Results 1 to 12 of 12
    Jul 10 2019
    2009 Nissan Altima (winter daily)
    Richland, WA
    Best bang for your buck slotted and drilled rotors and break pads... GO!!
    I've had my 15 S5 for about a month now and am looking at replacing the rotors and break pads (that hopefully produce less dust)...
    I've found quite a few candidates but I wanted to use this knowledge base as a resource before I pull the trigger on anything.
    Current: Monsoon Grey 2015 Audi S5 PP; 034 Stage 2+ E40; 034 TCU; 190/57.5 PR; APR Ultracharger; Jokerz Ported Blower; IE HPFP; AWE Coldfront Excahnger and Reservoir;Tampa Test Pipes w/ JHM Baffled HFC Downpipes w/ AWE touring cat back; Bilstein PSS10 coils; EuroCode sways; Vorsteiner VFF-104; Stoptech slotted/drilled rotors; all the chassis bracing
    Past: 2017 Fully Built STI (700+ whp) but decided to get rid of the hot wheels car for something more classy/comfy
    Established Member Two Rings S5Black's Avatar
    Mar 24 2019
    2014 Audi S5 S-Tronic, 2020 Jeep Grand Cherokee
    Nevada
    I've got the ECS V4 drilled and slotted rotors with EBC red stuff pads as a kit from ECS, couldn't be happier with this setup. They had a sale on the kit when I got mine.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    I have always been a fan of the Hawk HPS brake pads. Used them for years. They are not dust free but they are lower dust than the OEM pads. This time I decided to try something different and I installed the Akebono pads on my A5. So far I am totally satisfied. The performance is fine for a street application and the dust is practically nonexistent. Akebono is now going to be my pad of choice.
    Established Member Two Rings Twotonicnite's Avatar
    Mar 21 2016
    NW Indiana
    I have the Hawk HPS on currently and couldn't be happier with the performance, and low dust. I've yet to try Akebono but a lot of folks here have the same opinion as Old Guy. I have the JHM 2-piece slotted rotors, which are significantly lighter than stock, and supposedly run cooler due to the vane design. Not a fan of drilled rotors after a bad experience with cracking years ago.
    Twotonicnite
    *2015 S5 Prestige, black optic, manual, GIAC Stage II Tune, Vorsteiner V-FF 104s, Bilstein B16 w/ IRC Ride Control coilovers, Milltek exhaust, 034 rear swaybar, endlinks, differential, & transmission mounts, ECS carbon intake
    *2016 Q5 Premium Plus 3.0T, S-Line, Exclusive Derby Green Pearl
    *2019 A6 Prestige, Mythos Black, Night Vision
    *2008 Toyota Tundra SR5, bone stock
    Veteran Member Three Rings carrrnuttt's Avatar
    Mar 24 2019
    2013 Audi S5; 2009 Mazda RX-8 R3; 2022 Dodge Durango R/T AWD
    Phoenix, AZ
    I got the Power Stop Z26 Street Warrior Brake Kit: https://www.powerstop.com/product/po...&mk=AUDI&mo=S5
    Has worked great for me so far.
    2013 Audi S5 Brilliant Black 6-spd Sports Diff
    APR Stage 2 Ultracharged (93 tune) - CPS Cooler - Carbonio Intake
    ECS light flywheel
    Spec Stage 3+ Clutch Kit
    JHM Short Shifter
    034Motorsport Insert Kit - Trans Mount
    • Custom Exhaust
    Veteran Member Four Rings Neil F's Avatar
    Jan 13 2017
    marlton/nj/usa
    Myself and other are happy with akebono. I have had them for over 2 years right after I go my S5. Virtually no dust
    Veteran Member Three Rings Brozee's Avatar
    Oct 12 2009
    Oxford, MI
    I use Akebono on front and back with Adam's rotors.
    2013 S5
    APR Stg. 2+ Ultracharger, DSG, CPS | Full AWE Touring Exhaust | Roc-Euro Intake | H&R Coilovers | MRR GF6 | 034 Trans + Diff + Subframe Inserts | Apikol Rear Diff Mount | CR-15 | Full Eurocode USS Suspension | DEVAL CF Rear Diffuser | Adams Rotors / Akebono | Stoptech SS Lines | RS5 Grill | Tint | LED Interior, Reverse + Turn | HID Fogs | Escort Max 2
    Veteran Member Four Rings HazeMyth's Avatar
    Jul 17 2015
    Colorado
    I've had Hawk HPS pads on the Evo since about 2007 or 2008. I also had them on my STI for nearly the entire 10 years I owned the car. Always was super happy with them, but they can get pretty loud in certain conditions. Certainly not as loud as stock S5 pads though.
    2013 Audi S5 - EPL Stg 2 E40 ECU/TCU, AWE Track 102mm, RocEuro intake, etc.
    2014 Audi Q5 S Line
    2011 Toyota Tacoma TRD Sport - Lifted, reinforced, and slow
    2003 Evolution VIII - HKS280, FBO
    2004 Subaru STI - Stg. 2 (Sold)
    IG: @MrHazeMyth
    Sep 28 2010
    NW NC / DE
    Our most popular combo is Hawk HPS pads with Stoptech slotted rotors.
    Dec 28 2006
    Western Maryland
    A great combo for sure! I'll continue to use Hawks on the A4 since that one is my "go kart" for when I want to get a little sporty behind the wheel ;-)
    My A5 is used more as a cruiser so the quietness and dust free performance from the Akebono's fits the bill better for the A5.
    Mar 11 2007
    Colorado Springs
    I concur...
    2022 Q8 S line Prestige Stock
    2012 A7Plus APR Stage II+ UC
    2012 A8L 4.2
    Still own them all...
    Mar 18 2015
    2015 GL450
    IL
    This is what I’ve got and have been pretty happy. Thinking of giving the ECS 2 piece a try with the Akabono ceramic pads. I like the idea of reducing 6lbs per front and 3lbs per rear.
    Sent from my iPhone using Tapatalk Pro
    2016 S5 6MT - Brilliant Black, P+, High Gloss Black, Sport Dif, B&O, Tech, Nappa
    Engine: GIAC Stage 2 & SC Pulley / ECS Carbon S-Flow Intake
    Suspension & Wheels: H&R Street Performance Coilovers / Vorsteiner VFF-103 (Carbon Graphite)
    Exhaust: AWE Touring
    Cosmetic: OEM RS5 Grill / PPF & CQuartz Finest Coating / 35% Pinnacle Tint
