Originally Posted by
daytona rs7
i got the Ross-tech VCDS, before they started to limit how many VIN's it can attach to. have never had a problem, and has almost no limitations to what it can read and change.
I hear great things about OBDeleven. i can't help but feel it maybe has some (advanced) functions unavailable to it, that ROSS-tech can do. i may be completely wrong.
Id stay away from the china made VCDS cables, mostly due to the software.. One of the best things about Ross-tech is the software and support (if ever needed) that comes with it. you cant use full/licensed ross-tech software without a ross-tech branded cable.
Thanks! This company specifically discusses the chip in their cable and it being the reason why theirs works. This is a quote from the description of the product on the company's website -
What's the Difference Between (Total Car Diagnostics VAGCOM 18.9.0) — and Original (Ross-Tech VAGCOM)?...
Firstly, this is NOT the original RossTech VAGCOM kit as sold for $600+ on their website... (Even though we encourage you to get the original on their website right now or eventually... if you're truly serious, caring mechanic who deals with customer cars. But if you won't do that for whatever reason, then keep reading...)
Our version of VAG-COM cable uses a 3rd Party manufactured chip. That's why we can keep costs down — because we're not using Ross-Tech™ OEM chip — but 3rd party chip using identical firmware code.
In short, this cuts down our OEM licensing fees... hence we pass those savings onto YOU.
So to clarify... Total Car Diagnostics VAG-COM 18.9.0 cable gives you 100% identical capability of what original VAG-COM $600+ kit can do.
It also comes with original, genuine and fully license-activated RossTech VCDS 18.9.0 software. (Software is NOT cracked or modified in any way. It's original software.)
In summary: This VAGCOM 18.9.0 cable and software is the exact same product in terms of functionality and features when compared side-by-side to original RossTech VAG-COM $600+ kit. You're about to own it at a fraction of the cost. Also our VAGCOM works on unlimited VIN / vehicles - and on unlimited computers. So no restrictions of any kind.
