Results 1 to 38 of 38
    Aug 21 2015
    2018 SQ5, 2010 Q5 3.2
    Naperville, IL
    Clattering in 3.2
    2010 Audi Q5 3.2 with 142k miles
    I replaced the valve cover gaskets and spark plugs. All went together without issue...so I thought. Upon initial startup there is now a clattering on driver side bank and is very noticeable with the oil cap off.
    I towed it to Audi and they said all was ok...no problem found. No codes. No abnormal noise and test drive is ok.
    We went to pick it up and while driving it home my wife said it feels heavy and sluggish. My guess is compression is lost in one of those cylinders.
    Attached is a video of the noise.https://cloud.tapatalk.com/s/5d367a01...722_201454.mp4
    Sent from my SM-N950U using Tapatalk
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    That kind of sounds like a valve is stuck open, which would also explain a compression loss.
    Aug 21 2015
    Naperville, IL
    That's what I was thinking too. Is compression test enough to diagnose? Or should the valve cover also be pulled to visually inspect?
    Also, is piston damage guaranteed? Or can valve be stuck open enough to not interfere with piston but still cause this noise?
    Apr 26 2014
    DFW
    A compressdion test will tell you which cilynder to look at, but you'll still need to pull the valve cover to really diagnose it.
    I'm sure the piston is damaged, but whether you continue to use it or not is your call, although probably not advised.
    Aug 21 2015
    Naperville, IL
    Assuming camshaft lobe is damaged, possibly rocker arm, valve, piston.....what can I expect for repair costs at a dealer vs independent shop?
    Aug 21 2015
    Naperville, IL
    Is it possible to have a stuck valve and not throw any codes or check engine light?
    Veteran Member Four Rings A U D I's Avatar
    Nov 13 2012
    Chicago
    Clattering in 3.2
    Quote Originally Posted by robd88 View Post
    Not really.
    I’m also not hearing what is a “stuck valve”. The engine would be running terrible all the time. The sound clip to me sounded normal, however after throttling the motor. I would double check over your valve cover work to see if something was damaged or not connected properly to start. I do think you might be over thinking this unless you dropped something into the motor that can be causing a issue. Try not to think the worst or mechanical problems because you just did the valve covers and spark plugs.
    Also, did you use the factory spec plugs ? Or which ones did you use ?
    Aug 21 2015
    Naperville, IL
    I went back to my dealer today and after speaking with the technician at Audi, I had him listen to the sound as well and he said it was normal. He also said that during the time it took me to do the work, the oil drained down in the pan so it may have taken longer to get up to the top during the initial startup. And if a valve was stuck open with no compression, the engine would be shaking and the check engine light and/or codes would be seen.
    I think I was trying to listen for any little abnormal sound during initial startup and got caught up in any sound at all. I took pictures throughout the process and did not remember anything broken or missing. Surprisingly no plastic connectors were broken either. It all went back together well.
    For the plugs and the gaskets parts, I bought them at my local dealer. I prefer to use OEM dealer parts as I justify the higher cost because I do the work myself and save on the labor.
    Thanks for everyone's input on this.
    Apr 26 2014
    DFW
    I swear. . .you could take an Audi into the dealer not running at all and they would say "that's normal." Over 99% of the time, that's the dealership's answer to every problem that comes through the door. That goes up to 100% if it might possibly be a warranty item.
    Aug 21 2015
    Naperville, IL
    Most likely I'll still pull the cover to visually inspect at a minimum. Then a compression test depending on what I see in the valvetrain.
    And if anyone with a 3.2 is willing to post a video or audio recording of the engine running with the oil cap off for a comparison that would provide another data point of "normal".
    Nov 13 2012
    Chicago
    Quote Originally Posted by SQive View Post
    Lol. Funny although too many times true depending on the level of techs.
    Aug 21 2015
    Naperville, IL
    Or if anyone with a 3.2 Q5 can comment on the sound in my video. Is it similar to the sound in your Q5 3.2?
    I would appreciate any feedback.
    Apr 26 2014
    DFW
    I don't care what engine in what car. . .that sound is not normal, and sounds pretty bad if I'm honest.
