I just finished a teardown of a 2.0TFSI. A few observations.
1: At 140,000 miles it had some clogging of the pickup tube but is was not all that bad. Over its life the motor had eaten at least one fuel pump cam follower (see photos).
2: The 2.0TFSI engine is generating more metal than other designs (fuel pump cam and follower). Not all of that metal gets filtered and some ends up embedded into the bearing surfaces (filters are not 100% efficient, some junk always gets by). I found a few particles in the mains, nothing too bad, the bearings have good embeddability and the crank did not get scored.
3: Not all bearing surfaces handle metal equally well. The mains and rods are designed to have a good level of embeddability. Bearing surfaces generated by machining a casting dont tolerate debris as well as the mains and rods inserts that are made from multiple layers of soft metals on a hard backing.
4: When the machined in bearings in the head or the oil pump assembly encounter debris that don't readily embed that particle stays proud and scores the the journal of the shaft.
That generates more debris and can cause a cascade effect that wipes out the entire bearing surface.
5: Softer shafts on cams (and possibly balance shaft units) are less tolerant of debris ( compared to a heat treated steel crank). The poor embeddability of the housing can also cause particles to embed in the camshaft and basically machine the housing away.
6: Balance shafts run at 2X engine speed and can be more susceptible to oil starvation (Mitsubishi 2.6 engines were known for this). It does help that Audi reduced the journal diameter so that the surface speed is lower.
7: The higher particulate contamination of a GDI engine stresses the oil more and can lead to pickup tube clogging. Especially true if the oil quality is an issue or if oil changes are skipped. GDI engines don't vaporize fuel as well as port injection engines, that creates a greater soot contamination that the oiling system has to deal with.
8: On engines that are using a lot of oil because of the piston ring problems its possible that the pump is sucking air now and again. That is really tough on bearings and can cause cavitation damage ( small chunks of bearing flaked out).
9: Fuel contamination from poor injectors reduces the lubricity of the oil. That can also cause cavitation damage.
10: If you combine fuel contamination with a partially clogged pickup, cavitation becomes a lot more likely. Cavitation reduces oil pressure and causes bearing damage.
11: Thickened old oil is more likely to bypass the filter on cold start (or increase the amount of time and volume of the bypass). That allows more cam follower debris to circulate, increasing the likelihood of damage.
Solutions:
1: Reduce the metal loading on engine ( keep an eye on the cam follower or upgrade).
2: Good maintenance, regular oil changes and check the oil for high fuel contamination.
3: Make sure your injectors are working right if the motor runs rough find out why.
4: It's possible that the higher particulate loading of a GDI engine loads the filters up faster and that increases the tiem the that leverlthe the filter gets bypassed. See not #2 on good maintenance just following the factor recommendations may not be enough ( i know that everyone here already knows that).
5: The dual inlet pump pickup is designed to address pump starvation and cavitation damage be allowing a second passage. A good first defense is to keep the pump pickup from getting clogged in the first place.
Summary:
The pump and balance shaft system itself is a good design , however it is living in a very harsh environment. If it's run with oil that doesn't sludge the pickup screen and normal level of metal contamination it will last as designed. As a side note my other car is a Dodge Raider with one of the original balance shafts systems. I have been running various versions of that 2.6 liter with a turbo for a really long time (since 1990). Done right the balance shafts make for a super smooth large four. Despite being a 1987, the four in my Raider is noticeably smoother than the 1.8T. If you want vibration try the 2.6 with the balance shafts removed. The amazing thing is some people can't tell the difference. Same debate we get on the Audi engines but this one is not even a little bit subtle, its vibrate the mirror enough so you can tell what vehicle is behind you bad. Some people think its fine not to have them.
