Hey Fellow Audi Drivers,
I have an issue with my A3 2011 2.0T (85K miles) for about a year now. It happens only in the warm season (I live in Illinois) or/and at warm starts.
Right after the ignition, the engine sometimes hesitates and RPM drop below normal 800 to 550-600 and lower. With this hesitation, the engine might shut down.
I can rev it up with no problem, and after idle sets on 800 RPM, the car runs fine with no issues. There are no errors with VCDS, and the car runs perfectly fine.
Please see the videos.
https://youtu.be/NmQ_GQxVAFA
https://youtu.be/kv5VBtyK9fs
This is definitely not normal.
Ignition coils, spark plugs, fuel, air filters are all new. I also cleaned the MAF sensor recently, checked for vacuum leaks.
I only use 93-premium gas from Costco and put Motul 5W-40 in the engine.
Today I checked all temperature sensors with VCDS, and all measurements are reasonable. When starting the car (warm) for Engine Coolant and Oil, it shows 80 – 100 C, Air temperature sensor reading is in the range 50 – 60 C.
What else could it be?
Bad fuel, leaking injectors, carbon buildup, HPFP?
Appreciate any ideas/help!
