Results 1 to 31 of 31
    Veteran Member Three Rings AudiC7Owners's Avatar
    Jan 14 2016
    Wilmington, NC
    DIY Video: How to Jack up your C7 & Install Wheel Spacers
    Put together a quick video on how to properly jack up your C7, as well as how to install wheel spacers. I know these are trivial things for most people that have been doing work on their own cars, but my youtube got a surprising amount of requests on how to jack up and support a C7.
    Tools List:
    -Breaker Bar or Impact Gun
    -17mm Socket
    -Universal Audi Polyurethane Jack Pad Adapter (https://amzn.to/2XNNp9Z)
    -Jack
    -Jack Stand(s)
    -Wheel Hanger/Wheel Guide(s)
    -Gloves & Knee Pads
    -Various tools provided by your roadside tool tray under your spare tire
    Noteworthy Information:
    -This is an easy DIY, even for beginner at home hobbyists as long as you have the right tools.
    -Make sure the car is on sturdy Level Ground.
    -Remember to never use the widowmaker emergency jack provided by Audi unless it's an emergency situation... and never get under the car while using it without something else being there to support the car in the event that it fails.
    -Always Use Jack Stands to support your car while working on it. Never trust the jack by itself.
    -If using a breaker bar, remember to loosen your wheel bolts before lifting the car.
    -Use the provided Wheel Guide (found in your roadside tool tray under your spare... it's plastic) to guide the wheels onto the hub and make life easier getting things lined up. I suggest picking up an extra one that is metal so you can have 2. Much better to have 2.
    -When installing wheel spacers, make sure you buy the appropriate length wheel bolts. Your stock wheel bolts are 27mm. Take the width of your spacer you are using, and add that to the length of your OEM wheel bolt, and that will give you the length of wheel bolt you need to properly run your new spacers. Example: You are installing 20mm spacers to the rear. 27mm + 20mm = 47mm long wheel bolt needed.
    I have some more videos getting ready to come out, including DIY's on installing front/rear sway bars, installing a P3 Digital Gauge, and changing your oil. If any of my videos have been helpful to you, I'd appreciate it if you subscribed and gave them a thumbs up so others can find them on the youtubes.
    You can also follow my C7 Instagram page @AudiC7Owners
    Kwikstix DIY Video Thread
    //2013 A6 Prestige 3.0T |IE Stage 2 Single Pulley | Berk TCU Tune | Injen Intake | Cende Valvetronic Full Exhaust | Gutted OEM Catalytic Converters | Merc Racing HX | H&R Sport Springs | 034 Motorsports Control Arms & Engine Mounts | Eurocode Drivetrain Mount Inserts | Eurocode Front & Rear Sway Bars + End Links | P3 Multi Gauge | StoneCarbon2009 RS Style Grille //
    Feb 03 2016
    Cleveland
    Those panels pop off so you have better access to the frame rail without harming the skirts. FYI.
    Jan 14 2016
    Wilmington, NC
    Quote Originally Posted by ItsLarryG View Post
    Good to know! I haven't damaged mine at all doing it this way, but I'll add that in the notes on the description.
    Feb 03 2016
    Cleveland
    Quote Originally Posted by KwikStix View Post
    I figured it out through trial and error. Just trying to spread knowledge. Good vid
    Veteran Member Three Rings Vinng86's Avatar
    Jul 20 2018
    Toronto, ON
    Great video as usual, didn't think about the frame rail at the back for placing the jack stand. I had difficulty at the front, did you find any place to put the jack stands near the front jack points?
    Also, I have a few additional pointers
    - Piece of flat wood under the jack stands will prevent damage to your driveway (especially if you have asphalt driveway)
    - For the front jack points, remove the trim piece (around 3:01) around it or you might damage it. You can easily pry off with a screw driver.
    - The breaker bar in the spare kit is garbage. I broke mine the first time I used it and only managed to get 2 bolts off. Buy a decent one and keep it in the trunk.
