Results 1 to 8 of 8
    Aug 17 2015
    Modded 06 Maxima, 02 Civix EX
    Stockbridge, Ga
    Supercharger Pulley Puller
    Does anyone have a supercharger pulley puller that can give me dimensions? I have access to a full machine shop with a lathe and a mill and a ton of scrap steel. I know they sell them and where to buy them, just want to try my hand at it.
    I have a ton of bearing pullers but it's a bit absurd to spend $250 removing a <$200 part 1 time.
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    The back of the s/c pulley is angled. A traditional puller will not grip it properly and will most likely slip. The good s/c pulley pullers are machined to fit into the seven grooves in the pulley itself, sort of like a mold would be for the pulley. That is where they grip. You would need an OEM s/c pulley to get those dimensions, I would think. That would let you make a clamshell that then would attach to your more traditional gear or pulley puller, or be machined with a threaded center section for your puller bolt to go through. You will be gripping the pulley from the sides rather than the back.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Established Member Two Rings WeeKenny's Avatar
    Jan 05 2015
    Scotland
    You can buy cheap supercharger pulley pullers, I got one for £12 from eBay. Because its not S4 specific it didn't fit without removing the supercharger, but I was doing that anyways to change the thermostat.
    Jun 21 2013
    DC
    Quote Originally Posted by MSq5 View Post
    Something like this should work, right?
    https://www.amazon.de/gp/product/B00...KR8XB7XF&psc=1
    Senior Member Two Rings scalbert's Avatar
    Oct 21 2004
    Woodstock, GA
    I have the APR pulley removal tool which I have loaned out multiple times.
    Feb 14 2017
    Gulfport, MS
    Quote Originally Posted by JS81 View Post
    Nope. Wish it would. Not even possible to put it in place and have room for the center bolt with the supercharger still on the car. And, you can't pull it from the back of the pulley. It will slip off. Nothing there flat to grip. You have to have some sort of shell to encircle and contain the pulley by its grooves or a two piece clam shell to grip it from the sides that then attaches to a threaded hole in the front.
    I have all sorts of pullers in my shop. Supercharger pulleys are a different breed. Conventional pullers will not get in this tight space and will not grip the pulley properly. There might be other ways to pull it if you have the supercharger completely off, but most of us will not be doing that.
    They are going to look something like this, or similar but with two clamshell halves. The one I rented from EPL looks just like the first one below. It grips the pulley grooves from the side and is very compact to allow it to fit onto the pulley with room to turn the center bolt.
    The APR version grips the inside lip of the pulley, front and back and forms a shell completely surrounding the pulley, rather than trying to grip the pulley from the outside back.
    See how this one relies on the internal ridges of the tool to fit precisely inside the supercharger pulley grooves?
    Two piece clam shell tool - same principle but completely enclosed around the pulley. Either works, but you must grip the pulley grooves or encase the pulley from the side between its front and rear flanges, rather than try to grip from the back.
    Jan 05 2015
    Scotland
    This is the type I used but you'd need to remove or at least lift the supercharger a little to have room for it.
    Aug 17 2015
    Stockbridge, Ga
    Quote Originally Posted by scalbert View Post
    Hey, I'm in McDonough. I didn't realize how close you were. I need to borrow that puller. I can compensate you. 404-271-8083 Riginald.
