Results 1 to 16 of 16
    Aug 17 2018
    Montreal, QC, Canada
    Q7 why towing capacity is different
    Hey does anyone here know why in the 2014-15-16-17 model years the towing capacity dropped by 1000lbs?
    When compared to 2013 they have same engine choices same brakes almost same suv but the towing capacity is rated at 7500lbs. Why?
    Thanks
    Veteran Member Four Rings arjun90's Avatar
    Dec 27 2014
    2013 Audi Q5 3.0T
    The folks over at Audi Design and Engineering found a way to shave off 700 lbs in their newer Q7's--swapping out steel and using aluminum components. As a result of lighter design, they had to drop the towing capacity as well.
    Over the last few years, the Q7's, Q5's, and Q3's all have progressively gotten lighter. It's not just in this line-up, but across other car makers as well.
    Its the need to address fuel economy.
    Eventually, every car on the market will be using 100% recycled materials (from up to down), lol
    Quote Originally Posted by B6USPGUY View Post
    Thanks
    Current:
    | Audi Q5 (B8) 2013 (3.0T, Quattro) |
    70,xxx Miles
    | Audi A6 (C6) Avant, 2010 (3.0T, Quattro) |
    182,xxx Miles
    Gone But Not Forgotten:
    | Audi A6 (C5) Avant, 2004 (3.0L, Quattro) |
    221,386 Miles [April 2014 - March 2022]
    New genuine Audi/VW parts for cheap within the US - audiusaoemparts.com
    New genuine Audi/VW parts for cheap if you can afford the wait - oemVWshop
    Aug 17 2018
    Ohh I see, but the newer ones 2018-19 have increased capacity to 8500lbs🤔. So they decided to return to steel or just a higher aluminum gage?
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    Ohh I see, but the newer ones 2018-19 have increased capacity to 8500lbs🤔. So they decided to return to steel or just a lower-gauge aluminum?
    FTFY
    BTW, The Q5 line didn't lose any weight, though I'm not sure why, as that was supposed to be one of their design goals.
    Dec 27 2014
    2013 Audi Q5 3.0T
    More aluminum is being used over steel nowadays. The steel is still being predominantly used where chassis rigidity is extremely important. You can call it a hybrid type of design. I'm also sure added reinforcement was especially made on the Q7 rear-end.
    By using more thicker aluminum gauge over mild steel, you're able to compensate and increase towing capacity because of lighter materials such as aluminium being used
    Something tells me this is how Audi was able to finally make a change from hydraulic power steering to electronic steering in 2017 and later Q7 models
    Yeah, that still puzzles me, because there's not a dramatic difference in terms of curb weight between the Q5 and latest Q7
    Quote Originally Posted by SQive View Post
    FTFY
    Current:
    70,xxx Miles
    182,xxx Miles
    Aug 17 2018
    Thanks for the info, we are shopping for a Q7 and no one at the dealers can point out why lol. Funny thing is they all have the same idea that towing capacity is at 7500lbs and i get them confused when i mention that it's rated less lollll.
    Aug 03 2014
    WPB, FL
    Just to piggyback off what has already been said, while the type of metal used does make a difference, It’s mainly the weight of the vehicle that is the driving factor. Using aluminum does make the vehicle lighter therefore lower towing capacity, due to weight not due to aluminum itself.
    07 Q7 4.2 S-Line
    02 A4 B6 Avant - Sold
    Aug 17 2018
    Yes that really makes sense
    Established Member Two Rings djkyky's Avatar
    May 27 2015
    24 Audi Q3
    Estero FL
    There are a lot of numbers thrown around in this thread.
    My '18 Q7 with 3.0 is rated for 7700# towing. I have not seen the 8500# rating as mentioned above.
    2024 Q3
    Past A3, S4, S5, Q5, Q7
    May 31 2016
    Mexico
    I went to audis website and only see 7,700 tow capacity. Where are folks seeing 8,500?