    - A decent torque wrench is super valuable to make sure you don't compromise the lug bolts. Get one!
    2014 Audi A6 3.0T Technik(Prestige) S-line w/ Black Optics
    Jan 14 2016
    Wilmington, NC
    Quote Originally Posted by Vinng86 View Post
    The frame rail runs the entire length of the side side of the car. So it's pretty much the exact same up front that it is in the back.
    Good tip on the wood... I use 2x4's to get my car up higher when I'm under it working.
    LarryG mentioned the jack points trim piece comes off too... I truly didn't know that. Gonna throw it in the description of the youtube video.
    I really don't consider the tire wrench in the roadside kit to be a "breaker bar". Yes you can break the lug bolts with it, but it's nowhere near as easy as an actual breaker bar that gives you good leverage over the bolts.
    And yup... while I didn't show it in the video, I did mention to torque the bolts to 90 ft/lbs.
    Thanks for the feedback!
    Mar 04 2018
    Saab 9-3’s
    Philadelphia PA
    Follow you on instagram, our cars are literally twins lol (minus my lack of ACC)
    Veteran Member Four Rings AudBoost's Avatar
    Apr 05 2005
    Tampa, FL
    Great job on the video!
    Also, a little anti seize on the back of the spacers is not a bad idea to prevent the spacers from getting stuck to the hub.
    2016 S6
    Jan 14 2016
    Wilmington, NC
    Quote Originally Posted by Saabya6 View Post
    Haha nice!
    Quote Originally Posted by AudBoost View Post
    Didn't think about that.
    Senior Member Two Rings gkott78's Avatar
    Apr 22 2018
    Metro Detroit
    Thanks again for posting this vid. I was installing my RS grill and was boggled about where to put the jack stands in the front. I was so concerned that I actually pulled the tire off, unbolted the bumper and put the tire back on then lowered it back down while i did the work (both sides). I wish you would have posted this two weeks prior.
    I need to take a look at the front again, as I put the jack stand just behind the jack point and lowered slowly only to see it flex and immediately lifted it back up.
    2018 SQ5 Prestige - 034 Motorsports Stage 1 E85 ECU, Stage 2 TCU, 034 Carbon Intake, Rev 9 Intercooler, 034 Trans Mount Insert. Pending install CTS Turbo Catted Down Pipe, Stage 2 034 tunes R1 Concepts brakes and rotors.
    Jan 14 2016
    Wilmington, NC
    Quote Originally Posted by gkott78 View Post
    There is a lot of plastic under there that may flex slightly, but as long as the rail is resting on it you are good. I'll get a picture tomorrow of where I put mine.
    Dec 31 2018
    Illinois
    Great video! Thanks for sharing.
    Where the front grill come from?
    Jan 14 2016
    Wilmington, NC
    Quote Originally Posted by Laziebun View Post
    Look up StoneCarbon2009 on eBay. I have a video about it on my channel too
    Established Member Two Rings Four rings fan's Avatar
    Sep 10 2016
    Florida
    @KwikStix Thanks for the link to that jack pad adapter. Who knew that Audi would have such a funky shaped place to jack up the car. Perfect timing as I blew out one of the POS oem Pirellis P-Zero's today and I'm pretty sure my hole in the wall tire guy that I've used for years for other cars won't have an adapter that shape. One day shipping from both Amazon and Tirerack so I'll be good as new by Friday.
    2018 S6 Mythos Black Prestige
    Jan 14 2016
    Wilmington, NC
    Quote Originally Posted by Four rings fan View Post
    Glad I could help!
    Feb 21 2017
    St Louis
    I don't understand why you had the wheel on while installing the wheel bolts? I haven't ever done anything like this though ..
    2016 Mythos Black S6 | 20% Tint | APR Exhaust | DS1 Stage 1
    Jan 14 2016
    Wilmington, NC
    Quote Originally Posted by ry0t05 View Post
    Maybe I don't understand where you are coming from... but how else would you attach your wheel?
