Results 1 to 12 of 12
    Apr 04 2018
    '15 tacoma
    Burbank California
    How long does a supercharger last?
    I am wondering if I may have a failing supercharger- I have experienced a gradual loss in power over the past few weeks. The car is still making power, but it feels like I just went from dual pulley back down to single pulley or stage 1 power levels. I remember quite well the numbers I was putting down and now the car is not pulling nearly as hard. I have a supercharger with 160,000 miles on it. I have changed the oil but other than that have done nothing. I don’t know what if anything can fail this way in the supercharger, or if there may be a leak I’m not keen enough to observe. I may be looking at the wrong thing but I can’t think of another reason the car would act this way. It is driving fine and shifting fine, running the same dual pulley setup and a front heat exchanger, but feels very sluggish. If it isn’t the supercharger, I don’t know what it could be. Thank you.
    Jul 31 2016
    PA
    Have you done any carbon cleaning? Any data logging you can share to see what the car is actually doing? Has been exceptionally hot out where you are?
    Sent from my Pixel 3 using Tapatalk
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
    Veteran Member Four Rings Morritse's Avatar
    May 08 2018
    Stage 2 b8 a5 (sold)
    Berkeley, CA
    Log.
    The mechanical part of the supercharger itself is one of the last things I'd expect to fail.
    FBO B8. ~ 10.95@126 ~ 2.96s 0-60 ~ full weight street tires.
    Veteran Member Three Rings silverf0x's Avatar
    Dec 14 2015
    Montreal, QC
    Do you have an aftermarket heat exchanger?
    Murdered B8.5 S4
    Build Thread
    Registered User Four Rings Jay@JXB's Avatar
    Dec 21 2014
    2018 Silverado 3500 HD DRW, Bart the Big Ass Red Trailer.
    Milwaukee
    A supercharger wouldn’t fail like that. If it was mechanical you’d likely hear it too. Do you still have your cats?
    Apr 04 2018
    '15 tacoma
    Burbank California
    Yes, I still have cats in place. I'm wondering if one of them is clogged.
    May 08 2018
    Berkeley, CA
    Quote Originally Posted by GLIS4 View Post
    You will have misfires in all or usually at least 2 of the cylinders in the bank corresponding to the bad cat, especially at high load.
    Change in exhaust tone is usually noticable, as is loss in power.
    Dec 21 2014
    Milwaukee
    I would ditch the cats ASAP as it’s a must for DP. You will destroy your engine if you don’t.
    Mar 20 2015
    McKinney,TX
    Quote Originally Posted by jbullin2 View Post
    Let's find out first what it is before he drops 2-3K on a different setup, if it is the cats then you are correct
    Apr 04 2018
    '15 tacoma
    Burbank California
    From what has been said I think it is cats. The drivers side one seems to be clogged. I checked everything else it could be, no issues with injectors, plugs, coils. The car seems down 70-100hp and misfires on two cylinders, always 5 and 6. I might pick up a borescope and pull the o2 to make sure, but it seems like it. Car seems fine up to around 5k but above there at WOT it misfires every single time. I don't think I can afford to do both cats . now, I wish there was a cheap way to unclog the cat just for the time being.
    May 08 2018
    Berkeley, CA
    I gutted/hollowed out my stock cats and put them back in. Sounds like you don't want to do that though. If you're under 80k miles, emissions equipment (including cats) are covered by a federal mandate, you just have to make the car look stock, tune wise
    Apr 04 2018
    '15 tacoma
    Burbank California
    Following up. I have swapped around coils and plugs. Made absolutely no difference. Popped out the drivers side o2 - made no difference. I stuck a boroscope in the o2 hope and saw the center of the cat is sagging down about a quarter inch. I know this means it is on its way out, but I don't know if that means it is for sure the source of the issue. I do not want to embark on a 3,000 dollar job only to find out it is the fuel system (injectors, fuel sensor?). I have considered swapping the injectors around but since I would have to replace the gaskets, which are not very cheap, I'm not sure where to go. I could pay for VCDS and do logs for more information, or swap around the injectors and see if the problem follows them. I've heard both injectors and cats can lead to this type of symptoms and issues. It is also possible that the misfiring, if it was from the injectors, dumped gas into that cat and screwed it up, although every time it happened to misfire I pulled over and reset the car and limped it home. What do you think?
