Alright I went out with my multimeter and tested the wiring with the car on. Let me know if I did something wrong, this is my first time testing wiring using a multimeter.
These pictures show the wiring harness on the side that's plugged into the G65 sensor. I'll refer each contact point bottom to top as #1, 2, and 3, #1 is closest to the rounded side.
So with the engine on I tested each contact with both chassis ground and using #3 pin as ground. #3 with the red lead and chassis ground gave no voltage.
#1 pin reads as:
#2 pin reads as:
I also traced the wiring, it joined with another set of wires and ends at this connector:
I unplugged that connector and found this damage, but as far as I can tell it's just the connector housing:
I tested these pins for continuity with the other three pins on the G65 side:
I got a solid beep from 3 different pins, so it seems the wiring itself is OK.
My question is are these readings the correct ones? The multimeter shows mV instead of V when in autoranging mode. When I manually set the range to 000.0 V it shows 000.1 V for both pins 1 and 2. I plugged the G65 connector back and made sure I got a solid click. ECON light still stays on. I haven't reset the code with VCDS yet, I came back inside to grab my laptop and figured I post this up to see if anyone replies.
