Results 1 to 10 of 10
    Veteran Member Three Rings Batman0424's Avatar
    Dec 11 2015
    2020 SQ5, 2020 Audi Q3, and 2010 Mini Cooper S
    Hopewell, NJ
    Throttle Response / Lag Issue?
    I noticed this on the RS5 and now also on the S4.
    I always drive in S or M and 99% of the time I am in dynamic with the stability fully on or in sport. However, regardless of the setup, this issue occurs consistently.
    When trying to accelerate quickly, i.e., mashing the pedal to the floor from a dead stop, there is a noticeable lag in response. It is maybe 1-2 seconds where the car will start to move slowly and then take off quickly once RPMs climb up a bit. To be clear, this is not turbo lag - I feel the turbo kick in a bit after the car starts to actually accelerate - but rather a delay with the car responding to my throttle input. I have drive many turbo, SC and NA cars (both manual and auto) and never experienced anything like this before. My wife has a Tiguan (2.0 turbo) that does not do this at all. My GTI did not do this either (also a 2.0 turbo, but a MT). It almost feels like what happens when you try to take off with a MT and you don't give it enough gas - the car slugs forward a bit until the RPMs can climb and then it rockets forward. I hope this make sense.
    I have been searching and read about this topic for a couple days now, but do not seem to find anyone that has a solution. I tried a reset the throttle position with procedure I copied below, but that did not improve the issue either. Someone also mentioned an updated map from the dealer, but no additional details were provided on what this was (no TB provided).
    Any input or thoughts would be great. I will schedule an appointment with Audi soon, but was hoping to get some information here first.
    This is the procedure I referenced above:
    -With the ignition off, push the throttle to the floor and hold it there
    -Turn on the ignition, but don't start the engine (i.e. press the start button without simultaneously pressing the brake pedal)
    -With the ignition on, continue holding the throttle down for about 10 seconds
    -Turn off the ignition and then release the throttle
    2020 Audi SQ5
    Veteran Member Three Rings thermobryan's Avatar
    May 30 2018
    SoCAL
    Just get a pedal tuner, that fixed the issue for me.
    Dec 11 2015
    Hopewell, NJ
    Quote Originally Posted by thermobryan View Post
    Which one did you purchase?
    2020 Audi SQ5
    Veteran Member Four Rings HyperM3's Avatar
    Mar 20 2004
    Lawrenceville, NJ
    I miss cars with actual throttle cables...
    21 S5 Coupe - RacingLine strut brace/034RearSwayBar/CTSTransMount/034 tune/VPS Res Delete/CTSIntake
    10 S4 (gone),13 S6 (gone),14 S6 (gone),14 S6 (gone),16 S6 (gone),17 A4 (gone),19 S4 (gone)
    20 BMW R1250RS
    ACNA Lifetime Member - 26690
    Respond to a post with an answer, they will keep asking questions. Teach them how to RTFM, they will learn to help others.
    May 30 2018
    SoCAL
    DTUK Tuner, not sure if they're in business anymore. I think there are a few around.
    Established Member Two Rings struong's Avatar
    Jun 10 2019
    San Diego, CA
    You can read more on the DTUK Tuner on Yabi's build.
    I think this is the one
    https://www.pedalbox.com/us/audi/a4-.../pedalbox.html
    I'm also looking for a deal on it...
    Senior Member Three Rings mobE's Avatar
    Nov 26 2018
    '18 GMC Sierra Denali ultimate
    IL
    I definitely I agree it's more of a pedal/computer thing. That input lag is annoying! Once the car starts to go it's quick.... I've been trying to hold out for a real tune expecting stuff like this to be fixed but I'll likely get a pedal box myself.
    '18 s4, under construction!
    Senior Member Two Rings LaZyB0ne's Avatar
    Mar 16 2019
    San Diego, CA
    PM me if interested....I'm selling my pedalbox to help pay for an ecu tune.
    In addition to things mentioned here...I would highly recommend this. I feel like this has eliminated so of the lag from a stop, no way all, but definitely feel the delay is less than before.
    https://store.034motorsport.com/dens...s5-q5-sq5.html
    Veteran Member Three Rings Yabi's Avatar
    Mar 30 2018
    91 Cadillac Brougham, 11 Toyota Prius 5
    Raleigh-Durham-Chapel Hill
    Quote Originally Posted by struong View Post
    Right on, struong! The PedalBox greatly reduced the lag feeling from the car. For a detailed review, you can check out my post here. As mentioned, DT-Power isn't around anymore but ChipTuning and DTE Systems definately are. Their official US website is: https://www.chiptuning.com/
    Alternatively, one can consider the Forge Motorsports Atomspheric Dump Valve as an option. Mops mentioned it helped reduced throttle lag in this post. Plus the ADV's have a cool sound they make (video in link).
    HTH,
    y.
    B9 S4 Prestige build and photo log | IG @tag_yabi | My YouTube Car Channel: Real Ridez
    Dec 11 2015
    Hopewell, NJ
    Thanks all, I’m going to start with a pedal box (from Mops) and then go with the Forge.
    I’ll post back once I have it installed.
    2020 Audi SQ5