    2016 Q5 3.0T GIAC Stage 2, HP tuners TCU tune with help from P3U and BG SQ5, aFe 11-10121 Pro Dry S filter, 034 Throttle body hose, AWE Cold Front Heat Exchanger
    93 octane tune (0-60mph 3.90 seconds (1 ft rollout), 0-60mph 4.12 seconds, 1/4 12.31 secs @ 112.40, 0-60ft 1.90 seconds)
    Race 104 octane tune (0-60mph 3.70 seconds (1 ft rollout) , 0-60mph 3.89 seconds, 1/4 12.09 secs @ 115.34, 0-60ft 1.88 seconds)
    Veteran Member Four Rings blackfunk's Avatar
    Jul 12 2012
    European tow ratings are different and should not be compared to US ratings. It has to do with the way the trailers are designed where if memory serves the location of the wheels affects the tongue ratings for what can safely be towed. Same cars otherwise though.
    Sent from my SM-N950U using Tapatalk
    Life has taught me never try to make something idiot proof, they'll simply come up with a better idiot.
    I'd agree with you but then we'd both be wrong.
    I have neither the time, nor the crayons to explain this to you properly.
    Junior Member Two Rings
    Oct 29 2018
    Roseville, CA
    Towing capacity MY2007-2015 was 6600lbs if you selected the factory tow package option from Audi, regardless of engine. MY2017+ 3.0T is rated at 7700lbs, and the 2.0T is rated at 4400lbs. Not sure where you're getting your numbers from.
    CURRENT: 2018 Q7 | Glacier White/Black | Prestige | Driver Assist | Cold Weather | 21”s | Tow
    PREVIOUS AUDI: 2007 A4 AV, 2008 A4 MT6, 2012 S4, 2013 S5 Stronic, 2013 S5 MT6, 2015 A3 Q, 2014 Q5 TDI
    PREVIOUS NON-AUDI: 2006 V10 TDI T-Reg | 1994 GT, 2001 Cobra, 2003 Cobra, 2017 GT350R
    Aug 17 2018
    Hey everyone just came back from vacation. Sorry my mistake about the 8500lbs tow capacity, I got mixed up with numbers when researching. I towed a loaded trailer the other day and was really impressed, it was as if I had nothing back there!.
    Jun 27 2011
    My 2017 Q7 w/ tow package is rated for 7700lbs. Not aware of any differences in any of the 4M Q7s for any year, aside from the 2.0t being rated significantly lower for obvious reasons.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Active Member One Ring larkyan's Avatar
    Sep 20 2020
    Virginia Ashburn
    Well, i was thinking at the beginning that they have a smaller towing capacity due tot the fact that the cars got lighter, however, when looking at the 2018-2020 models, again a lighter car, with the towing capacity getting increased. Sooo, that is pretty strange, i am not really sure why does it happen like that. However i am not really sure that there was any q7 capable of towing 8.5k lbs, that is just too much. I mean, dude that is almost 4 tons, that is something like 3.8 tons. That is a weight that you have to call towing companies for. In case you have to tow such a weight just call expresstowing.ie and let them do it, do not risk your cars.
    Jun 27 2011
    The tow rating is generally based on the hitch design and the chassis strength. The GVWR is determined by the factory and is how they calculate the towing capacity (GVWR minus vehicle weight). How they determine the GVWR is anyone’s guess but likely they have their methods of determining that maximum safe weight. The GVWR factors in vehicle weight but the weight isn’t a determining factor in tow capacity.
    So basically, if two of us have the exact same options, our towing capabilities are identical. If one of us has a ton of add-ons that add weight technically his tow rating is reduced. I would imagine Audi specs the worst case vehicle weigh and bases their tow rating on that for a given drivetrain because dealing with all the option combos sounds terrible just to move the needle 20-30lbs one way or another.
    What I’m getting at, I doubt there are any fundamental changes (nor will there be) that will alter the towing capacity for a 3.0t 4M Q7 throughout its run.
    Similarly, I would suspect a 4L Q7 didn’t have major towing capacity changes throughout its run that weren’t down to its engine. I’m not really an expert but there’s more to it than just the vehicle weight.
    -CP
    2017 Q7 3.0t
