Results 1 to 20 of 20
    Veteran Member Four Rings AUDIS$'s Avatar
    May 01 2007
    NH
    Overboost problem
    Had my motor out and replaced the turbos with F21's, running AWE stage 3 tune with green top injectors. Hitachi MAF. Car runs well but seems to be overboosting. Even if i change to stock mode. Things i have done to troubleshoot this problem-
    1) Checked wastegate lines, used bike pump to apply pressure. made sure the rods were both moving.
    2) Unhooked the N75 valve Saw boost pressure max out at 10-12psi
    3) Replaced with new N75 valve.
    4) Tried Changing both ECU tunes Stock/pump still boosting well past 25PSI
    I have not done a pressure test, at this point that will be next. anything i am overlooking?
    Here is a log of blocks 114/115/003 I am new to logging so some of this is foreign to me.
    https://docs.google.com/spreadsheets...it?usp=sharing
    2000 Audi S4
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    You aren’t tuned for the cracking pressure your F21s are set at.
    May 01 2007
    NH
    Quote Originally Posted by CELison View Post
    really, so its a matter of getting a tune specific for the F21's? or do you mean physically adjusting the wastegates? Also i would think in stock mode the ecu would tell the n75 the wastegates need to open?
    2000 Audi S4
    Veteran Member Four Rings m_haiser's Avatar
    Apr 24 2011
    2012 A6 Prestige, 1998 Jeep Cherokee XJ
    Central Willamette Valley
    Had the same thing happen. F21 wastegates are usually set at 14psi. You can tune to compensate or adjust wastegates. Given your smallish injectors I would advise adjusting the gates.
    Sent from my SM-J737T1 using Tapatalk
    It's to the point where all the problems just run together in a spider web of disappointment and mush.
    -CELison
    May 01 2007
    NH
    Quote Originally Posted by m_haiser View Post
    Thats what i dont get, if the cracking pressure is at 14psi why am i able to boost past that point with the N75 plugged in. isnt the tune or for that matter the stock ecu saying "there is 14psi of boost time to open up the wastegate"
    2000 Audi S4
    Apr 24 2011
    Not quite. It goes by n75 duty cycle. Say on a stock engine it takes 80% duty cycle to make 10psi well because your car THINKS it's got stock wastegates its going to use that same 80% which would make you boost closer to 20 or 25. You car doesn't use the n75 as an on off switch but rather modulates it for a smoother power delivery
    -CELison
    May 01 2007
    NH
    ok, That makes sense now. thank you!
    2000 Audi S4
    Jun 14 2007
    2000 S4
    Connecticut
    What turbos did you have before? RS4-K04s? Why the change?
    May 01 2007
    NH
    K03's before.
    2000 Audi S4
    Jun 14 2007
    2000 S4
    Connecticut
    Quote Originally Posted by AUDIS$ View Post
    K03's before.
    Oh okay.. So you swapped in F21s during the engine pull and bought an AWE fueling kit to go along with it? Just FYI, you are leaving power on the table.
    May 01 2007
    NH
    so i have heard, :( im contemplating selling the ecu and injectors and going with a tune from blake and 52# injectors. Thoughts?
    2000 Audi S4
    Jun 14 2007
    2000 S4
    Connecticut
    Definitely the right decision to sell what you have and go the custom tune route.. Once you start changing up the hardware outside of what AWE designed their kit for, or any kit for that matter, you're going to be losing power from the adjustments that the ECU will be making to try and keep things kosher so the car at least runs. The ECU will do a pretty good job of keeping things in a state so that you can drive the car, but when it comes down to WOT you really need the hardware the tune was designed around. Even though F21s are pretty similar to K04s, they're different enough that as already mentioned N75 duty cycle will be most likely requesting too much boost from those turbos, the fueling won't be right, etc. If you've already invested (VERY loosely speaking ) in swapping the turbos, do yourself a favor and get a good tune on it.
    Veteran Member Four Rings erykv1's Avatar
    Jul 01 2014
    'murca
    @Corradovolksb can also hook you up with what you need
    we are so far along with these cars and the ME7 ecu there is no point in running an off the shelf tune anymore
    Apr 24 2011
    Quote Originally Posted by erykv1 View Post
    Agreed. Get a wideband and get the power you paid for with those f21s. Mine was base tuned by Daz back in the day and was a pretty serious machine for only being stage 3-
    -CELison
    Dec 06 2012
    hinsdale
    Thanks guys! I think that is the route im gonna go.
    Hopefully get it running well soon. A couple pics. Have a few things still left to install
    Sent from my SM-G950U using Tapatalk
    Mar 26 2018
    los angeles
    What bi-pipes are those?
    Veteran Member Four Rings Silverex's Avatar
    Nov 13 2018
    Ocean city NJ
    Stock with some CF wrap?
    Jun 07 2005
    Shepherdstown, WV
    Apr logo on the passenger side pipe
    80 rabbit pickup, 98 TJ 4bt cummins, 00 180TTQ 6spd, 02 Freelander, 03 Allroad 2.7t 6spd swap now with K04s, 06 A3 2.0T w/GT3071R (2012 JSW TDI and 2015 GSW TDI now in TDI purgatory )
    May 01 2007
    NH
    Quote Originally Posted by zachattacker View Post
    APR Bipipe Carbon dipped.
    2000 Audi S4
    May 01 2007
    NH
    Got the wheels on, lowered..need a clean filler plate..52# injectors and 3bar MAP should be here tomorrow.
    2000 Audi S4
