I recently picked up an Audi A3 2.0t automatic, I have been working on fixing small things on it and just today I ran into a new issue which I could use some help on. When I went out to start it today the battery was completely drained after sitting overnight, I threw a spare battery I had in it and it started right up and I went to work. When I went to leave work the battery was once again completely dead and the car had no power whatsoever. I got a coworker to give me a jumpstart and I was able to get it going to get home. I thought maybe my bluetooth fm transmistter was draining the battery so I unplugged it and went to check on the car about an hour later and once again it had no power at all. There doesn't appear to be anything on when turn off the car.
The other day I was working on the car and removed the battery and the battery tray and while I was putting it back together and tightening up the battery the socket wrench slipped and touched the two terminals of the battery together for a split second, the car started fine after this and it was only for a split second but Im wondering if that incident may be related to my battery drain and if so what areas do I need to check? Thanks in advance for any insight you can give me.