    Veteran Member Three Rings eurospek's Avatar
    Mar 15 2008
    Chicago
    Any suspension mods?
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    Perhaps he was confused because the car has lug-bolts and not lug-nuts. Myself I have been wrenching with my dad since the early 1970s and now on my own. My 2012 Audi was the first car I have ever had that had lug-bolts.
    Jan 14 2016
    Wilmington, NC
    Quote Originally Posted by eurospek View Post
    Sway Bars front and rear, but that's it. I am going to be replacing my control arms soon and when I do, i'll be putting on H&R lowering springs as well.
    Quote Originally Posted by Valpo A7 View Post
    Good point.
    Feb 21 2017
    St Louis
    TIL what a lug bolt is! I've only ever dealt with lug nuts on the stud...didn't even know this other lug bolt was a thing. When I was considering adding spacers to my car (hence why I watched your video), I was very scared about messing around with studs thinking it was pretty difficult/scary. Now that I understand what a lug bolt is and see your video in that light, this looks like a trivial job to do.
    My comment has to look hilarious from your point of view
    Senior Member Three Rings akingzkid's Avatar
    Mar 04 2018
    2006 Audi A6 3.2, 2014 Mercedes E350
    Virginia
    Same here. Lug bolts were new to me also as of 2 years ago when I got my first Audi. Using the little thing that you screw in to hold the tire on while removing the lug bolts is a must.
    Feb 21 2017
    St Louis
    Quote Originally Posted by akingzkid View Post
    When I saw him get that tool out in the video I immediately thought "ok what a waste of a tool"...just set the damn wheel on the studs. Duh. Why would you need to make it longer??
    Now I want to buy a 2nd like he recommended
    Jan 14 2016
    Wilmington, NC
    lol, glad we got all that sorted
    Nov 27 2018
    Valparaiso, IN
    When I first got the car I used the plastic false stud until I snapped it off. Now I can just line it up and lift the wheel in place. Once I start the first lug then it’s all good. I typically just run the lugs down with my impact and don’t mess with the life wrench or torque wrench. This past weekend I buzzed the backs on and checked with the torque wrench. Confirmed that my impact sets em right each time.
    I have a 1/2 inch drive ingersol rand air impact
    Established Member Two Rings DeRico's Avatar
    Aug 10 2012
    1993 Toyota Chaser, 2018 VW Atlas
    San Antonio, TX
    It took me a couple times to realize how you were asking that question.
    '13 C7 A6 Quartz Gray
    >APR Intercooler
    >Michelin PS4
    Feb 21 2017
    St Louis
    You'd be happy to hear (after my shameful question earlier) that I successfully jacked up and installed my spacers today. Went with 15mm on all 4 corners. Skipped the jack stands since I wasn't getting under the car - there was only about 20 seconds of floor jack failure risk on any one corner.
    In the process of finishing my garage - excuse the mudding and taping. IMG_20200601_201551.jpegIMG_20200601_202937.jpegIMG_20200601_202913.jpeg
    Feb 21 2017
    St Louis
    I'll lower it -17mm tomorrow on stock air. Was too exhausted tonight. 2 of the wheels were seized like a mother f***er and I left my rubber mallet at my brother's house
    Dec 16 2015
    Boston-ish
    Face away from the car, and back kick it like a horse, both sides of tire. Should only take a few hits.
    Mar 30 2018
    long island
    and apply some anti seize to the hub/spacer and spacer/wheel when reinstalling.
    2017 RS7 | Daytona gray pearl | DS1 | Mike's downpipes (catted) | Milltek non-res exhaust | SRM intake | AK racing lowering module | VS forged VS16 wheels | JHM turbo filter relocation | Blackout badges | Color matched side reflectors | Cquartz ceramic coating | 20% tint |
    Feb 21 2017
    St Louis
    Quote Originally Posted by daytona rs7 View Post
    Yup, thanks, I did that based on someone else in this thread. I painted a thin layer on the back....wasn't sure how much to really do.
