Originally Posted by
ItsLarryG
So, bushings. I’m considering this how should I or anyone know when it’s time to replace?
I have more suspension info in my review of Koni's Special Active shocks, but I'd say if you see noticeable cracks or deformation in the rubber then it's time to replace. My worst bushing was the middle one under the shock fork, which was so deformed it was off-center. The next worst was the inner upper control arm, which was just cracked. The hydrobearings are easy to spot since they leak oil. The hardest to spot wear on was the steering, since there aren't any exposed parts.
From personal experience, mechanics don't check this for preventive maintenance, so you'd have to specifically pull in with a complaint. (Mechanics aren't as thorough as most people think they are.) As far as subjective feel before/after replacement... I'd say that the failure mode is more of a sloppy/loose steering and tendency towards understeer. After full suspension replacement, I felt more of a difference between driving modes, understeer went away and steering is generally tighter with a strong return to center.
If you're doing this on your own, it's a fairly sizeable job. ...not hard, but time consuming. I'd recommend getting the latest part revisions and getting Lemforder parts (most in stock at FCP Euro with some from AutohausAZ) instead of genuine Audi. You'll spend about a third to half going with Lemforder and they're the ones that make the actual Audi part with the only difference being they grind off the Audi rings so you can't do a warranty claim through a dealership.
