Results 1 to 9 of 9
    Aug 30 2016
    Los Angeles, CA, USA
    water pump - clean mating surface and silicone?
    Hi,
    I'm in the process of changing my water pump and I'd like your opinion on the following:
    1) how best to clean the mating surface of the engine block
    razer blade? scrub pad?
    2) should I use some type of silicone sealant on the gasket?
    Blauparts says no sealant if gasket is paper, but ours is a rubber one (https://www.fcpeuro.com/products/aud...ring-06j121119)
    3) should I flush out all the coolant?
    how do I get all the coolants out if there's only a drain plug on the bottom of the radiator? there must be some left in the engine/water pump/pipes/hoses
    Thanks in advance.
    Alex
    Jul 16 2018
    Atlanta
    The only thing the repair manual says is coat o-rings with coolant. I don't see any need for any kind of sealant in the procedure.
    It also mentions to make sure both centering pins are installed in the block.
    And on new pumps there's a cap on the cog wheel that the toothed belt goes on? That should be removed.
    I think for cleaning the mating surface, I'd do it just like for the intake manifold.
    Brake clean (non-chlorinated) applied with a towel, scrub pad like you showed, and plastic prys for the stubborn. Razor blade, maybe but be damn careful.
    How to fill the system? There's a 6 page process in the repair manual, using tools no normal person is likely to have.
    So I no guidance on the fill and burping process without said tools.
    The manual does say "don't reuse dirty coolant", and "do not reuse coolant if the radiator, heat exchanger, cylinder head, head seal, or block were replaced". You're just replacing the pump. If the coolant looks fine, reuse it and don't worry about what's left in the system.
    Veteran Member Four Rings Spawne32's Avatar
    Nov 20 2016
    scotch brite if necessary, razor blade should suffice, although there shouldnt be much at all of any gasket residue as its a viton gasket. No sealer required, and you can just drain through the bottom of the radiator where the plug is on the lower hose and refill as necessary, no need to flush as your draining most of the block anyway. Unless your coolant is rat ass nasty.
    Feb 15 2016
    Cambridge,Ontario
    there wont be residue of any kind as there is no gasket, just an oring , the only think to worry about will be if it leaked past the seal there might some corrosion of the block sealing surface. just use the scotch bright to clean it up and slap on the new one. edge motors uses a spray on sealant that wont hurt but i didn't bother and it has been fine.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Feb 24 2004
    Minneapolis
    I didn't use any sealant. I used a razor blade to clean the surface. It left no scratches behind on a cast iron block. No leaks here.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Aug 30 2016
    Thanks for all the replies. When I took the water pump off, the mating surface looked fairly clean. Very little residue from the o-ring or any dried up coolant.
    I will proceed with some scotch pad scrubbing and then some brake cleaner to make sure surface is clean.
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by findalex View Post
    yeah you will be fine.. just dont over torque those bolts. i remember it being low as the part is plastic.
    1976 Yamaha XS 360
    Aug 30 2016
    Yea I think they are 9 NM or something. https://images-na.ssl-images-amazon....1kxaNa02CL.pdf
    Feb 15 2016
    Cambridge,Ontario
    exactly , i used a smaller inch pound torque wrench to be more accurate ..
    1976 Yamaha XS 360
