7 (step 2) from a/c pressure switch malfunctioning
- a/c pressure switch faulty
- malfunction in a/c coolant circuit (positive or negative pressure)
If I clear code with ignition on engine off code immediately resets so I don't think it is a problem with actual pressure in the a/c system.
Before I dig in further, any suggestions?
Chris
