So a few thoughts from a guy who runs Slotted on all 3 of my cars - and 2 are DDs - driven EVERYDAY (even in winter).....
#1 - As noted Drilled is the highest concern for issues - slotted is just fine - I've never had any issue with cracks/or breakage at all over thousands of miles - just make sure to pick a well known rotor brand - so you don't end up with a knock off Chinese product....
#2 - As to rusting - simple - Choose a rotor that offers at least a "Zinc" coating as well as one that has painted / coated hubs and not just zinc coating the rotor surface
#3 - Technically a blank rotor has the most surface area - so likely the "Best" option as braking is all about surface area.... But a well designed rotor will dissipate heat well anyways (proper veining is important here) - but I do find slotted helps to create edges that seem to clean the pads - and it does also seem to help in wet conditions to keep water at bay too - Stopping power is not an issue at all - and I drive my cars like they're stolen all the time....
I suggest avoiding drilled - but slotted is just fine to give that little extra for appearances - as well as a good trade off for some added pad cleaning / water dissipation. All my cars have performance pads (Porterfield R4S is my choice) and stainless lines added as well.
I suggest Stoptech Cryo Treated Rotors - the Cryo Treatment adds protection to help keep temps down as well as keeping the rotors rust and dirt free for a long time - they still look almost new after 2+ years and 2 winters on my cars.