    Shame on them for giving you the brush-off, but it's what I've come to expect from my local Audi dealership as well.
    Aug 21 2015
    Naperville, IL
    If someone with a Q5 3.2 is willing to listen to their engine running with the oil cap off and verify if it does or does not make the same noise, that would be helpful and appreciated. Anyone??
    Aug 21 2015
    Naperville, IL
    While I agree that the sound does not sound normal, I cannot say with certainty that it is abnormal as I did not record the sound prior to servicing the vehicle. How many of us have actually did this ever? When you fill the engine with oil, the engine is usually off. The cap goes back on and the engine is started. Who keeps the cap off and starts the engine? Probably not many if any at all. So let's approach this as a matter of fact, and not opinion. I'm guilty myself, but trying to change my approach towards fact finding.
    Veteran Member Four Rings arjun90's Avatar
    Dec 27 2014
    2013 Audi Q5 3.0T
    This comment made my day, LOL ROFL
    It's so true
    Edit: Heck, Audi recommends their customers to change oil "at least" once a year or every "10,000" miles
    Guess what? We (us Audizine members) change the oil every 5,000 miles for the obvious reasons
    Current:
    | Audi Q5 (B8) 2013 (3.0T, Quattro) |
    70,xxx Miles
    | Audi A6 (C6) Avant, 2010 (3.0T, Quattro) |
    182,xxx Miles
    Gone But Not Forgotten:
    | Audi A6 (C5) Avant, 2004 (3.0L, Quattro) |
    221,386 Miles [April 2014 - March 2022]
    New genuine Audi/VW parts for cheap within the US - audiusaoemparts.com
    New genuine Audi/VW parts for cheap if you can afford the wait - oemVWshop
    Aug 21 2015
    Naperville, IL
    Anyone with a 3.2 Q5 willing to check their engine running with oil cap off to compare to the sound in my video?
    Nov 13 2012
    Chicago
    My opinion I gave was actually based on knowing these 3.2 motors well. It sounds okay to me and the parts you used does not make concerned. Maybe you want to check the spark plug gaps on that side of the motor in case you bumped one and closed the gap some ? Let us know if you find anything else
    Feb 03 2017
    Alameda, CA
    Sent you a PM a few days ago. Here's a video of normal 2012 Q5 3.2 engine noise, with oil filler cap removed, etc. Knock on wood, but our car has been running strong since Day 1 -- looks, feels and drives like new... 80K miles. I wind it up through 4th gear a few times a week on a quiet freeway and to date no signs of carbon buildup, etc.
    Good luck.
    Apr 26 2014
    DFW
    Quote Originally Posted by m3ma420 View Post
    Good luck.
    Yeah, that's normal injector noise.
    Aug 21 2015
    Naperville, IL
    Thanks for posting the video! I just received the PM that you were planning on sending me a video, but I never got it. I still haven't had a chance to get in there again...too busy with work and family stuff. I'll post back once I do. The direct injectors sure make a loud noise, but it doesn't sound like you have the same noise I'm hearing on mine with the oil cap off.
    If there was/is scoring on the camshaft or lifter, what should I look for or should expect to see?
    Nov 03 2010
    2019 Audi A5 Sportback, 1986 MB 560SL
    Fallbrook, CA
    From my limited experience, the direct-injection motors just make more noise. We've got a 3.2 Q5, and a 3.0 A4. The A4 with 215,000 miles ticks over much quieter than the Q5 with 120K. My guess is that you never really listened that close until after changing the VCGs and thought it was abnormal.
    Aug 21 2015
    Naperville, IL
    Quote Originally Posted by Turbo510 View Post
    That's what I'm still thinking. Did you listen to the video I posted in my original post #1? That clattering noise has me guessing if it's normal. I still feel I should get in there and check it out. I'll have time this weekend.
    Feb 03 2017
    Alameda, CA
    When you pop the oil cap something sounds off -- valve not seating just right, etc.?
    Good luck -- keep us 3.2ers posted.
    Aug 21 2015
    Naperville, IL
    I've got the cover off now and inspecting. The only thing I can see is a very slight mark on the exhaust cam lobe on the front driver side. The plugs look good...all even carbon burn since the recent change.
