Results 1 to 17 of 17
    Junior Member Two Rings skeeterlaflare's Avatar
    Mar 19 2019
    Maryland, USA
    B8 S-Line Struts & Shock Issue!
    Hey Guys,
    I Have A 2012 A4 2.0T S-Line. Last Night When I Was Driving I Heard A Loud Metal Sound. I Thought I Ran Over A Steel Plate In The Ground (From Road Work) But When I Exited The Car, I Noticed The Passenger Side Front Was Dropped Almost To The Tire.
    Below Are Pictures Of The Issue & How It Currently Stands. All Advice & Feedback Is Greatly Appreciated. Thank You, Do Your Thing Audi Zine!IMG_9285.jpgIMG_9284.jpg
    Veteran Member Four Rings Novarider's Avatar
    Jul 02 2017
    Knoxville TN
    Pull the wheel off and look around. Could be a mount, spring, bolt etc.
    2011 A4 Avant Prestige S-Line
    Mar 19 2019
    Maryland, USA
    Quote Originally Posted by Novarider View Post
    Alright, Thank You. Another Question - What Caused This To Happen? How Much Will It Cost To Fix Approximately? Feedback Appreciated!
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by skeeterlaflare View Post
    Broken spring. No idea on cost. Springs themselves are cheap. It's about the labour. Do not take to Audi unless you have CPO .
    Any suspension shop can fix this . Do both sides
    Sent from my SM-G973W using Audizine mobile app
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Mar 19 2019
    Maryland, USA
    Ok Thats Exactly What I Thought It Was. Ill Just Go Ahead And Replace All 4 Of The Springs, Or Do You Think I Could Just Get Away With Replacing 2?
    Thank You!
    Established Member Two Rings colorado.a4's Avatar
    Dec 04 2018
    how many miles on car?
    did you hit a bump or pothole?
    I知 an audi tech, and generally (my shop) they値l charge about an hour of diagnosis to find problem and quote you for the problem. if it is a spring I imagine it SHOULD cost less than 2 hours of labor for doing 1 spring. but I can imagine that it痴 common to also suggest a new strut and hardware.
    all depends on what the problem it is.
    IG @Colorado.a4
    Dec 01 2011
    Thank You!
    if it is the broken spring, you can probably just replace it with 1, as long as it's the same exact spring, and as long as the other spring isn't that old yet. springs don't really wear out that quick so even if the other side is like 2 years old i would assume it will still have the same strength as a new one so it will match up just fine. but depends how old and how much wear is on it i guess, but otherwise yes you can just replace with 2 that's fine, as long as it's the same type again.
    IG @theshawon
    Mar 19 2019
    Maryland, USA
    Quote Originally Posted by colorado.a4 View Post
    sorry just logging back in, theres 139K on it no bump or pot hole it just came down. i noticed after hearing tire rub.
    do you have a number? shoot me a call or text asap 240-883-4965
    Mar 19 2019
    Maryland, USA
    Quote Originally Posted by Liquid Smoke View Post
    good to know i wanna do 4 but idk if i wanna spend that much right now? any suggestions on brand for springs? greatly appreciated.
    Mar 19 2019
    Maryland, USA
    i also have an A3 with a few questions too, care to look? A3 2.0T Oil Light Indicator & Pressure!
    https://www.audizine.com/forum/showthread.php?t=862899
    Dec 01 2011
    so are these your original stock springs? i would just get the same OEM ones, you can keep the same ride height and comfort and all that and not have to replace more than 1-2. only reason to change up all 4 springs would be if you were trying to lower the car, but that would also require all new shocks which are made for the lowered height, so that makes it all more expensive in total. just replace the 1 damaged spring with the same exact one again and that should be all you need. and then have them check maybe if that 1 shock was affected, or something wrong there with the spring mount/plate, etc so that you can be sure of anything else besides the spring itself.
    IG @theshawon
    Mar 19 2019
    Maryland, USA
    Yes Orginal / Stock Suspension, Thank You For Feedback!
    Feb 15 2016
    Cambridge,Ontario
    im in Canada and lke the Northeast US there is a fair amount of salt used. it is always advisable to replace springs in pairs. If you are in Maryland maybe not , but i would replace both. Ask to see the spring, if its broken due to corrosion ......
    1976 Yamaha XS 360
    Mar 19 2019
    Maryland, USA
    Hello Audizine, Thank You Guys For Commenting With All Of Your Advice + Suggestions. My A4 Is Back On The Road With A Replacement Stock Shock. I Plan To Do Coilovers Soon.
    Established Member Two Rings VAGguy's Avatar
    Apr 08 2008
    04 Passat Variant 1.8T Manual Swap
    Abingdon, MD
    So, it was a shock and not the spring? Would be interesting to see how it failed.
    Mar 19 2019
    Maryland, USA
    Quote Originally Posted by VAGguy View Post
    It Was Shock That Failed, It Was A Stock One. Im Guessing It Was Just Old & Broke Upon Driving Over Rough Roads. I Plan To Do Coilovers All The Way Around.
    @skeeterlaflare
    Veteran Member Four Rings rcprato's Avatar
    Jan 30 2018
    21 Jeep Grand Cherokee Overland
    Rochester, NY
    Maybe the spring seat moved passes the lip on the shock ? Only way I can think of for it to drop down like that without it literally breaking