    The marks on the cam lobe cannot be felt with my nail.
    Sent from my SM-N950U using Audizine mobile app
    Nov 13 2012
    Chicago
    The marks are normal wear marks. Nothing to be concerned about. Did you find anything else odd ?
    Aug 21 2015
    Naperville, IL
    I see nothing else. All springs look good and not broken. No mysterious parts or fragments. There is a good gap between the cam position follower and the sensor...no interference.
    Not sure what else I can do besides put it back together and consider it all normal.
    Nov 13 2012
    Chicago
    See if your noise is still the same after you do reassemble it.
    Aug 21 2015
    Naperville, IL
    Quote Originally Posted by A U D I View Post
    I just put it all back together and the noise is the same.
    I really wish I checked this noise before I started any work at all. But lesson learned for the next time.
    Thanks for your help...I appreciate it.
    Apr 26 2014
    DFW
    I wonder if this could have anything to do with the cam stepper. These engines use Audi's version of VVT, where the cams can shift forward or back to a diferent cam lobe. Can you setup an oil damn on the bottom edge of the head and check it while running?
    Aug 21 2015
    Naperville, IL
    I thought about the VVT too when it was apart. None of the cam areas of contact looked worn and the cam followers the VVT uses looked fine too. How does the VVT work? Does it shift the cam at a certain high rpm to change the intake valve lift timing?
    Aug 21 2015
    Naperville, IL
    Here is a better video of the noise if anyone is interested.
    https://youtu.be/dIl84qoRk7U
    Jul 31 2019
    San Diego, CA
    My .02 Cents
    I have a 2011 Q5 with 3.2L engine as well, it has 135k miles. I recently switched to Mobil One 0w40 euro spec oil, and the engine started to burn a little oil as it was lighter than the 5w40 Castrol Synthetic. I found it to be half quart low on oil after driving about 3k miles. When I went to fill the oil level back up, I removed the fill cap while it was running and noticed loud ticking, like yours. After I topped it off it seemed a little less noisy.
    What type of oil are you using? Do you fill it all the way up to the tippy top? Do you use the dipstick or the MMI sensor to check oil level?
    Also about 15k miles back, my car threw a misfire cylinder 1 code. I replaced the plug and coil. Code came back the next day. Bummer. I did some research and found that most Direct Injection engines run the fuel lines at a very high pressure. It is critical that the injectors are clean. I ran some Techron fuel injection cleaner, cleared the code. Code has not come back since. Woot woot. I put a bottle of Techron in the tank once every three months. If you search Youtube for "Loud fuel injectors" you will find a few videos covering the subject. These direct injection engines seem to be known for loud injectors across lots of different brands.
    Sorry for the rambling post, hope you get it fixed soon!
    Aug 21 2015
    Naperville, IL
    Quote Originally Posted by Audifahren11 View Post
    I just changed the oil before replacing the valve cover gaskets and spark plugs. I usually use Mobil 1 or Castrol but this time I used Pennzoil Platinum Euro 0W-40. It runs smooth, no vibration, just this noise when removing the oil cap. I'm still not convinced there is something wrong aside from my opinion that it is just not sounding right. I use the MMI to check the oil level and always have checked it that way. After the recent oil change I put in 6.5 quarts and it showed full.
    Would it be possible for you to post a video of your 3.2 running with the oil cap off? I'd like to listen to the noise yours makes as a comparison.
    Nov 13 2012
    Chicago
    FYI
    0w-40 is not lighter then 5w-40. It’s just the cold fluid flow ability.
    The 3.2 oil change should be at 7 quarts. If you only put back in 6.5 you might want to be draining it longer or pumping more out. Penzoli Euro got good level ratings also.
    Aug 21 2015
    Naperville, IL
    FYI
    I put in 6.5 because I overfilled it once and I'm not gonna go through that again. It burns about 3 quarts every 10k miles anyways so I'm always checking the level and adding as needed to keep it in the correct range on the MMI.
    Jul 31 2019
    San Diego, CA
    Here is a video- https://youtu.be/TV8HaCM5aYA
    Aug 21 2015
    Naperville, IL
    Thank you! I can hear the same noise. Another data point for normal.
